Does a double cab bed fit on an access cab frame?
Discussion in '1st Gen Tundras (2000-2006)' started by CocaDonut, Mar 18, 2025.
  1. Mar 18, 2025 at 7:02 PM
    CocaDonut
    CocaDonut [OP] New Member
    Andreas
    2000 base Tundra Access Cab 4wd grey
    So i have a weird question for you guys. I just bought a 1st gen 2000 tundra access cab. I had in mind that those models has 6.5' (78 inches) beds but weirdly enough when i measured mine it was only 74.5 inches... So im wondering if its possible that the bed was changed entirely or did they produce some models with smaller beds?
  2. Mar 18, 2025 at 7:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Mar 18, 2025 at 7:09 PM
    CocaDonut
    Andreas
    My measure is the inside of the bed. What pics would you need more precisely?
  4. Mar 18, 2025 at 7:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Of the truck
    1lowlife likes this.
  5. Mar 18, 2025 at 7:20 PM
    You'll want to read THIS THREAD before you post any other questions (this is answered there, parts interchange, in the 'body types and why it matters' section, IIRC).
    Even if the bolt holes are the same, the beds are totally different dimensions, the tailgate is different, the bedsides are different heights, body lines are different, so it's going to look like shit.
  6. Mar 18, 2025 at 7:30 PM
    CocaDonut
    Andreas
    That's why im confused, because i read the thread and it says access cab is supposed to be a 78 inch bed but my access cab has a 74.5 inch bed...
  7. Mar 18, 2025 at 7:55 PM
    If you shared a pic of the truck we could instantly answer your question
  8. Mar 18, 2025 at 8:06 PM
    The bed wall and tailgate would make up that extra 3.5” is my guess. Dunno what to tell you, I think the numbers in that community mega thread came from what Bubba pulled out of the brochures. I can tell you, if you go to various sites like Edmunds and look up info, it’s wrong there too. Parts vendors like DealTeuck rarely get it right either.
    DC bed is a couple-to-few inches taller, and roughy 1-1.5” shorter than access cab. The tail lights anre wildly different, 50% larger. Tailgate has a very different body line. And regular cab bed is over a foot longer, if memory serves. There were no alternate bed sizes if we exclude stepsides. If you look at a DC bed next to an AC truck, you’ll see the difference. It’s pretty substantial.
    Tundra2 likes this.
  9. Mar 18, 2025 at 9:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Mar 19, 2025 at 4:59 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  11. Mar 19, 2025 at 5:27 AM
    JasonC. likes this.
  12. Mar 19, 2025 at 5:30 AM
    Also worth noting the top of the AC bed is nearly vertical, as the DC cab is rounding forward. The lines are totally fucked. You can really look at the DC and tell they tooled the cab off the front half of the Sequoia, matching the rear cab wall to the shape of the rear Sequoia door (I believe they share doors) to make it look natural.
  13. Mar 19, 2025 at 5:57 AM
    They do not share doors. Otherwise we would have a first gen suburbaqouia
  14. Mar 19, 2025 at 6:01 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If I did, this is the figures I would have posted. What I don't know is if the brochure dimensions for bed length are measured like @CocaDonut did.
  15. Mar 19, 2025 at 6:06 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    It's also not clear where measurements are taken. Does inside mean inside rail to inside rail, bed wall to bed wall, widest point or narrowest point etc. Hence why everyone wans a pic!
  16. Mar 19, 2025 at 6:28 AM
    CocaDonut
    Andreas
  17. Mar 19, 2025 at 6:31 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Looks normal to me.
    KNABORES likes this.
  18. Mar 19, 2025 at 6:32 AM
    CocaDonut
    Andreas
    That's what i thought but weirdly enough the measurement inside the bed is 74.5" inches. Unless the measurement is supposed to be outside the bed?
  19. Mar 19, 2025 at 6:46 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    That sounds about right, i’ve got a 78” cot that doesnt quite fit with the tailgate closed.
  20. Mar 19, 2025 at 6:49 AM
    Fragman
    Fragman New Member
    Honestly, if I wanted to make one measurement and 'tell the difference'. it would be inside height. The DC is a fair bit taller. This is my DC inside height.
  21. Mar 19, 2025 at 8:40 AM
    Looks normal to me.
    I guess what I'd be doing is measuring the length of the inside box, then from the top edge of the front bulkead to the center-line of a level held to the tailgate, so you get the overall length.
    I suspect what you'll find is, the overall length is within ½" of 78"
  22. Mar 19, 2025 at 7:10 PM
    CocaDonut
    Andreas
    Well, thanks everyone for the replies. Based on everything you said, im assuming it's not a DC bed. I just had it in my mind that the bed was going to be 6.5ft exactly. I guess it just depends on how you take the measurements! Thanks alot everyone
  23. Mar 19, 2025 at 7:16 PM
    They're wildly different beds and body styles, sometimes it helps to see a over/under comparison - pay special attention to the rear tail lights and that area:
    jimf909 and The Black Mamba like this.
  24. Mar 19, 2025 at 7:17 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    The trim I circled in red is an early year access cab exclusive. That is one distinctive characteristic of a OG AC FGT.
    shifty` and jimf909 like this.
