  1. Mar 20, 2025 at 8:55 AM
    Tempting but I'll splurge for Archive Garage when the time is right.
  2. Mar 20, 2025 at 9:04 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Archive Garage sale going on now on springs!
  3. Mar 20, 2025 at 9:31 AM
    Neo
    Neo New Member
    Alabama
    With the loan of my brother's 02 AC, I've been doing tons of fixes and upgrades to make it a decent daily driver for me. He has made very few specific requests. A week or so ago, he asked me to find a replacement for the missing passenger side plug that covers the nut holding the windshield wiper arm to the cowl. I went to one local junkyard, but the wiper arms were long gone. Then I went to the local LKQ because they had a new Gen1 I wanted to check out. There's a $5 cover charge and you have to give them some personal info just to get on the lot. If you've ever been to an LKQ, they usually put their vehicles on several spot welded rims to get them up off the ground. That way you can get parts from underneath the rigs more easily. That wouldn't have been a problem except that we'd had a round of heavy storms roll through and this LKQ has a drainage problem. I had to wade into 4 inches of the sketchiest water and mud that I've seen in a while. :eek2: Fortunately, I was in my Muck boots. Then I had to climb up on a loose wheel and stretch over the hood to get the little cover being careful not to drop it into the engine bay. When I went to check out, the guy at the counter just gave me the part. Guess the cover charge was good enough for him.:) I'd have taken pictures of the lot, but was afraid of dropping my phone in all that muck. I may go back and put a light bead of RTV on each of those plugs so they don't get lost again.
    G_unit3000, Voss, BroHon and 3 others like this.
  4. Mar 20, 2025 at 9:34 AM
    oscardog86
    Southern California
    A small piece like that just goes in my pocket at the LKQ, lol
  5. Mar 20, 2025 at 9:57 AM
    Neo
    Neo New Member
    Alabama
    Monday was the wiper arm plug. Tuesday, it was time to replace the front passenger seat belt buckle. The original was still working, but the button was no longer rebounding.
    The gray ones are NLA and the only color for almost everything plastic for Gen1s is MED OAK. I found a replacement on eBay for $44 through seller "beachtoyota" and it arrived in short order.
    Pulled the seat, replaced the buckle (torqued to 31 ft-lbf), and routed the wire nice and neat underneath.
    The color is a little off, but it matches the driver side that we did about a year ago. This sure beat waiting on the thing to fail!
  6. Mar 20, 2025 at 11:06 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    ...and that's why there is a $5 cover charge
    Tundra2, jerryallday, shifty` and 5 others like this.
  7. Mar 20, 2025 at 11:09 AM
    I need to replace my driver side buckle. It doesn't rebound either.
    Voss likes this.
  8. Mar 20, 2025 at 11:14 AM
    Can the passenger’s be swapped with the driver’s or am I SOL? I have grey as well.
    FirstGenVol and oscardog86 like this.
  9. Mar 20, 2025 at 11:42 AM
    Neo
    Neo New Member
    Alabama
    I can't imagine why not, but EPC-DATA is showing different part numbers.
    LH: 732240 (73230-0C050-E0)
    RH: 732230 (73230-0C040-E0)
  10. Mar 20, 2025 at 11:47 AM
    Do you recall if they looked identical?
  11. Mar 20, 2025 at 12:05 PM
    Dakillacore
    Georgia
    Dude nice job! That job looks daunting.
  12. Mar 20, 2025 at 12:18 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Completed a drain and fill of my AT. Will do another one when I replace all of the cooler hoses in a few weeks. Also changed the rear diff fluid with the highly recommended Lucas 80w90.
    Oh...and I received the gusseted spindles that I can't use....ugh.
  13. Mar 20, 2025 at 12:18 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Thanks! I picked a perfect day, it was almost 70 out with sun, and then today it was snowing :eek:
    Got blessed with the weather and a good outcome.
  14. Mar 20, 2025 at 12:36 PM
    Neo
    Neo New Member
    Alabama
    They look the same from the top. However, I do recall that we had to modify the plug on the one my brother bought last year for the driver side (LH) because the connector didn't quite fit the receptacle on the bottom of that seat. That makes me wonder if he ordered a RH and didn't realize it. It's a pretty simple swap. Give it a try.
  15. Mar 20, 2025 at 12:39 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    neither of my buckles have worked for years. Thinking about going aftermarket.
    “we die like men.”
    Tripleconpanna and G_unit3000 like this.
  16. Mar 20, 2025 at 1:55 PM
    Neo
    Neo New Member
    Alabama
    In the midst of pulling the passenger front seat to replace the seat belt buckle on Tuesday, I suddenly realized there would be no better time to shampoo the carpets. So, I broke out our new Hoover PowerScrub XL and put it to work along with some Folex Instant Carpet Spot Remover.
    (RH BEFORE)
    (RH AFTER)
    (LH BEFORE)
    (LH AFTER)
    Here's the towel I used for spot cleaning and the dirty water tank from the Hoover.
    I ran a full tank of shampoo solution through the Hoover during this operation. The stuff in the dirty tank looks like coffee because that's probably most of what it picked up. :rofl: So, technically I know the carpet is clean-er, but you need the before and after photos to see the improvement. I think 2 more full tanks would have gotten even better results, but I'd had enough. If I ever have to pull the front seats again, I'll probably also pull the center console and repeat the entire process. For now, I'm satisfied that it's LESS yucky. Now I just need some good all-weather mats.
  17. Mar 20, 2025 at 2:01 PM
    Por Que?
  18. Mar 20, 2025 at 2:12 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    They are for the early, small LBJ year Tundras....2000 - 2003 I think. I just had a brain fart when I ordered them. Already placed the order for the correct ones. Gonna bathe in the dollars spent on shipping ....FML. Lesson learned.
  19. Mar 20, 2025 at 2:13 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    You need them for yours...along with the new ATS HD leaf pack I have. I deliver...lol.
  20. Mar 20, 2025 at 3:27 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    Oh look...a box was just dropped off....:bananadance:
  21. Mar 20, 2025 at 5:00 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Got the new KO3s mounted and balanced. No issues. Rides so much better than the previous MTs. My cab is finally smooth and quiet. Got an alignment as well. Had them max out the caster. Couldn’t get total toe and camber exactly where I wanted it but overall it was worthy sacrifice.
    oscardog86, abcinv, BroHon and 7 others like this.
  22. Mar 20, 2025 at 5:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Pretending to make progress... Still not sold on whether it's going to work or not since my truck is a little different than Mamba's, but going to trim the ears on the frame horns this weekend. Should know then.
  23. Mar 20, 2025 at 6:31 PM
    des2mtn
    SW
    Tonto cover
    I'd just buy this for a spanner wrench: https://www.kartek.com/parts/king-s...ng-and-sway-a-way-516-pin-diameter-45315.html
    This is the one I have https://www.tatummotorsports.com/products/2-5-spanner-wrench?variant=44946018992350
    oscardog86, bmf4069, Voss and 2 others like this.
  24. Mar 20, 2025 at 6:37 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Just be careful not to drop a nut and lose it inside the frame box :anonymous:
  25. Mar 20, 2025 at 6:40 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Update: Idle relearned, still sitting around 900 o_O, but she starts like buttah compared to before. I could smell those new OEM gaskets burning in, prob should revisit the 13ftlb torque setting soon.
    I have yet to clamp off the brake booster line, or the PS booster line to see if either of those are a vac leak.
    I forgot to mention what the flywheel looked like considering the condition of the starter... I looked as soon as it sunk in and there was minimal damage, dodged a serious bullet there :rolleyes:
    Best trick I learned during this was to use a 3/16 wide piece of gorilla tape over the lip of my socket to hold the 12mm bolts/nuts for the manifold in the socket while fishing them down in.
    Wobble extension helped for the rear nuts as well.
  26. Mar 20, 2025 at 7:26 PM
    des2mtn
    SW
    Tonto cover
    Your little edit is funny to me because some of the differences 100% have to do with cooling... No trans cooler, no A/C fan, no power steering "cooler", AC drier separate from condenser...
  27. Mar 20, 2025 at 8:12 PM
    I used my needle nose to hold them from the top and drop them in, then to hold them from the side. Those rear nuts suck, especially when you're lifted. I just knelt on the rad support and one hand on the firewall.
  28. Mar 21, 2025 at 3:15 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Yes, which is why (for science) you’ll have to document everything. Your fan, I believe, will be the biggest hurdle. I know that the winch mount must sit flush against the rad support for it to clear the bumper.
    G_unit3000, Voss, 805Tundra and 3 others like this.
  29. Mar 21, 2025 at 4:56 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, It took a bunch of strange unnatural positions to hover over the area for me. Glad there are no photos of it.
  30. Mar 21, 2025 at 8:26 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Fired up the BlueDriver, went live data (RPM) and proceeded to clamp off the brake booster, then PS vac lines. No change, still 900-890 Idle.
    I'm not trippin on it, just curious if it was something simple. Retorqued/checked all the manifold nuts and bolts.
    My honeymoon with this truck still isn't over. Standing there listening to her 297k engine just purrrrrr so nicely made me smile. ;)
