New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jan 30, 2025 at 1:22 PM
    #751
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I ended up with about 3.5-4 inches of lift. I had stock leafs with the overload in place, plus the Deaver minipack. It's a 3-leaf progressive leaf pack. https://deaverspring.com/product/ta...years-3-leaf-overload-replacement-1-1-2-lift/
    If you don't want lift, then I would go stock springs with airbags. It'll support the weight when you need it, and the ride wont' be harsh when the bed is empty.
    Bmktw2[OP] and MT-Tundra[QUOTED] like this.
  2. Jan 30, 2025 at 1:34 PM
    #752
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Thanks. I suppose worst case if I got stock springs and airbags, I could always add a leaf later if I thought I needed it. But doing leaf springs is a pretty major job for me...and I'd rather not do it twice. One of the reasons I keep leaning back toward HD springs every time I think I've decided to just go with stock leafs... :D
    Bmktw2[OP] likes this.
  3. Jan 30, 2025 at 5:51 PM
    #753
    Go HD. I have no complaints about the ride or the additional lift of 1”. I just need a scoche more ride height. And I tow a TT. Sags pretty good in the back when we go camping. Would like to support the weight better.
  4. Jan 30, 2025 at 7:15 PM
    #754
    MT-Tundra
    Montana
    I likely will. I'm more willing to put up with an inch lift than take a chance on being disappointed by stock springs. I know a lot of people want soft rides, but I didn't mind the ride with HD springs on my Tacoma. I don't like stiff, jarring suspension, but I do like firm, 'I can take a bump' suspension.
    Now the 2883s (pretty sure that's what I put on the front of the Tacoma) and OME shocks up front were a completely different story. I was never happy with the ride up front. Too stiff and jarring. But I liked the feel of the HD leaf springs.
    I'm hoping the extra weight of the Tundra will make 2883s feel just right.
  5. Jan 31, 2025 at 7:21 AM
    #755
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Adding to the hijack just to help out. Based on the last couple pages of banter, you won't be disappointed with the ATS HD.
    I had the RAS on my DC - I have full time snugtop canopy and don't carry much regularly, but do carry good size load from time to time. The RAS was great - I had em on my old T100 too and loved it. I didn't want a lift which was my primary motivator for staying with it. I towed a little here and there with utility trailer and never had an issue.
    I finally decided to go with the 6125 up front (I lifted minimum 1" to match my ATS HD) when I did decide to replace my RAS/stock springs. They perform better in ever scenario; I am really glad I went this route. They're not harsh (was a concern of mine) and just deal with every type of truck thing I do just as well or better than the stock with RAS setup.
  6. Jan 31, 2025 at 7:29 AM
    #756
    whatcha do with that RAS….
    bmf4069, ChesterTundra and Bmktw2[OP] like this.
  7. Jan 31, 2025 at 7:34 AM
    #757
    noahrexion
    Washington
    2005 4WD DC
    Sold to a dude on here shortly after swapping springs - $50!
  8. Jan 31, 2025 at 7:37 AM
    #758
    dang
  9. Feb 17, 2025 at 4:33 AM
    #759
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    That's a true Gem :thumbsup:
  10. Mar 23, 2025 at 9:18 AM
    #760
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    I ordered this HD leaf spring setup yesterday desiring an increase of capacity weight to include the fiberglass topper and supply.
    KNABORES, shifty` and FiatRunner like this.
  11. Mar 23, 2025 at 10:30 AM
    #761
    If you think about it, take some before/after measurements. Just curious to see what you end up getting.
    The forward driver side mount is probably the only difficult fastener. When hanging your spring, if doing it solo, or even if not, I found using the OEM bottle jack to be a lifesaver to incrementally lift/hold the spring so the bolt holes line up. Maybe a helpful protip if you haven't done yours yet.
    Don't forget to remove your lower shock bolt, helps a ton with axle travel.
  12. Mar 23, 2025 at 6:55 PM
    #762
    MT-Tundra
    Montana
    I just put the same springs on today. Went surprisingly well. Torque wrench bit it on the third 125 ft/lb hanger/shackle bolt so I had to guess the rest until I buy a new one.
    When you get them, make sure the shackles are installed on the right end of the spring pack. I put new shackles on mine so I can't say for sure I didn't mix them up, but I'm pretty sure they came with shackles installed on the short end of the leaf, rather than the long end. Confused us a for a few minutes.
  13. Mar 24, 2025 at 6:13 AM
    #763
    To avoid this, I used a paint pen to mark an arrow pointing forward on the forward-facing end of the OEM leaf pack.
    When I pulled the leaf pack, I put the ATS and OEM leaf packs side-by-side so the long/short ends matched, and moved over the hanger to the ATS pack.
    Then reinstalled the leaf pack; for good measure, I marked the new leaf pack with similar arrow pointing forward b/c I can be a mindless dumbass at times.
  14. Mar 24, 2025 at 6:38 AM
    #764
    MT-Tundra
    Montana
    That, apparently, would have been far too strategic...
    Luckily we caught it when there were only two shackle bolts installed, and only snug, not torqued. This time was way better than when I did them on my Tacoma. Having a friend helped, but also, there were no real issues. All the bolts came out no problem with the impact wrench, minimal wrestling to get the new bolt holes lined up. Less frustrating all around than I remembered the job being.
    Nic I think I remember we were talking about not wanting a lift, earlier on. I found lowering shackles from Total Chaos and installed those with the new springs. I haven't had a chance to really look close at things, but at first glance I'm really happy with how it turned out. I was very worried about the rear end being jacked up. It's not. I'll get measurements and photos before long, but with OME 2883s + 1stgenoffroad 1/4" spacers up front, and the ATS HD leaf springs in the back with 3/4" lowering shackles, I actually think I found the sweet spot. Might have just returned the truck to the OEM rake.
    Rich L. and Bmktw2[OP] like this.
  15. Mar 24, 2025 at 6:44 AM
    #765
    Don't worry @bmf4069 has horror stories too. He was the inspiration behind my process. This is why I always share openly any of my failures on here, and I'm happy to see people confident enough to share their f-ups on here all the same. We don't all need to fail; one person sharing their failures can help dozens of others from having to learn, similarly, the hard way.
    (Now if I could just get our kids to actually listen when we share our failures, so they don't make the same mistakes...)
    bmf4069, Bmktw2[OP] and Ghost Rider like this.
  16. Mar 24, 2025 at 6:55 AM
    #766
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Amen.
    Bmktw2[OP] and shifty`[QUOTED] like this.
  17. Mar 24, 2025 at 10:04 AM
    #767
    bmf4069 Captain wtf
    Yeah, we just straight put the springs on backerds. Beer may or may not have been involved.
    shifty`[QUOTED] and Bmktw2[OP] like this.
  18. Mar 24, 2025 at 11:40 AM
    #768
    MT-Tundra
    Montana
    Funny. We noticed there was no way the alignment pin on the leaf springs was going to reach the hole on the axle. "Either I bought the wrong springs, something else is weird here..."
  19. Mar 28, 2025 at 6:53 AM
    #769
    noahrexion
    Washington
    2005 4WD DC
    At least you didn't get out the chain binders :)
  20. Mar 28, 2025 at 2:17 PM
    #770
    MT-Tundra
    Montana
    We knew better than to force it
  21. Mar 28, 2025 at 4:42 PM
    #771
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    New ATS heavy duty 4 leaf
    Original equipment soft 3 leaf
  22. Mar 30, 2025 at 1:33 PM
    #772
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The bolts have to be installed in a certain direction or else they don't fit or get stuck behind the Reese hitch.
    Then you have to cut the bolt short that goes under the bump stop.
    The truck lifted a little bit but I'm really happy
  23. Mar 30, 2025 at 1:38 PM
    #773
    It’ll be great when you have your camper shell on there
    Bmktw2[QUOTED][OP] likes this.
  24. Mar 31, 2025 at 12:34 PM
    #774
    MT-Tundra
    Montana
    Looks great! Yep, we had to cut that center bolt, too, but since I replaced my stock bump stops with Sumo Springs, I wasn't sure if that was the reason.
    With the 3/4" lowering shackle, I think I got almost no lift at all. It definitely raised the back end from where it was sitting due to completely worn leaf springs, but I don't think I'm much higher than stock.
  25. Mar 31, 2025 at 1:01 PM
    #775
    Definitely had to cut and file the center pin bolt on mine also.
  26. Mar 31, 2025 at 1:36 PM
    #776
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I also wanted to mention that the bolts on the shackle have to be installed a certain way. Anyone installing new leaf springs, note the image I have shown of the bolt orientation.
  27. Mar 31, 2025 at 2:02 PM
    #777
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Here is where I'm at right now. Empty tank of gas and fresh springs installed yesterday. Once I get a full tank and the springs settle a little it should be fine. The ride is definitely a bit firmer but I believe it really needed it so I'm happy. Would recommend to anyone on the site to get these springs especially if you have a topper or use a trailer.
    After:
    Before:
    Acatlin96 and The Black Mamba like this.
  28. Mar 31, 2025 at 5:59 PM
    #778
    MT-Tundra
    Montana
    Yeah looks great. I agree, they feel good. I've been driving a lot of dirt roads that are pretty trashed as winter starts thawing, and I love the way my suspension feels.
    Bmktw2[OP] and KNABORES like this.
