How big is yours? Measure up!
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, May 15, 2019.
  1. Feb 17, 2025 at 7:19 AM
    #181
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Going in for a re-do. Icon Stage 1 maxed preload based on the instructions in the front...177k tired leaf packs in the back. Freedom UCAs, extended end links in the front as well. Sits at 21" front and a hair over 21 in the rear. Topper and 175lb drawer set up in the bed. Perfect stance just not the height I'm looking for. Contacted Accutune and Alcan for some advice. We'll see what happens. Pic 1 is when I first bought her...heavy ass grandpa hard tonneau on the bed. Pic 2 was yesterday. 265/70/17s in both pics.
  2. Feb 24, 2025 at 8:29 AM
    #182
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Are you looking for more height? Are you planning on sticking with that tire size?
  3. Feb 24, 2025 at 8:30 AM
    #183
    Damn. That thing is sexxxxxy AF
    Tlar25 likes this.
  4. Feb 24, 2025 at 8:31 AM
    #184
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Agreed. What wheels are those? @wtrbrdm ?
  5. Mar 8, 2025 at 4:26 PM
    #185
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    Should be going under the knife in 2 weeks or whenever I get a weekend free. Waiting on the final items to come in slowly.
    RRW RR7-S with 275/70/17s
    Radflo front coilover
    Durobumps
    Fr33lanceFab gusseted spindles with extended lug studs
    CVJ Axles and fresh oil seals
    ECGS needle bearing delete
    Already have Freedom UCAs, extended links, OEM LBJ and LCAs installed
    Radflo rear shocks
    Archive Garage MD leaf packs
    Archive Garage u-bolt flip kit with #4 bumpstops
    GX front calipers
    Advics rotors
    Akebono pads
    Fr33lancefab Wildwood LSPV delete
    Front and rear stainless brake lines
    Should be a fun weekend. Gotta install the Weboost, fridge slide and other odds and ends in too. I need a different hobby.
    bmf4069 and Kimosabe like this.
  6. Mar 8, 2025 at 5:11 PM
    #186
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I'll be interested in your review on the radflo. I've only ever heard good things. Did you get external reservoirs with those? What rate springs come with them?
  7. Mar 8, 2025 at 5:27 PM
    #187
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    Went with the 2.5s...non-resi. Based on the "offroading" I do, they should be fine. I emailed them the type of driving, terrain, and front/rear truck weight (CAT scale'd it) info. Leaving the weight set up and valving up to them.
  8. Mar 31, 2025 at 12:45 PM
    #188
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I don't think my measurements are very precise, but here goes.
    Before suspension work:
    Front hub to fender: 20.5"
    Rear hub to fender: 20.5"
    After suspension work:
    Front: 21" (passenger side 21.5")
    Rear: 21.5"
    This is after some settling, but only a few days.
    Suspension work:
    Front: OME 2883 with Bilstein 4600, + 1st gen offroad 1/4" spacers
    Rear: ATS HD leaf springs with Bilstein 5100 and Total Chaos 3/4" lowering shackles
    I don't really even feel the need to stuff bigger tires in there to fill in the space. Really just slightly lifted the whole truck, probably not even perceptible to the untrained eye.
    Tlar25, whodatschrome, BroHon and 2 others like this.
  9. May 8, 2025 at 5:45 PM
    #189
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Noticed i never updated this, but with bilstein 6112’s on the bottom notch, a full set of skidrow skidplates, a cap, a battery, a fridge, a solar panel, tools, and polo’s suite in the back of the cab.
    (From the steering wheel)
    LF: 21.5”
    LR: 21.5”
    RF: 20.75”
    RR:21”
    with polos 120lbs about centered, and my 200lbs in the driver seating squares up almost perfect.
    MD0811, Tlar25, bmf4069 and 1 other person like this.
