Wireless CarPlay and wireless mag charger 2020 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by sadbttru, Dec 7, 2023.
  1. Dec 7, 2023 at 8:31 AM
    sadbttru
    sadbttru [OP] New Member
    2020 tundra 1794 edition
    None yet but help!
    Hello,
    just wanted to share this. Watched a few videos on removing the shifter section of trim. Whole project cost less than 100$ cnd. And took less than 1 hr. Now I have wireless Apple CarPlay and a wireless mag charger. A friend is bring a scrap of brown leather that I will wrap the wood in or I’ll urethane the top piece. Only thing I might add is a strip of Velcro to the bottom but it’s a snug fit so I likely will not need it.
    Henry1jg likes this.
  2. Dec 8, 2023 at 8:34 AM
    sadbttru
    None yet but help!
    Here is the final:
    bulldog93 likes this.
  3. Dec 8, 2023 at 9:17 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    Looks good , planning on building something like this on the armrest, what are you using to hold charger on wood?
  4. Dec 8, 2023 at 11:53 AM
    sadbttru
    None yet but help!
    So I have some glue I was going to use but I wanted to test everything first. So the charger is held to the leather and the leather held to the console with double sided hanging tape. I might add a layer of cork to the middle as the charger sits high right now and I wanted more of a sunken look rather than it just sitting on top. I had to turn it that way as there is not enough clearance to the bottom if the usb area for the phone to fit.
    I looked at doing this in armrest but I open that thing all the time and the magnet is not strong enough to keep it from flying off!
  5. Jan 1, 2024 at 7:19 AM
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    I’m looking for something similar to this, what were the actual charger/cables you bought to make this up?
  6. Jan 1, 2024 at 7:38 AM
    sadbttru
    None yet but help!
    I can post the links if you need them but here is the stuff! Been working great. Not 100% satisfied with the wrap job of the base /charger but I am picky that way
  7. Jan 2, 2024 at 6:53 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I think there are MagSafe options for the console lid insert now too. I’ve seen some threads about them. I used an earlier version of this CarPlay adapter and the same USB adapter, console mod and it works well.
  8. Jan 2, 2024 at 6:56 AM
    sadbttru
    None yet but help!
    Yeah there is an adapter that fits in that insert. I am in and out of that centre storage a lot. My phone would for sure get flipped into the back once a day! That’s why covering that cup holder worked better for me. Would not hold much anyway but you could drill a hole anywhere near there. There is a ton of room there
    ChesterTundra likes this.
  9. Jan 2, 2024 at 9:29 AM
    Sfrigon
    Sfrigon New Member
    Sylvain
    Tundra 2020
    On my SR5 2020, the Android auto seem to not be available on the radio itself ( the word of my dealer). I ask them to add that feature because the radio look like it could take it, but they said it's not possible. So I'm wondering if that device will add Android auto to my vehicle radio? Looking at the spec, it basically a WiFi card added, but I need the factory Android? Is that it? If so somebody find a box with Android complete?
  10. Jan 2, 2024 at 9:32 AM
    sadbttru
    None yet but help!
    Sorry I don’t know about androids
  11. Jan 2, 2024 at 2:10 PM
    ChrisLopez
    Christian
    Chicago,Illinois
  12. Apr 3, 2024 at 8:40 PM
    HartysTundra
    HartysTundra New Member
    Looks good!
  13. Apr 4, 2024 at 8:59 AM
    PapiShields
    PapiShields Big Bad Voodoo Daddy
    Chicago - NW Suburbs
    2020 VooDoo Blue Tundra SR5 - TRD Sport
    BDS 4.5" lift kit w/ Fox shocks and Swaybar Links Black Rhino Barricade 20x9 +10 wheels powder coated black. BFG KO2 35x12.5 R20. Go Rhino RB20 Running Boards - Protected Bedliner Coating Drivers Side Grab Handle
    Do you notice a delay in audio when watching videos (obviously not when driving.)?
  14. Mar 27, 2025 at 9:31 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    Yes, there's a noticeable delay in the audio. Most noticeable with video, but don't need to do that often. I do notice it when I first start playing a song on Spotify, it will take a bit.
    I have the same Carlinkit 5.0, wondering if others have the same experience and if other adapters have the same problem. Or even headhunts that have wireless CarPlay built in?
    Bluetooth headphones don't have a noticeable delay, so not sure why this should be different.
    Edit: A quick google search indicates there's some settings that could be toggled to fix: https://www.reddit.com/r/CarPlay/comments/xkzqz3/comment/ipp17oy/. I'll give it a shot and see if it works.
