Lower ball joints/part numbers
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Oct 23, 2021.
  1. Mar 25, 2025 at 7:39 AM
    #391
    No clue! But I'd err on the side of caution. I'm curious what the difference is now. If you flip back to the earlier pages of this thread to look at that bolt part number, you'll see another member who had issues with that bolt being too skinny, so clearly there's something going on with bolt hole sizes ...
  2. Mar 25, 2025 at 7:42 AM
    #392
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    @__YG__ if you order the part numbers that seem to match your truck please post pictures of the parts, as well as the part numbers indicated on the box/bag and see if they are the same.
  3. Mar 25, 2025 at 7:56 AM
    #393
    It's also curious because, unless something is wrong in the documentation, I had the numbers taken from the recall doc as:
    • Late '04 - '06
    • Early '02 - '03
    • Early '01 - '02
    If those years are accurate, then '04+ has to be the same joint, I think? Unless they're custom-boxing things based on the VIN at McGeorge? That'd be wild.
    If those year ranges are wrong, I need to update my reply on the 1st page. I did just put a big disclaimer in my 1st reply on this thread to urge folks to look up their part numbers directly.
  4. Mar 25, 2025 at 10:45 AM
    #394
    __YG__
    __YG__ New Member
    2005 V8 4WD Access Cab
    So if I understand correctly, my truck has the same ball joints as the 04 since its an early 05?
  5. Mar 25, 2025 at 11:54 AM
    #395
    That's what I'm thinking. I'd need to run an '04 truck's VIN thru EPC to say with 110% certainy, "yep!"
  6. Mar 25, 2025 at 1:14 PM
    #396
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mines a later 04 and this is what I just put on from Ourisman if that helps.
    The Black Mamba likes this.
  7. Mar 25, 2025 at 1:37 PM
    #397
    __YG__
    __YG__ New Member
    I cant seem to find the part numbers you sent, I wonder if these are what Im looking for, LH 43340-39595 & RH 43330-39825 ?
    When you look up the part numbers I just mentioned on autoparts.toyota.com the other part numbers are listed as previous versions.
    what are your thoughts?
  8. Mar 25, 2025 at 1:40 PM
    #398
    __YG__
    __YG__ New Member
    Ah, only now seeing this response, so maybe that is what I need as well then
  9. Mar 25, 2025 at 2:37 PM
    #399
    The part numbers in the picture you quoted, those are what the EPC-DATA site gives me when directly inputting your specific VIN, 2005 AC in V8/4WD.
    But the parts Bubba is showing pics of, those are identical to what I ordered for my '06 AC in V8/4WD.
    Which is correct, the one EPC data gives for your truck, or what Bubba ordered for his '04 and I ordered for my '06? Not sure, but you can always check compatibility in the Toyota Parts system by giving your VIN and noting what Toyota says is compatible. Unfortunately ... see the result of that below.
    I would find it VERY strange Toyota would list a recall kit for '04-'06 truck year range specifically, but somehow have different LBJ part numbers for the three of our trucks... Just sayin'.
    But really. You have four part numbers - the ones Bubba and I used, and the ones EPC spit out for your VIN - use the links in this reply to load up one of the part numbers Bubba and I used, then click the "ENTER YOUR VIN" to check compatibility. Is it compatible with your VIN in their system?
    When I did it using your VIN, this is what I saw...
    (But I saw the same with the EPC part numbers too!!! It makes no sense!) :rofl:
  10. Mar 25, 2025 at 3:14 PM
    #400
    __YG__
    __YG__ New Member
    Im beyond confused lol
    This is what I was referring to though
    The parts I was searching for are listed as previous versions under this part. But when I put in my VIN it also says may not fit, although Im not sure how accurate that is.
  11. Mar 25, 2025 at 3:26 PM
    #401
    That's typical. Toyota changes part numbers, i.e. supercessions (or whatever they call it). But I don't see our '06 part numbers in the supercession list.
  12. Mar 25, 2025 at 3:57 PM
    #402
    __YG__
    __YG__ New Member
    The part number at the top is the one bubba used (39595) and the previous versions list the ones you picked out with my vin 39515, 39575
    might be the correct part still not sure though…
  13. Mar 25, 2025 at 6:42 PM
    #403
    Ah. Well. That would explain it then :rofl:
    Yeah, this solves the riddle. I didn't look at the supercessions to realize they were the same part, but one is a future revision. Looks like they were jumping up by 20s on the last three digits of part numbers
    i.e. 495 + 20 = 515, 515 +20 +20 +20 = 575, 575 + 20 = 595.
  14. Mar 25, 2025 at 8:07 PM
    #404
    __YG__
    __YG__ New Member
    Ah true didnt catch that.
    So in conclusion we thinking LH 43340-39595, RH 43330-39825, Bolt 90080-10066 are the correct ones?
    Is that the bolt you used as well @BubbaW ?
  15. Mar 26, 2025 at 3:26 AM
    #405
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Correct
  16. Mar 28, 2025 at 6:46 PM
    #406
    __YG__
    __YG__ New Member
    Update:
    Got the parts and went to install one of the ball joints today, Bolts do not fit...
    From what I can find online it seems like those are the ones that should fit, they are however too small.
    Re-used the old bolts for now would like to figure out the correct bolts and switch those out tho... any other suggestions where I can look up part numbers?
    I remember reading something somewhere about someone else on the forum having issues with the bolt sizing, cant find it though.
  17. Mar 29, 2025 at 4:12 PM
    #407
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    About to order Bj's and bolts for my 2000 Tundra, Don't need the ARP bolts does everything in my cart here work? Making sure I didn't read something wrong in all these ball joint threads.
  18. Mar 29, 2025 at 4:34 PM
    #408
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yup. Those are the same parts numbers I installed.
    Filthyphil likes this.
  19. Mar 29, 2025 at 5:25 PM
    #409
    Filthyphil
    Phil
    Sweet thanks brotha! Where did you order from?
  20. Mar 29, 2025 at 7:03 PM
    #410
    The Black Mamba
    DFW
    Imma keep it stock
    Filthyphil[QUOTED] likes this.
  21. Mar 30, 2025 at 5:44 AM
    #411
    NickB_01TRD
    KY
    Big bolt is 9010512316 small bolt is 90080-10066 that you ordered.
    @BubbaW are you sure you ordered small bolts previously for your 04?
  22. Mar 30, 2025 at 7:24 AM
    #412
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Couldn't find receipt but this is my entry in the Parts ordered spreadsheet I use for Ourisman purchases. Seems I was mistaken earlier and did use the longer bolts, sorry YG.
