Tailgate Bump Switch
Discussion in '3rd Gen Tundras (2022+)' started by Novotz21, May 6, 2022.
  1. May 17, 2024 at 5:32 AM
    Dunbarington
    Dunbarington 24' TRD PRO
    Def want a video on that bump switch.
  2. Aug 1, 2024 at 6:24 AM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    2024 Lunar Rock SR5 Tundra TRD Sport
    Can you share where you search this information? I've tried looking around but haven't found a link to something like this yet. Just overall think it would be useful to know when I'm trying to figure out what connector is where when doing some mods.
  3. Aug 1, 2024 at 6:33 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    60centenergy[QUOTED] likes this.
  4. Aug 1, 2024 at 6:38 AM
    60centenergy
    Zack
    GVL
    Goobax[QUOTED] likes this.
  5. Aug 13, 2024 at 12:33 PM
    Bucknut
    Bucknut New Member
    84967-AK010 in case you haven't found it yet
  6. Aug 13, 2024 at 1:00 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    No, but thanks! Will see if I can find one available and the plug for the back of that and get it wired up. Hopefully it works
  7. Aug 14, 2024 at 5:11 AM
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
  8. Aug 14, 2024 at 5:11 AM
    Jalzate44
    San Antonio TX
  9. Aug 29, 2024 at 9:33 PM
    minium
    minium New Member
    Bringing this back from the dead again, as this is how long it took for Toyota to come to a resolution............. May 16th to Aug 20th when they called and left me a VM that Toyota approved the harness replacement. It's scheduled for mid September. No clue how extensive that replacement will be.
  10. Sep 2, 2024 at 1:24 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Wait until the 2025 Tundra's come out and get the wire harness and button for passenger side.
  11. Sep 3, 2024 at 4:42 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    I was looking at adding this feature as well. The factory harness part # 82177-0C030, switch # 84945-0C010 and bezel # 81568-0C160. The wire harness does not seem to be a big deal. It's a small harness that powers the bed lights and tail lights but I don't think it would be overly complicated to make it all factory parts
    I should add I assume that’s the factory part # wire harness.. it’s an educated guess based on the TIS pic posted earlier and find a truck with this feature and seeing the part # for that harness vs my harness
  12. Sep 6, 2024 at 7:44 PM
    LionsFan20
    Josh
    24 Tundra
    Well I can confirm the 3 parts numbers I listed above are what is needed for this to work. I installed in my truck today. Looks perfect like it came from the factory with it, wire harness clips in all the same places. Note this is for truck without bed lights or the electric fuel door.
  13. Sep 7, 2024 at 3:38 AM
    Tundra341
    Tundra341 New Member
    Was anyone successful in adding a switch to the passenger tail light when there's already one on the drivers side?
  14. Sep 8, 2024 at 7:18 PM
    LB-1889
    LB-1889 New Member
    I think it is doable…when I added the switch to my driver side I checked it on passenger side first. The trim piece the switch goes through would need to be drilled/cut and opened up for the switch, they are not able to switch the trim from one side to the other (they are not symmetrical). Then you would have to do the wire harness to splice into the existing DS bump switch. All seems doable but at $150ish decided not to pursue it.
  15. Dec 10, 2024 at 12:10 PM
    machd08
    machd08 New Member
    CLARENCE
    I added the switch and used the trim piece from drivers side on the passenger side, there is some engineering that you have to do, Trimming the trim piece, adding spacer on the bottom screw and double sided tape. I tried to cut the passenger side trim piece, but it looked like shit, so waiting for aftermarket or a OEM one that is specific to the passenger side.
    First picture is mine, the rest are from a guy who did it and shared it on Facebook.
    I am now waiting on Garrick Vanderbilt to make a harness that will connect both buttons to the module.
    Tundrastruck91 likes this.
  16. Dec 11, 2024 at 7:29 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Cool idea for those that would find this useful.
  17. Mar 16, 2025 at 12:00 PM
    jeromy6
    jeromy6 New Member
    I would like to add this switch, but I can't find any information on the harness listed above. I just want to double check that the factory part number listed in the prior post - harness part # 82177-0C030 is a plug and play like what is used in the video in this thread. Just want to confirm before I order everything from the dealer.
    Thanks for your help.
    Does it look like this:
    https://yotaxpedition.com/products/taillight-button-harness-tundra-2022-2024
  18. Mar 16, 2025 at 5:38 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    You can order the complete kit from them.
    https://yotaxpedition.com/products/tail-gate-bump-switch-tundra-2022-2024
    mrfreeman likes this.
  19. Mar 16, 2025 at 5:43 PM
    LionsFan20
    Josh
    24 Tundra
    It’s there…listed as 82177A in the pic. The pic however is generic, this harness # DOES NOT go along the bed rail like shown
  20. Mar 17, 2025 at 5:10 AM
    #50
    jeromy6
    jeromy6 New Member
  21. Mar 17, 2025 at 5:20 AM
    #51
    jeromy6
    jeromy6 New Member
    Thanks, I have to stop by the dealer today to pick up door seals (the front and rear seals that don't come standard on the SR5 and below), so I'm going to talk to them about the harness. Every time I place an order they tell the parts won't fit my vehicle based on the VIN because it is a 2025 - most of there listings are from 2022-2024, but they are the same. I had this issue with the black lugs and TRD center caps. The lugs are for 2021 and below and the caps are for the Tacoma, because of this site I knew everything would work just fine.
