  1. Mar 19, 2025 at 6:12 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    link to magnet? mine always fall out of clips and I hate it too. Thank you! great idea.
  2. Mar 19, 2025 at 6:50 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Picked up DRT mount relocation kit for really cheap off marketplace. Now I need someone to weld it on for me.
    BreyTundy, Mdl, Florida AF and 9 others like this.
  3. Mar 19, 2025 at 7:59 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    No better time than now to make the trek to NM! I know a guy that can get those done for you.
  4. Mar 19, 2025 at 8:00 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Looks much better... :thumbsup:
    1lowlife[QUOTED] and HulkSmurf14 like this.
  5. Mar 19, 2025 at 8:03 PM
    Tripleconpanna
    Magnet is a great idea... my plastic ones crapped out on me probably a few months after install. I called customer service and they advised it was a known issue and sent me the new design, which are metal slide in units but the 'clip' is made of a fairly dense rubber...
    So far, so good... but if the rubber ones fail or end up stretching out, I'll be stealing this idea from you!!! :hattip:
    1lowlife[QUOTED] likes this.
  6. Mar 19, 2025 at 9:38 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    Diode Dynamics SS3 Pro Amber ditch lights and also amber Elite fogs came in yesterday. Got them installed tonight after work.
    Ran the wires to the grommet underneath the drivers floor. I didn't want to cut the firewall grommet yet.
    Currently I have the amber backlights turn on automatically when I turn on the truck. I'll add a switch to them later when I figure out what switch set up I want to go with.
    These are the back lights and drls only.
  7. Mar 20, 2025 at 12:44 AM
    jspec rsx
    jspec rsx New Member
    Nice wheels, Dustin @ FNWheels is pleasure to deal with
  8. Mar 20, 2025 at 2:23 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Sounds like a good plan :thumbsup:
  9. Mar 20, 2025 at 4:35 AM
    Tundra family
    Tundra family New Member
    Like a new truck. :thumbsup:
    TheMuffinMan[QUOTED] and woods like this.
  10. Mar 20, 2025 at 5:33 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    Added Road Active Suspension (heavy duty) to the 2018 Platinum Crewmax (stock suspension).
    Ground to uppermost radius of rear wheel arch = 38.25" (stock) and 39.75" (after), I used the black disc.
    Had my son and son-in-law do it for me. Two beers and 50 minutes including putting up all the tools.
    Velocity72, HulkSmurf14, BR73 and 8 others like this.
  11. Mar 20, 2025 at 5:47 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Coolant drain and fill. At 51k already. Feel better about it now.
    91A96E33-115A-47B4-B1D6-1E432CCD5A95.jpg IMG_4091.jpg IMG_4092.jpg EDE6BD8D-0C53-4624-A822-B81686FDFA56.jpg
  12. Mar 20, 2025 at 5:55 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I ordered coolant, need to order the no-spill funnel next. I'm waiting another month or so for warmer weather to do mine, plan to do the power steering as well.
  13. Mar 20, 2025 at 6:01 AM
    BrandonL812
    Brandon
    If you can, get the rubbery hose like the one i have draining into the homedepot bucket. It slip over the draining port real easy and no need to drop the skid plate. I tried using the 3/16 and 5/16 ID clear hose and they do not fit. The 5/16ID hose was used on the passenger side port. It was loosey goosey. Got it done but it dripped some on the floor, little extra clean up.
    HulkSmurf14, bulldog93 and woods like this.
  14. Mar 20, 2025 at 6:02 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    What was the size of the hose that fit correctly?
  15. Mar 20, 2025 at 6:05 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    So probably get a 1/4" ID hose for the block drain then?
    What size hose fit the radiator drain?
  16. Mar 20, 2025 at 6:46 AM
    BrandonL812
    Brandon
    I’d say 3/16ID if rubbery, will fit fine. I can get the size tonight after work.
    HulkSmurf14 and Gaston[QUOTED] like this.
  17. Mar 20, 2025 at 6:57 AM
    Florida AF
    Logan
    North Florida
    Thinking today is about to be less annoying when staring the truck.... Fingers crossed!
  18. Mar 20, 2025 at 6:59 AM
    BrandonL812
    Brandon
    Bought one of those from eBay through their official store. Had to return it because it would not let me do anything but check and clear codes. Won’t let me access any modules or anything. Hope yours is better.
    Florida AF[QUOTED] likes this.
  19. Mar 20, 2025 at 7:00 AM
    Florida AF
    Logan
    North Florida
    Fingers crossed! I am tired of the hard starts and the forum says it will work... I will post up once its confirmed, or isnt.
  20. Mar 20, 2025 at 8:04 AM
    BrandonL812
    Brandon
    I hope so for you also. I wanted mine to work since you were supposed to be able to change the settings like seat belt chime and what not. Mine must’ve been a defective unit. I did all the updates prior also. Definitely let us know your results. For now i’m back to using techstream on an old laptop.
  21. Mar 20, 2025 at 8:11 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Right on:thumbsup:
    I just did my first coolant flush a few weeks ago at 39k. Maybe a little early but my trucks an '18 and probably was never done before I bought it used Nov. '23 so my guess is that coolant was about 7years old. Definitely a good feeling knowing ya got fresh coolant in there.
  22. Mar 20, 2025 at 8:32 AM
    BrandonL812
    Brandon
    My buddy with a 2016 at 77k needs to do his soon. We’re planning on next Sunday. I read every 5yrs you should do a drain and fill. Im early also but it’s a peace of mind for me.
  23. Mar 20, 2025 at 8:53 AM
    Florida AF
    Logan
    North Florida
    To soon to tell, but I hit clear and started the truck and it was the first time in weeks she fired right up. So it did work and I posted additional menu photos in the other thread.
    I'll do the driving portion later.
  24. Mar 20, 2025 at 8:53 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Finally remembered to take pic for you of lower mount area of Dirt King coilover. Ground it back just a little and put some cheap black spray paint over the raw metal after.
  25. Mar 20, 2025 at 9:44 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    I did mine last summer (almost 6 years) and about 36K miles and I don't think it was early. It's cheap insurance and pretty easy to do.
  26. Mar 20, 2025 at 11:26 AM
    CaptRussia253
    Ruslan
    Haha
    HulkSmurf14 and STravis[QUOTED] like this.
  27. Mar 20, 2025 at 11:37 AM
    koditten
    Kirk
    Midland of the Mitten
    I have one, too. The learning curve is kind of steep and the instructions are worthless.
    Just spend some time with it and it will start to make sense how it works.
    I haven't used it yet for anything but changing settings, but it does that so far.
  28. Mar 20, 2025 at 11:49 AM
    Florida AF
    Logan
    North Florida
    oohhhh I havent looked at changing settings yet, only cleared the ethanol thing... I will look to see what can be changed.
    koditten[QUOTED] likes this.
  29. Mar 20, 2025 at 12:25 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Got everything moved, rewired and going again changed out the kenwood sub amp for an audiocontrol epic2000 and one of the kenwood 4 channels for a stinger mt600. 20250319_194551.jpg 20250319_194651.jpg 20250319_194714.jpg 20250316_202343.jpg
  30. Mar 20, 2025 at 12:28 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Damn that looks nice. Perfect setup
