Catch Can?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ghost Rider, Mar 27, 2025.
  1. Mar 27, 2025 at 1:58 PM
    Ghost Rider
    Ghost Rider [OP] Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Does anyone have an installed catch can that caught nothing within the span of, 11-ish months?
    I installed one of those on my truck and it is roughly 11 months, no a single drop, though does smell of strong petrol if I sniff the can.
    Normal, or weird?
    https://www.radiumauto.com/Tundra-Catch-Can-Kits-07-21-P933.aspx
  2. Mar 27, 2025 at 2:19 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    This was discussed a lot on the general supercharger thread. The newer radium design is terrible and does not catch anything. Better off with a cheap Amazon one or a J&L.
  3. Mar 27, 2025 at 4:18 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Oh.....I'm not FI, just NA.....
    Installed it just to see what it can catch..... My Taco fiend caught quite a bit from his brand new 2024 (back then) Subaru Outback Wildness.....
  4. Mar 27, 2025 at 4:28 PM
    Retired...finally
    Sniffing cans? @hagrid. Maybe you have an opinion on this behavior.:eek2:
    vtl, Bammer, Saltyhero13 and 4 others like this.
  5. Mar 27, 2025 at 4:38 PM
    Silver17
    Eastern PA
    Yeah, unfortunately it doesn’t matter whether it’s FI or NA the newer design Radium catchcan doesn’t seem to work too well. Some have modified it with some steel wool with success. I could try and find that post for you. I think it was @PolishedTRD that was the first to modify his.
  6. Mar 27, 2025 at 5:02 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That’s one guy that has a vast amount of experience sniffing cans. I look forward to his reply.
  7. Mar 27, 2025 at 5:37 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Yes, please, and thank you.
  8. Mar 27, 2025 at 5:43 PM
    Silver17
    Eastern PA
  9. Mar 27, 2025 at 6:00 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Radium and big name cans are an absolute waste of money. Buy one of the many $30 Amazon options from Evil Energy or whatever, does just as much if not more than a name brand can and looks just as good imo
    Mdl, Tripleconpanna and PolishedTRD like this.
  10. Mar 27, 2025 at 6:05 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    My catch cans caught nothing until I altered them. Even then only the can attached to the PCV valve does anything - the can attached to the valve cover ports is pointless.
    Looking at that Radium link, it looks like the design has slightly changed from what I have. I ended up gutting my catch can lids and added stainless steel Scotch Brite pads inside the cans. The can connected to the PCV valve now actually catches.
    Here are my posts about it in the general supercharger thread. 1 2
  11. Mar 27, 2025 at 6:21 PM
    centex
    centex New Member
    Catch cans are beer cans with steel wool. Do not fall for the crazy prices and marketing on them.
    vtl, Tripleconpanna and hagrid like this.
  12. Mar 27, 2025 at 6:44 PM
    Not all catch cans are the same.
    Dirty side catch can:
    Clean side catch can:
    200 miles of pretty easy driving. I don't want this 5W-50 in my intake...or on top of my intake valves (DI).
  13. Mar 27, 2025 at 6:44 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Indeed.
    I do not sniff cans. I sniff buckeyes and starfish. It is a worthwhile pastime that I recommend to all with a Tundra and a mast mounted radial array transmission cooler.
  14. Mar 27, 2025 at 6:47 PM
    centex
    centex New Member
    I wish I could find the picture I took of my old L83 Silverado. 168k miles of no catch can. Almost no build up on the valves at all. Direct injected. It’s not the issue the internet makes it out to be.
    Ruggybuggy and hagrid like this.
  15. Mar 27, 2025 at 6:51 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Whilst I'm inclined to agree, ze germans have responded with, "hold my bier".
    I've seen many BMW and Merecedes engines with coked intake valves. Not personally, via the youtubes.
    Retired...finally likes this.
  16. Mar 27, 2025 at 6:57 PM
    Maybe or maybe not. I do know several BMW owners that have received misfire CEL codes under 50K miles without catch cans. BMW actually has a walnut blasting maintenance schedule for this reason alone. Regardless, my CC's stopped oil from going into my SC. Good enough reason to justify it.
    I did a PCV re-route on my diesel too. When I popped off the intake plenum to the turbo my compressor wheel was nicely coated. My charge pipes were as well. 25K miles later, that has been resolved.
    Personally I don't mind the cost or added maintenance. If the one can caught that much oil in 200 miles...imagine in 3000K miles between oil changes?
    Black Wolf and Tripleconpanna like this.
  17. Mar 27, 2025 at 6:57 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    My "new" Radium wouldn't catch anything until I modified it. I went a bit further than just steel wool and added a bypass port cover sleeve AND more wool. I posted in the SC thread about it.
    Now it finally catches some goo.
    Saltyhero13 and Tripleconpanna like this.
  18. Mar 27, 2025 at 7:07 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Ghost Rider[OP] likes this.
  19. Mar 27, 2025 at 7:12 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    That has to be the first Tundra w/a supercharged 5.0 I've ever seen :anonymous:
    We're gonna need a write up on that entire process... :evil:
  20. Mar 27, 2025 at 7:13 PM
    snivilous
    SW UT
    This was how full my Amazon one was after a single drive the other day. Fat ring gaps, new engine still sealing, and seeing 20psi of boost every few minutes :D
  21. Mar 27, 2025 at 7:17 PM
    Yeah, I would say that's a sound investment. You can get some really cheap CC's that work well.
  22. Mar 27, 2025 at 7:29 PM
    Ghost Rider
    Ian
    Cypress, Texas
    So, help me understand some more, the CC is not catching mainly due to not enough pressure build up to "push" the blowby into the can and actually making the CC work as intended?
    My Taco fiend said his Type R Civic caught quite some as well, but from my limited knowledge, those are all FI, not NA.
    I have no issue with it not catching anything, if the pressure buildup was lacking therefore, not catching.
    But looking at some of those pictures, I might need to take the whole thing apart and figure out this "steel wool" thing.
  23. Mar 27, 2025 at 7:45 PM
    centex
    centex New Member
    Because German cars have such a fantastic history of reliability, ease of maintenance, and simplicity.
    hagrid[QUOTED] and ColoradoTJ like this.
  24. Mar 27, 2025 at 8:00 PM
    VWTim
    Corvallis, OR
    When Radium redesigned their can to have an overflow float ball valve, they inadvertently allowed it to bypass and not condense in the can. Vapors come in and immediately go out without anything to help them drop out of suspension in the air. This is where the steel wool or a sleeve to force the flow to never bypass, comes into play.
  25. Mar 27, 2025 at 8:15 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Ah. So the valve ball has to be removed in order to not have it "bypass" the can? If that's the case, guess the easiest fix would be the steel wool to "force" it to condense.
  26. Mar 27, 2025 at 8:31 PM
    VWTim
    Corvallis, OR
    Check post #10 above, he posted links that have photos and help explain the simple fix. Mines buried in there months later and involved a copper tube sleeve in addition to steel wool.
  27. Mar 27, 2025 at 8:43 PM
    Ghost Rider
    Ian
    Cypress, Texas
    I give the tube some thought, might try that later, steel wool sounds a bit easier.
  28. Mar 27, 2025 at 9:19 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I used one from Amazon and so far so good..
    Has a dip stick and steel wool separator.
    Time will tell, but the radium one just costs to much.
    Mdl likes this.
  29. Mar 28, 2025 at 1:45 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    https://a.co/d/fzNOn8l
    This one? Just discovering this mod. I’m not boosted (NA). Is this worth my time? Will this one get the job done for $35? The Radium is almost $300 and seems not to work according to other posts.
    mustang67408[QUOTED] likes this.
  30. Mar 28, 2025 at 4:44 AM
    centex
    centex New Member
    NA I’d say no but this is a hot topic on the interwebz.
