Four Wheel Camper (FWC) Thread
Discussion in 'General Tundra Discussion' started by Drainbung, Aug 28, 2021.
  1. Mar 26, 2025 at 8:24 PM
    #151
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I have finally finished my Project M cabinet—well, half of it, at least! I'm so happy with how it turned out, although it was a lot more work than I expected though. It's made of a 1" aluminum extrusion frame, 1/2" maple plywood, Formica countertops on 3/4" MDF. I used Prospect Overland's video as an initial guide for the frame. Then did my own thing and made it up the design from there.
    This side houses a Truma Varioheat Eco heater that runs off a 10lb propane tank on the back, as well as the Goal Zero, which powers the whole setup with a few fuse buses throughout. Using the Goal Zero external display for the power allowed me to completely close in the main unit and still control it.
    I plan to build the other side this spring, but it should be simpler. Just more of a low, bench height cubby with a few drawers and no electronics or heater.
  2. Mar 27, 2025 at 7:46 AM
    #152
    wackyhacky
    wackyhacky New Member
    Keith
    Berthoud, CO
    2020 Limited Double Cab
    That is excellent work there. Looks great.
  3. Mar 29, 2025 at 5:30 AM
    #153
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    SICK! That's true craftsmanship. Really well done.
  4. Mar 29, 2025 at 9:43 PM
    #154
    mrmahi
    mrmahi New Member
    2014 Tundra
    Wow that looks factory!
    Corndog123, junior and Drainbung[OP] like this.
  5. Mar 30, 2025 at 9:20 AM
    #155
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Thanks guys. I was going for a factory look after seeing some of the FWC in person last year. It just felt right!
    Corndog123 and Drainbung[OP] like this.
  6. Jun 7, 2025 at 5:26 PM
    #156
    Drainbung
    Drainbung [OP] Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    vorkuta775 and Wallygator like this.
  7. Jul 19, 2025 at 7:48 PM
    #157
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Hey Mike, who did you go through for your mattress?
  8. Jul 19, 2025 at 9:00 PM
    #158
    vorkuta775
    vorkuta775 New Member
    Reno mattress on 4th street. Bring your FWC they will measure it and get you any material you want
  9. Jul 20, 2025 at 8:49 AM
    #159
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Excellent, thanks!
  10. Jul 20, 2025 at 3:26 PM
    #160
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Wow awesome thanks for sharing!
    How did you source your truma?! And what techniques and tools did you use to cut the exhaust port for it?
  11. Aug 12, 2025 at 2:49 PM
    #161
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Ended up grabbing an old Kestrel model!
    Here's some pics.
