General Supercharger Thread
  1. Mar 18, 2025 at 6:54 PM
    ARES35
    ARES35 New member for life
    Mile high
    I've called a few times since I'm local. Couldn't get ahold of anyone, granted I did not leave a voicemail. I'll try again tomorrow, maybe I'll just swing by there.
    bflooks[QUOTED] likes this.
  2. Mar 18, 2025 at 7:07 PM
    bflooks
    bflooks New Member
    Metrowest MA
    It took some calls for me to catch him. Voicemails were definitely the best way, and then email second. They're apparently really busy with builds happening in the shop, so think less e-commerce and more hands-on off road shop. This is based on my discussions with him, anyways. I'll also follow up again if I don't hear from him tomorrow
    HulkSmurf14, reywcms and ARES35 like this.
  3. Mar 18, 2025 at 9:57 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Be patient! Big offroad events happening around the corner... we'll all be super happy very soon!
  4. Mar 19, 2025 at 10:12 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Got more clarification, basically, if your crossmember goes over the driveshaft, it'll fit.
    If your crossmember has a loop that goes under the driveshaft, it won't fit.
  5. Mar 19, 2025 at 10:13 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Interesting
  6. Mar 19, 2025 at 6:44 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The 8AR mod to my tune has solved all my issues! It's like magic!
    I tried to install the upstream O2 and it is in there so tightly with an O2 socket I semi rounded the sensor.
  7. Mar 19, 2025 at 7:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    That's great! My extended starts are gone and starts within 4 seconds, seems stronger too. I still haven't gapped out to .034 but am at .028 right now.
    Those primary O2's can be a bitch!
  8. Mar 19, 2025 at 7:28 PM
    centex
    centex New Member
    Had to use vice grips and a hammer to get mine loose.
    e30cabrio[QUOTED] and Mdl like this.
  9. Mar 19, 2025 at 7:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Powersteering fluid and acetone in a 1:1 ratio will loosen those 8itches up nicely!!
    e30cabrio, centex, Mdl and 1 other person like this.
  10. Mar 19, 2025 at 7:50 PM
    centex
    centex New Member
    I’ve always done transmission fluid and acetone. Nothing that stuff can’t loosen up.
  11. Mar 19, 2025 at 7:55 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I haven’t tried the crayon method yet, but you’d think it would work well on a hot ass exhaust.
    e30cabrio and HulkSmurf14 like this.
  12. Mar 20, 2025 at 1:36 AM
    e30cabrio
  13. Mar 20, 2025 at 5:00 AM
    Burdturger
    Burdturger New Member
    Hey supercharger gods. Looking at getting this kit but am a noob to this topic. All that comes with this is the following:
    MAGNUSON SUPERCHARGER TVS1900Head unit with intake gaskets, belt and idler pulley only.
    Just want to know what else I need to install. I know it will require a tune as well. And do I need to be concerned if its for flex/non flex fuel? Thank you.
  14. Mar 20, 2025 at 6:41 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Assuming that’s Nergal’s ad from superchargers online. You’ll need the fit kit to install it. And they can source that for you.
    Burdturger[QUOTED] likes this.
  15. Mar 20, 2025 at 6:52 AM
    Burdturger
    Yes I did reach out to them to inquire about the rest of it, thank you.
    e30cabrio and reywcms[QUOTED] like this.
  16. Mar 20, 2025 at 6:57 AM
    bflooks
    bflooks New Member
    Metrowest MA
  17. Mar 20, 2025 at 8:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio ordered em up and we followed suit afterwards. @Jowett knows the platforms and cross references.
  18. Mar 20, 2025 at 8:15 AM
    e30cabrio
    Welcome to the insane asylum, warning: Through this path madness lies.....
    2 questions, I want the defouler on the upstream & although there is antiseize on the O2 do I also need whatever is in the packet?
  19. Mar 20, 2025 at 8:17 AM
    e30cabrio
    Those are in my truck as we speak.
    bflooks likes this.
  20. Mar 20, 2025 at 8:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Your primary needs to read for closed loop it won't be accurate.
  21. Mar 20, 2025 at 8:18 AM
    bflooks
    bflooks New Member
    Metrowest MA
    my post was updated to ensure your contribution is captured. ;)
    e30cabrio[QUOTED] likes this.
  22. Mar 20, 2025 at 8:19 AM
    e30cabrio
    So the defouler goes on the secondary.
  23. Mar 20, 2025 at 8:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes the secondary. It helps with the p0420 related codes. If in the primary it won't properly read and could be way off for the ecu, inject less/more fuel than needed.
  24. Mar 20, 2025 at 8:35 AM
    e30cabrio
    Downstream is done. Waiting for the Amazon 12 point claw delivery.
    Thanks!
  25. Mar 20, 2025 at 8:39 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Fuck that, go to Calranch and buy a 6-point ratcheting box wrench.
    HulkSmurf14, NatesNightMare and Mdl like this.
  26. Mar 20, 2025 at 8:40 AM
    e30cabrio
    Was that on the driver side? My main issue is the front driveshaft, that fucker is seriously in the way.
    lol
  27. Mar 20, 2025 at 8:43 AM
    e30cabrio
    Didn't occur to me the connector will fit through a 22.
    Trying this.
    Wynnded and Mdl like this.
  28. Mar 20, 2025 at 9:05 AM
    e30cabrio
    Whelp, it's rounder nau.
    lol
    M3Tundra-JK likes this.
  29. Mar 20, 2025 at 9:07 AM
    centex
    centex New Member
    That packet is anti seize and yes, I’d use it to avoid rounding it out next time you need to change it.
  30. Mar 20, 2025 at 9:09 AM
    snivilous
    SW UT
    That's why you need the 6 point open end o_O
    12 points only exist for tight spaces or stupid fasteners
    ZPhilip, HulkSmurf14, Mdl and 2 others like this.
