Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Mar 9, 2025 at 4:03 AM
    #4351
    woods
    woods New Member
    2021 SR5 TRD Sport
    I have a Yukon with the lifter fail engine in it. No issues so far, but heres what the difference between GMC and Toyota is, even if I am negative towards "new toyota" as I call it.
    GMC does NOT have any replacement engines ready, they have NOT done a voluntary recall and it looks like the feds will have to FORCE a fix. This has been going on a couple years before the Toyota stuff started, and it still isn't dealt with. When your GMC goes down, you are in trouble and there isn't backup stock to replace it. The wait is a long long time. At least Toyota has owned it, wether people think the fix is a long term solution or not. We love the Yukon, but I've been really hoping there is some movement here soon before we find out about this failure the hardway.
  2. Mar 10, 2025 at 7:31 AM
    #4352
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Confirming as I have a 24 that was built in Aug of 23'
  3. Mar 10, 2025 at 11:53 AM
    #4353
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Same ... my truck was built 8/26/2023 (Thanks @bobbilly ) yet my previous 16 Plat also had a 08/16 build date (not sure exact day) and was a 2016 Model not 2017 ...so not sure if August is split ?
  4. Mar 10, 2025 at 1:44 PM
    #4354
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    My truck is an 8/22 build date as a 2022 model. Somewhere in there must be the split. I don’t have the final day of the month to help determine the split.
  5. Mar 10, 2025 at 1:51 PM
    #4355
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    I’ll throw a wrench - mine is a 9/22 build and it’s a 2022 MY
  6. Mar 10, 2025 at 9:48 PM
    #4356
    Retroboy1989
    Northern Utah
    There may not be a hard cutover date each year.
    There will be factors, days of inventory, parts supply, model year changes, etc.
    Tundrastruck91 likes this.
  7. Mar 19, 2025 at 2:43 PM
    #4357
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Soooo, looks like failures have completely dried up.
    cartage1 and Tundrastruck91 like this.
  8. Mar 19, 2025 at 2:49 PM
    #4358
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    lol unfortunately not...we just got our 1st engine failure with a production date after Toyota change the block and bearing part #'s. I believe build date is 5/24
  9. Mar 19, 2025 at 3:18 PM
    #4359
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Well that sucks. However, hopefully it slows down significantly for the later builds.
  10. Mar 19, 2025 at 3:28 PM
    #4360
    LionsFan20
    Josh
    24 Tundra
    I sure hope so
  11. Mar 19, 2025 at 3:29 PM
    #4361
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    too close to my build date... :frusty: oh well.
  12. Mar 19, 2025 at 3:43 PM
    #4362
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I don't think we'll ever know the true story with this alleged "manufacturing debris" issue, and when it was actually resolved, if ever.
    It certainly wasn't resolved when Toyota claims, based on the number of failures to engines that were built after the recall dates.
    Not sure why we should trust anything from Toyota, since they also claimed hybrids have "motive power" after their gas engine fails, and that's why they aren't included in the safety recall. We've learned that's demonstrably false.
  13. Mar 19, 2025 at 4:00 PM
    #4363
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    It's definitely a mystery ... I think it's the thermal expansion coefficient of dissimilar metals. Something is causing a dimension change/movement between bearing and crankshaft where that thin film of pressurized oil is not being maintained. But what do I know because I'm just a bud lite drinking armchair observer hoping Toyota solves the issue.
  14. Mar 19, 2025 at 6:07 PM
    #4364
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Mine as well
  15. Mar 19, 2025 at 7:30 PM
    #4365
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    The recall documents (defect information report) clearly state that they continued analyzing parts and investigating the issue until 5/24 and came to the final conclusion about the problem then.
    Whatever the relevant changes they made to the parts or manufacturing, had to be after 5/24 when they had a full picture about the problem at hand. I would think it likely took several months after 5/24 when things were finally corrected.
    https://static.nhtsa.gov/odi/rcl/2024/RMISC-24V381-8150.pdf
  16. Mar 19, 2025 at 7:59 PM
    #4366
    Retroboy1989
    Northern Utah
    Well this is creeping dangerously close to my 9/24 build date
  17. Mar 20, 2025 at 7:08 AM
    #4367
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    What worries me having a 2024 built in August of 2023 is will that be a factor when I trade this in next year?
    2022 and early 2023 will/could get crate engines. Late 2023s and 2024s are not covered under the recall so they raise a big question: If they fail under drive train warranty do they get a short block replacement?
    I wouldn’t want to buy a vehicle in this nebulous circumstance.
    WNY PAT and cartage1 like this.
  18. Mar 20, 2025 at 7:11 AM
    #4368
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    How come you’re trading it in?
  19. Mar 20, 2025 at 7:18 AM
    #4369
    woods
    woods New Member
    2021 SR5 TRD Sport
    cause money sucks
  20. Mar 20, 2025 at 9:23 AM
    #4370
    2wheelsforfun
    Foothills AB Canada
    It is the root of all evil.
  21. Mar 20, 2025 at 11:13 AM
    #4371
    Matt2015Tundra
    2023 1794 CrewMax
    As I understand it, yes, failed engines that aren't covered under the safety recall are only getting short block repairs. Which leaves all of 2023 and most of 2024 trucks potentially at risk for the inferior repair.
    I've maintained for months that Toyota will eventually expand the safety recall to include hybrids and trucks built thru 2024. It seems to be the only fair and legally less risky solution for them. I could be wrong.
    Either way, I think trade-in values of Gen 3 Tundras are going to be adversely affected by this for a long time. Even trucks with full engine swaps will suffer from the stigma of this recall, and other perceived quality and reliability issues.
    Tunrod and cartage1 like this.
  22. Mar 20, 2025 at 11:23 AM
    #4372
    AZBoatHauler
    So.Arizona
    Are we at day 4?
  23. Mar 20, 2025 at 11:29 AM
    #4373
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    definitely a fiasco
  24. Mar 20, 2025 at 12:16 PM
    #4374
    2wheelsforfun
    Foothills AB Canada
    Anyone know if that was a short block or long block?
  25. Mar 20, 2025 at 12:35 PM
    #4375
    Breathing Borla
    Northern Illinois
    I would bet the short block bs is going to see a lot of second failures, just too much to go wrong, parts all over the place, etc.
  26. Mar 20, 2025 at 2:43 PM
    #4376
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    *accordingly….
    FrankG, ElJefe77, wxman91 and 3 others like this.
  27. Mar 21, 2025 at 5:53 AM
    #4377
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    What a shame that this thread still lives on. What’s crystal clear at this point is this: Toyota cares more about pumping out new Tundras, Sequoias and GXs than they do about fixing the problem with the 3.4TT. Toyota is going to have to stack incentives like 0% financing and 35%+ discounts to get buyers like me interested at this point given the low resale and potential headaches of a new truck getting a short block replacement. I’d have to guess the 3.5 gen Tundra will have a redesigned motor. And a guy can dream… but maybe the 5.7 will make a come back as emissions regulations are relaxed. Id buy a 3rd gen with the 5.7 tomorrow if Toyota would sell it to me.
  28. Mar 21, 2025 at 5:55 AM
    #4378
    woods
    woods New Member
    2021 SR5 TRD Sport
    While I agree with a lot of what you said. The reality is this.
    3rd gen is the best selling truck Tundra has EVER made. EVER, hands down not even close. The 2nd/2.5 gen's best years are the 3rd gens worst. They don't care about you not buying their truck. They don't care I won't either.
  29. Mar 21, 2025 at 6:02 AM
    #4379
    Breathing Borla
    Northern Illinois
    too bad, you guys are missing out on an awesome truck.
    but your right woods, toyota is selling a bunch of tundras, they don't care about a few holds outs, neither would you or I if we were running the place.
  30. Mar 21, 2025 at 6:10 AM
    #4380
    WNY PAT
    WNY PAT New Member
    Western New York
    Yep - cheapen the product and slap really high MSRPs on so you can mark it down / incentivize purchases and still make money. It’s the game the domestics have played for years and years with their trucks and SUVs. What’s different about the 3rd gen is that Toyota has had to use rebates and other incentives heavily to move the product. And as the 3rd gen gets longer in the tooth, TFS won’t be able to dump off extra trucks with cheap leases through Ally and other leasing companies like they did in the last couple years of the 2.5 gen.
