2004 DC Big Job - TB, Front End, Steering Rack, Everything Else. Seeking Opinions & Commentary!
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Mar 20, 2025.
  1. Mar 20, 2025 at 7:42 PM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Getting ready to do "the big job." Finally going to bite the bullet and do what I've been putting off for a looong time. Need to maximize caster on the driver side due to a collision a few years ago that bent my front sub-frame rearward forcing negative caster even with maximized alignment. Also gotta do timing belt, refresh everything else in the engine if possible. The truck will be torn down for at least a few weeks if not longer since this will take me a while, fully intending on not having it in driving-shape for a longish time. I've never done any timing belt/rad/fan/AC stuff before but am confident I can do the job, I just don't know what I don't know or what I'm missing.
    The below is the parts list I've compiled for now. Blanks are parts that I haven't figured out the part numbers for. I'm hoping this will be useful for all of the forum too.
    Do you guys see anything I'm missing? Got anything wrong? Any advice on what I also might need to change? Like do I need to replace the AC Compressor or Power Steering Pump?
    Updated parts list:
    G_unit3000 and FirstGenVol like this.
  2. Mar 20, 2025 at 10:53 PM
    DarkMint
    Ben
    Everything will be coming from Rockauto, amayama, toyotapartsdeal, and 1stgenoffroad, no fleabay or scamazon.
    Hit me with criticism too fellas
    Edit: no toyotapartsdeal, bad reviews led me away
    Also ordered:
    - new cam bolts set from Bison Off Road.
    - a lot more stuff in the list from the dealer than expected since I couldn't find it on amayama/rockauto
    - new torque wrench that goes high enough for wheel castle nut and steering rack
  3. Mar 21, 2025 at 3:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I’ll look through this more in depth later, but I wouldn’t replace the compressor or ps pump unless it’s necessary. Mine are both 25 years old with 314k on them. My ps pump has a whine, but that’s it. Still functions. But hey, it’s your money, not mine.
  4. Mar 21, 2025 at 3:56 AM
    bfunke
    bfunke Tundra Curmudgeon
    Have you had a good frame shop look at your damage?
  5. Mar 21, 2025 at 7:29 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I wouldn't replace my AC Compressor or Power Steering pump unless it was needed. I replaced the steering rack, and all the power steering lines on my truck last year, still using the original power steering pump, it still works.
  6. Mar 21, 2025 at 9:52 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I noticed what looked like the return line seeping while under mine on Wednesday. I cleaned it off and will monitor it. Since the return line isn't pressurized, I'm wondering if I could just replace the soft lines with bulk fuel line as the hard lines are not deteriorated. Might try that vs $ on a whole line.
  7. Mar 21, 2025 at 10:19 AM
    kentuckyMarksman
    Worth a shot. Replacing the lines on my truck was not fun...
  8. Mar 21, 2025 at 10:42 AM
    DarkMint
    Ben
    I'll hold off on the PS Pump and AC Compressor then. This is helpful, thank you guys. I just don't want something to fail and have to tear it back down to get to it, but if these are hardy wear items I'm fine with holding off.
  9. Mar 21, 2025 at 10:47 AM
    DarkMint
    Ben
    At the time of the collision with a curb (2 years ago) every single body shop I called in my vicinity said they only take insurance jobs won't take individual jobs, or they'll charge me a fee just to check it out and potentially an exorbitant cost to replace the frame. The diagnosis of the "bent sub-frame" came from a generic auto shop while replacing my LBJ and wheel bearing due to the collision, and there was nothing that shop could do about it.
    I'm unsure if any "good frame shops" exist in Denver anymore, especially with today's consumer market of taking on debt and/or trading in a vehicle for the newest shiniest thing. So I decided f it I'll just buy special UCA and LCA that position their joints in a way that adds-in caster...no idea if that will work out though
    G_unit3000 likes this.
  10. Mar 21, 2025 at 10:51 AM
    DarkMint
    Ben
    You wouldn't happen to have the power steering lines part numbers handy, would you?
  11. Mar 21, 2025 at 12:06 PM
    kentuckyMarksman
    DarkMint[QUOTED][OP] likes this.
  12. Mar 21, 2025 at 2:48 PM
    I'm really impressed with your parts list. Tagging this thread for later. I'll need it when I do my timing belt.
    DarkMint[OP] likes this.
  13. Mar 21, 2025 at 2:50 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @DarkMint just offhand I think you need to add throttle body gasket and intake plenum gasket. Looks like you have a fun job ahead...
  14. Mar 21, 2025 at 8:08 PM
    DarkMint
    Ben
    Much appreciated, I'll add em. Oh yeah.. it's "the big one."
  15. Mar 22, 2025 at 5:54 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    Frame repairs are very limited. Toyota does not allow the use of heat repair to the frames.
    CRIB #161 - Collision Damage Repair Precautions: “Heat Repair For Body And Frame Components Is Prohibited.”
    CRIB 193: "Frame Repair Precautions Sectioning of frames is not an approved repair procedure. Sectioning is defined as the partial replacement of components at locations other than an original seam or joint. When a frame is determined to be repairable by the replacement of individual components, installation should be at factory seams or joints and replicate original factory attachment methods with corrosion protection. Since all Toyota and Lexus frames are made from High Strength Steel (HSS); Toyota does not approve of any heating method to stress relieve HSS during the repair process. Overheating HSS degrades the integrity, durability, and corrosion resistance of a frame.
    ‘Cold straightening’, defined as pulling, pushing and hammering, are the only approved methods to stress relieve collision damage. If a frame cannot be restored to original contour and dimensions by cold straightening during the repair process, it should be replaced."
    G_unit3000 and The Black Mamba like this.
  16. Mar 22, 2025 at 7:01 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Your list shows powering steering pump but not the rack. You said yours was leaking. Did mine this past winter. Buy new. Do not buy a rebuilt unit. Not even a Toyota one. Maybe half are decent and the rest leak.
  17. Mar 22, 2025 at 11:36 PM
    DarkMint
    Ben
    I didn't even know heat repair is a thing, but yeah makes sense that it would mess up the heat treat on the steel like with firearms or knives. I just need a slackjawed fella named Jimbo or Joebob to hook it up to a machine and cold-pull it ever so slightly to tweak a section. Since I cannot find one...it's UCA/LCA hacking to get the caster good.
  18. Mar 22, 2025 at 11:37 PM
    DarkMint
    Ben
    Far as I know there are no more NIB Toyota racks being produced, hence my inclusion of the "FR33LANCE FAB" branded rebuilt steering rack. Not looking forward to that part of the job, reading testimony from the other 1st gen members on here who have done that replacement.
    FirstGenVol likes this.
  19. Mar 23, 2025 at 5:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    You can get transmission oil cooler line by the foot at any parts store -- looks just like black rubber fuel line but is rated for oil.
  20. Mar 23, 2025 at 5:16 AM
    tvpierce
    Maine
    Personally, I'd hold off on rebuilding the starter. They rarely fail, and you're not really saving any labor by doing it with the rest of the items on your list. (Unlike say the water pump and timing belt: if you're doing the timing belt, you might as well do the water pump while you're in there because of the rate of failure and the duplicate labor.) An OEM Denso starter can realistically last the life of the vehicle.
  21. Mar 23, 2025 at 5:47 AM
    I’m basically on my third starter at 279k miles. Had to replace the copper contacts at 115k and again at 277k. If you’re pulling the intake, worth the extra15 minutes to remove the starter, pop it open and replace the 2 copper contacts and plunger inside.
  22. Mar 23, 2025 at 10:27 AM
    And wrap all the wiring harnesses with rodent tape.
    There's so much shit I'd do if I had my intake off. I'd probably proactively replace the SAI pump, wrap the wires, change out my driver side knock sensor (if not both), test/potentially re-terminate the knock sensor wires, clean any grounds under there. I suspect I'd spend 3-4 hours longer than necessary doing nothing but just cleaning everything up, with the hole I didn't need to take it apart again for another 20 years.
    Dakillacore and DarkMint[OP] like this.
  23. Mar 24, 2025 at 3:55 AM
    DarkMint
    Ben
    No SAI for me (non-VVTI), getting that rodent tape for sure after seeing you recco it to so many folks, will swap out them knock sensors. Knock sensors: P/N 89615-52010 based on my VIN, gonna get two. Will also check out wiring condition...seen a lot of rodent-chewed wiring on other trucks. I'm good at turning a wrench but unfortunately a total baby when it comes to working with wiring/electronics, definitely a weak point.
    Why the focus mainly on the driver-side knock sensor and not both by default? I'll likely replace both anyway just because I'll have the dang thing exposed but out of curiosity...
  24. Mar 24, 2025 at 6:34 AM
    FYI, Denso makes the knock sensors and last I checked, buying direct from them costs at least 30% less than buying it in Toyota's box. You can lookup the part numbers at www.densoautoparts.com --- just make sure you buy from a legitimate vendor, not scAmazon/fleaBay/WallyMart/etc.
    The only reason I'm mentioning replacing mine, and I'm focused on the driver's side, is because I've been throwing an occasional P0328 'knock sensor circuit high input' (driver's side). If you're not throwing any codes and the sensor tests out to spec per the FSM, I might not be so inclined to touch them.
    I (knock on wood) haven't popped the code in the last 800 miles or so, not since temps warmed up outside. But in totality of ownership (6yrs plus a few months), I've had to clear the code to get out of limp-mode about 2 dozen times (since the first case back in Oct/2022). It happened so infrequently I I wasn't too concerned, but during this year's unusually low temps and snows, I think I popped the code 3x in one month. I notice I only pop the code in the 1st 2-3 minutes of driving, and if I keep the RPMs below 2,000 until the engine is mostly warmed up, no codes. It's super tough to track down, because it's a 2-cycle code, i.e. ECU has to detect high input on the circuit for two consecutive drives to pop the code. And I don't want to pop the lid on the engine to really start debugging, because I'll be too tempted to do other stuff with money I don't have right now considering it's an inconsequential issue. Granted, for all I know, it could be an adjacent sensor (cam position sensor, maybe?) causing the engine to ping once or twice, and it actually is knocking? I dunno, but I'm not hearing any semblance of knock, so I'm inclined to believe wiring/sensor issue.
    I've run a snake cam up under my intake; no signs of rodent activity anywhere. Cold weather exacerbation of symptoms suggests to me either (A) wiring terminal issue, (B) connector for driver's side sensor is not fully seated (or clip broken), and when it's cold, or (C) the sensor itself is internally faulty internally related to heat/contraction.
    But, given I only want to need to go in there once and be one with it, I'd probably replace (at least) the one sensor, consider re-crimping the leads and replacing the connector end, then re-wrapping the wires.
  25. Mar 24, 2025 at 9:38 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I believe there is a "rebuild" kit for the power steering pump. It looks like it's just a bunch of seals, but the part number is 04446-06030.
    Also, there is a screen at the bottom of the PS reservoir that fills up with gunk over time. I purchased a new/used PS reservoir that only had like 40k miles on it, and a crazy amount of gunk came out of the screen. Pics HERE. I'd bet cleaning out that screen at the bottom would free up a lot of flow. I also solved my PS leaks by just replacing the hose clamps.
  26. Apr 14, 2025 at 11:55 PM
    DarkMint
    Ben
    First of the parts rolled in. Starter rebuild kit from Advance Truck Parts called ATP Denso Starter Repair Kit 0.8-2Kw Toyota. SKU 777-606D. I had trouble finding an "official" rebuild kit on the Toyota site since it's not the most clear as to exactly what I'd have ordered, and certainly couldn't find one on Denso's website either.
    @KNABORES does this look like the rebuild parts you've been using?
  27. Apr 15, 2025 at 5:28 AM
    Similar parts, but I orders them ala cart from Toyota. Plunger, copper contacts with new bolts and the gasket.
  28. Apr 15, 2025 at 9:39 AM
    bfunke
    I bought the plunger and contacts from a very old school alternator/starter repair shop and charged me $5 “because copper is so expensive these days.”
    G_unit3000 and Kimosabe like this.
  29. Apr 18, 2025 at 3:06 AM
    DarkMint
    Ben
    I have updated the list in the first post with parts I've added and the retailers I've purchased from. Also, including the parts list here in text and in alphabetical order so it's searchable in case it will help anyone else looking for part numbers.
    Any hyperlinks in there are auto-linked due to the forum. I do not endorse buying your car parts from ScAmazon.
    2nd Gen Beefy Tailgate Driver Clip → 69759-0C050 → Toyota Dealer
    2nd Gen Beefy Tailgate Pass Clip → 69759-0C040 → Toyota Dealer
    2nd Gen Beefy Tailgate Stabilizer Clip → 69749-34010 → Toyota Dealer
    A/T Cooler Hose 2/5 → 90080-44065 - got 90445-17122 as alternative → Amayama
    AC Compressor → Holding off on this one. →
    Aisin Timing Belt Kit (WP, TB, TB idler subassembly 1 & 2)Aisin TKT-021 → RockAuto
    Alternator Brush Replacement Kit → 27370-75060 → Amayama
    Brake bleed → Prestone DOT3 - 32oz flush, 12oz incidental → RockAuto
    Cam Seals (2) → 90311-38065 → Toyota Dealer
    Coil Packs (8)Denso 6731303 → RockAuto
    Coolant Toyota 00272-SLLC2 (5) → 00272-SLLC2 → Toyota Dealer
    Cooler Inlet Hose 1 (2) → 32941-34020 → Toyota Dealer
    Cooler Inlet Pipe 1 → 90080-44038 → Amayama
    Cooler Pipe → 32943-34010 → Amayama
    Copper anti-seize for Solo LCA → Amzon → Amazon
    Crank Front Seal → 90311-A0001 → Toyota Dealer
    Crank Pulley HolderSchley 64300 → Amazon
    Crank Seal Puller → Lisle 58430 Shaft Type Seal Puller → Amazon
    Denso rebuilt alternator → Denso 210-1065 → not purchased
    Denso rebuilt starterDenso 280-0319 → not purchased
    Distilled Water → 10 gallons → grocery store
    ECGS Bushing Replacement → ECGS Bushing/Seal/Tools package → ECGS
    Extended Sway Bar Links → SuspensionMaxx SMX-122270T → 1stgenoffroad
    Fan Clutch → Aisin FCT-18 (FCT-021 discontinued) → RockAuto
    Fan Clutch Bracket → 16371-0F010 (Aisin FBT-002) → RockAuto
    Fan Shroud → Not Needed →
    Figure 8 Oil Filter Gasket → 15692-50020 → Toyota Dealer
    Honda Rodent Tape → Honda Rodent Tape → Honda
    Hydraulic Tensioner (twig n berries) → 13540-50030 (Incl in Aisin TKT-021) → RockAuto
    Idler Pulley Plate (if bent) → 16659-50022 → Amayama
    Intake Manifold Coolant Bypass Front & Rear (4) (https://www.tundras.com/threads/coolant-leak-bypass-pipe-o-ring.81275/#post-2055606) → 16341-50020 → Amayama
    Intake Manifold Coolant Bypass Pipe O-Ring (https://www.tundras.com/threads/coolant-leak-bypass-pipe-o-ring.81275/#post-2055606) → 96761-24019 → Amayama
    Intake Manifold Water Net O-Ring (https://www.tundras.com/threads/coolant-leak-bypass-pipe-o-ring.81275/#post-2055606) → 96761-35035 → Amayama
    Intake Plenum/Manifold Gasket (2) → 17171-50020 → Amayama
    Knock Sensors (2) → 89615-52010 → Toyota Dealer
    LBJ Special Bolts (black) → Spiker(?)
    Loctite 242 for No.1 Idler Pulley → Permatex Blue → RockAuto
    Lower Ball Joint (Left) (04 DC) → 43340-39595 → Toyota Dealer
    Lower Ball Joint (Right) (04 DC) → 43330-39825 → Toyota Dealer
    Lower Radiator Hose Clamp (2) → 90466-41003 → Amayama
    MAF cleaner → Johnsen's 4721 10oz → RockAuto
    Oil Cooler Gasket → 90301-67004 → Amayama
    Oil Cooler Relief Valve Assembly → 15695-50010 → Toyota Dealer
    Oil Filler Gasket → 12196-50010 → Amayama
    Power Steering LinesSUNSONG 3401254 → RockAuto
    Power Steering Pump Rebuild Kit → 04446-06030 → Toyota Dealer
    Radiator → Denso 2210518 → RockAuto
    Radiator Cap → 16401-72090 → Amayama
    Radiator Hose (Lower) → 16572-0F011 → Toyota Dealer
    Radiator Hose (Upper) → 16571-0F031 → Toyota Dealer
    Re-Key 3 Barrel & 3 Keys set (04-06 DC) → 69005-0C040 → Toyota Dealer
    Rubber-safe Lubricant → Dielectric Grease → owned
    Serpentine Belt → Gates HD K060908HD → RockAuto
    Serpentine Belt Idler Pulley → 16604-0F010 (NSK 70SPPV0408DDUL) → RockAuto
    Serpentine Belt Tensioner Pulley & Bracket Assy. (Comes w Tensioner Pulley)16620-0W101 → RockAuto
    Shifter Column Plastic KeeperDorman 14797 → Amazon
    Spark Plug Gaskets (8) → 11193-50010 → Amayama
    Spark Plugs (8) → NGK IFR6B-K → RockAuto
    Special LCA's to adj caster → Solo Lower Control Arms → 1stgenoffroad
    Special UCA's to adj caster → JBA Upper Control Arms → JBA
    Stainless Brake Lines Front & Rear → What to purchase? Wheelers SS lines discont'd
    Starter Brush Holder Assembly → 28140-54380 - ATP Denso Starter Repair Kit instead SKU 777-606D → Advance Truck Parts USA
    Starter Magnetic Switch Plunger → 28235-58380 - ATP Denso Starter Repair Kit instead SKU 777-606D → Advance Truck Parts USA
    Steering Rack → FR33LANCE FAB Steering Rack - rebuilt → FR33LANCE FAB - not yet purchased
    Suspension Lift → Bilstein 5100 w/ 2887 springs → 1stgenoffroad
    Thermostat 90916-03100 → Toyota Dealer
    Thermostat Gasket O-Ring → 16346-50010 → Toyota Dealer
    Throttle Body Gasket → 22271-50042 → Amayama
    Timing Belt Idler Pulleys (2) → ?? Maybe don't need these. I’m too ignorant to know.
    Timing Belt Tensioner Idler Pulley "precoated" Bolt → 13556-50010 → Amayama
    Toyota FIPG → 1282B - Got Toyota 00295-00103 instead → Toyota Dealer
    Upper Radiator Hose Clamp (2) → 90466-41005 → Amayama
    Valve Cover Bolts w/ Washers (18) → 90080-10330 → Toyota Dealer
    Valve Cover Gaskets → 11213-50031 & 11214-50011 → Toyota Dealer
    Valvoline MaxLife ATF → Valvoline MaxLife ATF → Advance Auto Parts
    Water Pump → (Incl in Aisin TKT-021) → RockAuto
    Water Pump Gasket (no FIPG, rectangular part) → 16341-50020, the intake manifold bypass? May need FIPG instead. → Amayama
    Water Pump O-Ring → 96761-35035 → Toyota Dealer
    Hutcheson, tvpierce and Dakillacore like this.
  30. May 20, 2025 at 4:09 PM
    panterahead79
    panterahead79 New Member
    2004 tundra sr5 dual cab 4x4
    Hello can you tell me how you confirmed your LBJ part numbers? My dealer wont confirm the part numbers Just give me a price that would be 500 dollars after tax for both. According to your post they differ from what the Toyota website parts says my numbers are. When I look at the exact fit else where it tells me that my left which they tell me is 43340-39485 is for 2003 or earlier yours says 43340-39595 when i search that at Toyota I don't get a result with that specific part. I'm using my vin number to search I don't want to buy the wrong one and I know I can get them for less than 500 dollars for the set if I know the proper part numbers. We have the same year and model of truck according to your info mines just blue.
    Id appreciate any insight you have. As I need to do LBJ UBJ TRE and WB but none of my info seems to jive up when i go to the different Toyota warehouses compared to toyota.com/parts
