Parking Support Brake Malfunction Code
Discussion in 'General Tundra Discussion' started by Rascal, Mar 7, 2022.
  1. Mar 20, 2023 at 12:32 PM
    MaiToyTunCap
    MaiToyTunCap New Member
    Hoa
    Minnesota
    2023 Tundra Capstone
    Bak X4S; Hardwired Dashcam; Carlinkit
    Mine's at the dealership today for this issue. The service rep just called and said they cleared out the code, took it for a test drive and it came back. Now they're keeping it overnight to continue to investigate... SMH
  2. Apr 5, 2023 at 7:02 AM
    MKEtundra3gen
    MKEtundra3gen New Member
    Just got the code this am! In to the dealer tomorrow to find out what’s wrong…
  3. Apr 6, 2023 at 9:24 AM
    MKEtundra3gen
    Turns out it was a bad airflow sensor. Glad to see things breaking after a few weeks of ownership. Part’s on backorder.
  4. Sep 4, 2023 at 3:25 PM
    Rabbit6612
    Rabbit6612 New Member
    2023 Toyota tundra, platinum
    So I just bought a 2023 Toyota tundra platinum I haven’t even made my first payment on the highway. I get the same error message and the truck won’t go past 15 miles an hour. funny thing is is I turned it off and turn it back on. Error messages are gone. I’m glad I took those pictures and just like everyone else I came from ford
  5. Sep 6, 2023 at 11:35 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    The causes seem to be all over the place. My ‘23 with 1500mi popped up this same warning this morning just starting it. Hadnt even moved so I don’t think it’s the parking brake (but I’m gonna try the fix mentioned here tomorrow) Going to also connect my OBD scanner and try and read and reset codes. Leaving on a 3000mi trip soon and don’t want it stuck in the shop. Nor do I want to not have cruise control. Ughh.
    *UPDATE* Loose Gas Cap!! Reset code and all back to norm. Why the heck would they throw that dash warning for an Evap leak? Crazy. (Dealer could tell the average owner anything and then charge them accordingly)
  6. Dec 23, 2023 at 2:20 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Old thread but now happening to mine at 1600 miles. Does this happen for just a variety of reasons or what’s going on?
  7. Mar 30, 2024 at 10:30 AM
    Oakman
    Oakman New Member
    Michigan
    On 1794 , 14K,
    I was driving around 45 mph, and out of nowhere these errors pup up
    -parking support brake malfunction code
    -check engine light
    -Advanced intelligent ultrasonic .... Cruise control doesn't work.
    power still the same, i am taking it tomorrow to the dealers.
  8. Apr 18, 2024 at 8:33 PM
    Ro_2024
    Ro_2024 New Member
    Parking support brake malfunction + check engine errors on tundra 2024 limited trd. At 566 miles. Am I holding the record for the lowest miles ?
    Didn’t know about this thread so did not try the trick with resetting the error just brought it to a dealer. Even the dealer was surprised seeing the error at this mileage. On top of that tailgate open light is always on . apparently tailgate not close enough to shut off the sensor. Coming from Honda Pilot 2010 with 167k miles and with only rear bushings and cabin fan replaced over 13 years. I was afraid that my old pilot would stop in a middle of a fire road in mountains so got tundra and now back driving my pilot.
  9. Apr 19, 2024 at 3:39 AM
    Oakman
    Oakman New Member
    Michigan
    update for the check engine light:
    It turned out to be the coolant thermostat, it was replaced and everything went back to normal. The mechanic said, most of the systems functions overlap and if one thing goes wrong many systems will fail. it’s BMW concept IMHO.
    HLR_NM likes this.
  10. May 13, 2024 at 4:58 PM
    HLR_NM
    HLR_NM New Member
    Harry
    I had the same error when I pulled off my front fascia for a bumper job - I was crestfallen when the fault code threw thinking I ruined my new truck - my Scangauge would clear the fault but it kept coming back as a pending code. :( I thought it had something to do with the grill shutter since I’d been monkeying around with the fascia but I think it might have triggered when I applied the parking brake while still in Reverse.
    Happily the parking brake procedure cleared the code and it hasn’t come back :bananadance:
    estebanoss[QUOTED] likes this.
  11. Jul 12, 2024 at 7:09 AM
    bmwco
    bmwco New Member
    2024 Tundra Limited
  12. Sep 23, 2024 at 10:25 AM
    Meatsicle
    Meatsicle New Member
    Shawn
    2024 Limited I-Force Max
    Brand New
    8900 miles on my 2024 limited. Just got this as my windshield was getting replaced and now it’s stuck in the shop. Going to try the quick fixes.
    Edit: nothing worked. Getting towed to the shop. Shop said to unbolt the parking break to move it.
    Another Edit 9/24/24: turns out when you take the windshield off and the cameras lose connection with the truck it activates a kind of anti theft and/or safety system and locks the emergency parking break. So the glass shop had to pay the $623 for tow and repair/diagnostics. I haven’t heard of this happening before.
  13. Feb 12, 2025 at 4:11 PM
    tweezy
    tweezy New Member
    PA
    2024 Blueprint Tundra 1794
    IMG_1321.jpg IMG_1322.jpg This happened to me yesterday leaving work I have both lights on at every start up now. Appointment for the dealer next week.
    my truck is a 2024 model year with an April order date and June build date. Just shy of 2k miles on the just almost 3 months of from my purchase dates
  14. Feb 18, 2025 at 2:19 PM
    tweezy
    tweezy New Member
    PA
    So leave work and all my codes disappear. I get to the dealer after driving about 200 with both of these codes on.
    They scan the port and it’s a code for leak detected in the gas. They stated the gas cap wasn’t sealed all the way. Cleared the codes and sent me on the way.
    I live on the border of PA / NJ where they pump gas for you they have seen this numerous times the tech said.
    Cleared the codes sent me on my way
  15. Mar 19, 2025 at 1:50 PM
    scarecrow87
    scarecrow87 New Member
    Shane
    Silver 2023 Tundra SR5 TRD
    This happened to me yesterday after I got my windshield replaced. I haven’t attempted the quick fix but I’ll try it when I get home
