2008 tundra ..ABS CODE C0278 - OPEN CIRCUIT IN ABS SOLENOID RELAY CIRCUIT ....PLUS SECONDARY CODE C
Discussion in '2nd Gen Builds (2007-2013)' started by 2008tundrapooltruck, Oct 22, 2019.
  1. Oct 22, 2019 at 8:14 PM
    2008tundrapooltruck
    2008tundrapooltruck [OP] New Member
    2008 tundra ..ABS CODE C0278 - OPEN CIRCUIT IN ABS SOLENOID RELAY CIRCUIT ....PLUS SECONDARY CODE C1310 1, EV SYSTEM MALFUNCTION 2. HV SYSTEM MALFUNCTION
    !! HELLO PLEASE HELP !!
    WHEN I START MY TRUCK NO BAD DASH LIGHTS ARE LIT... I DRIVE, ONCE I HIT 15MPH THE DOORS LOCK, AS NORMAL, AND AT THE EXACT SAME TIME THAT THE DOORS LOCK..... THE DASH LIGHTS UP! BRAKE LIGHT, ABS LIGHT, VSC LIGHT, TRACTION LIGHT ALL LIGHT UP AND I LOOSE THE ANTI LOCK BREAKING AND TRACTION FUNCTIONS...
    CAN ANYONE PLEASE TELL ME WITH THESE CODES AND SYMPTOMS WHAT THE PROBLEM IS?? I THOUGHT IT WOULD BE A ABS RELAY BUT THIS TRUCK DOES NOT SEEM TO HAVE AN ABS RELAY. SO NOW I'M THINKING ITS THE ABS MODULE AND THAT THE ABS SOLENOID MAY BE PART OF THE ABS CONTROL MODULE..
    LIKE I SAY PLEASE HELP!!!!!
  2. Sep 7, 2020 at 5:58 PM
    Josef67
    Josef67 New Member
    Jose
    Tundra
    Hello, I have the same exact problem as you. I would like to know how you fixed it or what was the problem with it?
    Sindi likes this.
  3. Jul 27, 2021 at 9:17 AM
    5uperman
    5uperman New Member
    P
    07 Tundra Crew Cab leveled on 35's
    I'm amazed there isn't more information on the internet about this issue. I'm not sure the cause; there's been a lot of potholes and rough roads, but last week I was driving home from the VA and the ABS light came on solid, the e-brake light is on solid, the traction control light is on solid and the VSC light is flashing. I hooked up techstream since my snap-on solus refuses to work anymore; I got codes C0278 Open circuit in ABS Solenoid Relay and C1310 "Active booster solenoid". The truck is an 07 with 223k on it and still runs very well. I haven't had to do a whole lot other than tires, brakes and fluids in the years I've owned her. I've checked the wires at the wheels and they seem fine, and I've checked the wiring around the booster which also seems fine. Fuses don't appear to be blown. I really was hoping that I could gain some insight before spending hours upon hours out in the driveway with a multimeter checking every single circuit.
    Anyone?????
    Buehler?????
    Thanks.
  4. Dec 26, 2021 at 2:26 PM
    Ryanrmk
    Ryanrmk New Member
    2010 cm 4.6 4x4
    I’m having the exact same issue. Wonder if y’all ever found a solution?
  5. Jul 9, 2024 at 7:25 PM
    Sindi
    Sindi New Member
    I have the same the same issue. Please help out if you have the solution.
  6. Sep 25, 2024 at 8:46 PM
    erkme73
    erkme73 New Member
    Same on my 2011 Sequoia. Just started today. Autel reader shows codes C0278 (ABS solenoid relay circuit open)... as well as 6 more ABS codes:
    C0278 - ABS solenoid relay circuit open
    C1275 - Abnormal change in output signal of RF speed sensor
    C1276 - Abnormal change in output signal of LF speed sensor
    C1277 - Abnormal change in output signal of RR speed sensor
    C1278 - Abnormal change in output signal of LR speed sensor
    C1279 - Deceleration sensor output voltage abnormal
    C1281 - Master cylinder pressure sensor abnormal
    Makes me think it's ABS module related - maybe not getting proper voltage/current. Reader shows identical speeds for each wheel speed sensor on live data.
    Very frustrating. With 250k on the odo, I'm not particularly keen on taking it to my local dealer. I'm sure it'll be expensive, but I have zero confidence in their ability to rotate tires, let alone solve this mystery.
  7. Mar 28, 2025 at 1:32 PM
    bmbgmc96
    bmbgmc96 New Member
    My 2010 tundra threw these codes today, C0278 Open circuit in ABS Solenoid Relay and C1310 Active booster solenoid. Has anyone figured out what the problem is? Any help would be appreciated.
