Added MTS/Crawl Control switch to Platinum CrewMax
Discussion in '3rd Gen Tundras (2022+)' started by Tundra_Lover7, Oct 19, 2022.
  1. Mar 25, 2025 at 10:01 AM
    #271
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    2025 iForceMax 1794 Lunar Rock
    Heads Up | PRBs/TG | Tow Mirrors | X4TS Cover
    I purchased my truck not even a week ago, found this thread, looked up my local dealer parts, they have it for the $138.
    Ordered it, will install before I put on the matte console accessory. MTS is all I was looking for.
    I didn't like the way the TRD Pro handled for comfort / long trips, so this is great to have more intelligence into the system when needed.
  2. Mar 25, 2025 at 10:03 AM
    #272
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    Which dealer was this?
  3. Mar 25, 2025 at 10:17 AM
    #273
    KMAGS
    KMAGS New Member
    Ken
    STL MO
  4. Mar 25, 2025 at 10:25 AM
    #274
    JayDee
    JayDee New Member
    Has anyone verified that adding this switch actually alters the way 4WD works? I'm not sure how it could be tested. Maybe by driving on the selected type of terrain and seeing if the truck is handling any better?
    Anyone know what the terrain settings are supposed to actually do?
  5. Mar 25, 2025 at 10:35 AM
    #275
    mikewantsabeer
    mikewantsabeer New Member
    Pacific County, WA
    2023 Tundra Limited
    it adjusts throttle control, traction control, brake inputs. Mine arrives tomorrow and I will take it down to the beach at some point to test for obvious differences in the sand. I got it on sale for the off chance it gives me a little added security in winter, spend a lot of time in snowy/icy mountain roads. Will report back.
  6. Mar 25, 2025 at 10:56 AM
    #276
    ESalt206
    ESalt206 25 Limited
    CO
  7. Mar 25, 2025 at 11:13 AM
    #277
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    You're right! man -- I must have fat fingered it!
    I just cancelled mine, on the hunt again.
    84970-0C010 - is the right part number -- it's like $180
    **UPDATE** I ordered it from https://autoparts.fredandersontoyota.com/ like others - $175 shipped.
  8. Mar 25, 2025 at 12:13 PM
    #278
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Yes thank you. I have that. I'm referring to the thing that comes in the TRD OR package. It's an additional view on top of the 360 PVM.
  9. Mar 25, 2025 at 12:16 PM
    #279
    Rookhoe
    Rookhoe New Member
    Binghamton, NY
    2025 Mesquite Toyota Tundra Limited
    Waiting to install my matte console accessory until after I install mine as well. Too many possibilities for scratches.
    $175 seems to be the cheapest anyone has found at this point.
  10. Mar 25, 2025 at 12:23 PM
    #280
    ziznack
    ziznack New Member
    Texas Y'all
    That's why I said fake camera piece together thing.
  11. Mar 25, 2025 at 7:35 PM
    #281
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    I have 2023 Limited, with no AVS, no rear locker, just load leveling suspension. Non TRD, non hybrid. Would this switch add anything to my truck?
  12. Mar 25, 2025 at 8:05 PM
    #282
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    We really need a way to pin posts, to the end of forum. I think most people skip to last page - read a few things - I get it.
    To summarize the 10pages before this post:
    This is NOT a 100% solution. There are some SR5s that this isn't working for them.
    It looks like Limited and up - this appears working for most.
    WORKS:
    Only the MTS system will get enabled by this switch swap and those only show up in 4H and 4L - 4 modes on each. From some other posts, some mention you CANNOT turn on MTS while stopped even in 4H/L - you need to be moving.
    Hard to confirm, but many have stated it's affecting their trucks (throttle, abs/traction).
    DOESN'T WORK:
    Crawl does not work - it looks like something is missing, some ECU - no one is sure, no one has that working.
    This appears to NOT add the 'under the truck' camera.
    People have tried looking to see if it's the rear diff-locker - but to no avail.
    People have replaced some of the ECUs - but to no avail.
    Correct Part Number: 84970-0C010
    (Don't accidentally get others as variations of the same switch are out there as 84970-0C020 84970-0C030)
    Dealer that will ship for free, and appears to be one of the lowest priced:
    Combination Switch Assembly #84970-0C010 | Autoparts.toyota.com
    In time someone may figure it out more...
    kkkk2023, ziznack, work truck and 9 others like this.
  13. Mar 25, 2025 at 10:35 PM
    #283
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Yes, I have the virtual under the truck view. Thought that was part of the 360 PVM.
    Blufin likes this.
  14. Mar 26, 2025 at 2:15 PM
    #284
    CajunTim
    CajunTim Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    Add 84970-0C010- is the right part number
  15. Mar 26, 2025 at 2:23 PM
    #285
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Here is a picture of the actual part from the very first post on this 10 page marathon,I honestly do not understand the confusion :facepalm:
    DontTazeMeBro likes this.
  16. Mar 26, 2025 at 3:00 PM
    #286
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    Welp I’m about to give up. Switch arrived and installed today in my 23 Limited. Only drive and tow modes working.
    remembered I need to be driving per someone else’s post. Went for a drive, put it in 4hi, nothing.
    currently resetting computers via battery disconnect but I doubt it will make a difference.
    Very odd that mine would be any different than other limiteds that have had success. Only thing unique on mine is the factory load leveling air bags
  17. Mar 26, 2025 at 4:12 PM
    #287
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    Just asking to ask - did you try to enable MTS while stopped? while moving?
  18. Mar 26, 2025 at 4:24 PM
    #288
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    Have done both. I’d be curious if someone who has it working could take a picture of the plug in like mine attached? Clearly missing 4 pins, wonder if the others look the same or not.
  19. Mar 26, 2025 at 4:44 PM
    #289
    KMAGS
    KMAGS New Member
    Ken
    STL MO
  20. Mar 26, 2025 at 8:07 PM
    #290
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    I have a 22 platinum hybrid and I also have load leveling air bags on the rear (and avs up front). The switch works for me. As you mentioned, I did have to be in motion in 4hi or 4lo before the mts button would light up (on position, not running lights) and give me the terrain options. I assume you tried it at roadway speeds…is it possible there is a mph minimum? Were you going really slow or 10+mph?
  21. Mar 26, 2025 at 10:30 PM
    #291
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    Interesting. I did find some videos on yt of dealerships showing it in the parking lot and they can activate it while at a stand still (from factory at least).
    there’s a guy on here where it didn’t work at first and then it worked later. Wondering what could have change besides him being at a cruising speed
  22. Mar 27, 2025 at 1:57 PM
    #292
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    I’ve exhausted my options. Have tried about everything. Took the center console apart to make sure the plug is fully seated. Reset ECU via battery disconnect. No luck.
    If anyone wants to take this off my hands, $130, i can ship.
    ziznack likes this.
  23. Mar 27, 2025 at 7:49 PM
    #293
    ESalt206
    ESalt206 25 Limited
    CO
    So.I'm curious what options/pkgs your truck has? Load leveling air, 14in screen, pvm, nonTRD, etc.?
    Mine is a limited with all or most of the tech and air, but not a TRD.
  24. Mar 27, 2025 at 8:55 PM
    #294
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    Yup. Limited, load leveling air, 14in screen.
    standard headlights, no pvm. Kind of a unique spec maybe?
  25. Mar 28, 2025 at 8:23 AM
    #295
    ESalt206
    ESalt206 25 Limited
    CO
    The option package may have something to do with it - that's just speculation on my part.
    Sorry it didn't work for you. I'll be sure to post in the thread if it works for me.
    mikewantsabeer likes this.
  26. Mar 29, 2025 at 7:05 AM
    #296
    DontTazeMeBro
    2022 Platinum MGM
    so I assume your running lights on the switch work at night? (All 4 running lights on thr switch work when lights are on?). When you put the switch into normal drive mode, do your old options still show on the screen (normal, eco, sport/etc)?
    you are basically saying there are no change to drive/tow, but MTS option will never allow itself to be selected (I.e. the light will never stay on when you try to select it)?
    not sure if it matters, my truck has about every option out there aside from TRd Pro specific items and MTS works fine:
    hybrid 4x4
    AVS
    Load leveling/air
    Birds Eye cameras
    Premium headlights
    Premium audio
    Retracting running boards
    Console safe
    Front air dam
    Lane assist/park assist
    Adaptive cruise control
    Automatic bed step
    Auto bed lowering
    Odd that some feature or mix of features wouldn’t allow it to work for you.
  27. Mar 29, 2025 at 7:31 AM
    #297
    mikewantsabeer
    Pacific County, WA
    2023 Tundra Limited
    No it acts the same as my original unit with drive and tow modes. Acts as if the MTS button and crawl button aren’t even there. Original and tow drive modes light up on switch and dash when selected. When I click MTS it just stays in drive or tow.
    I don’t have the digital dash, my truck is fairly bare bones. I’m wondering if it’s something with canbus with the premium headlights or dashes, but some SR5s have reported it working
  28. Mar 30, 2025 at 7:52 PM
    #298
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    I wonder if the PVM is the deciding factor here. It’s the one thing the SR5 had that it did work on, and the one thing the limited didn’t have that it didn’t work on.
  29. Mar 30, 2025 at 7:56 PM
    #299
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    I don't want to be a monkey wrench, but my SR5 does not have PVM and I can confirm it works for me.
    ElJefe77[QUOTED] likes this.
  30. Mar 30, 2025 at 8:13 PM
    #300
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    I stand corrected! This doesn’t make sense to me. I’m tempted to try it.
    60centenergy[QUOTED] likes this.
