  1. Mar 15, 2025 at 8:32 AM
    #9031
    Daedalus
    Daedalus New Member
  2. Mar 15, 2025 at 8:38 AM
    #9032
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    Looks good! Really diggin that grill and bumper combo
    PapaDave418[QUOTED] likes this.
  3. Mar 15, 2025 at 9:07 AM
    #9033
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Daedalus[QUOTED] and TRD_84 like this.
  4. Mar 15, 2025 at 9:17 AM
    #9034
    TRD_84
    TRD_84 New Member
    Chad
    Ohio
    2024 Lunar Rock Tundra Limited TRD Off-Road
    Rough Country Vertex 2.5 Leveling Coilovers 1” Cornfed rear spacer 275/65r20 Nitto Terra Grappler G3 WeatherTech Alloy Tonneau Cover Body Armor 4x4 Power Running Boards Bedrug Classic Bed Mat XPEL Prime XR ceramic window tint BeatSonic Amp (Non JBL system) TRD Puddle Lights from MVPAutoSupplies TRD air filters TufSkinz Foam Console Inserts Spigen Screen Protector TRD Pro Grille Swap w/ OEM marker lights TRD Dual Exhaust tips TRD Pro Camo rear bumper and front fog lights cover TRD Pro glovebox trim swap Matte Black interior vent overlays
  5. Mar 15, 2025 at 9:24 AM
    #9035
    Daedalus
    Daedalus New Member
    will let you know. I’m heading to get lunch shortly.
    BlackNBlu and TRD_84[QUOTED] like this.
  6. Mar 15, 2025 at 2:20 PM
    #9036
    CAPT_Squatchy86
    CAPT_Squatchy86 New Member
    2024 TRD ORCM Lunar Rock
    Do you still have the OEM tires equipped? If so, mine were the same. I had my tires rotated a couple of months ago. The rear were at 2/32's and front tires were at 8/32's, I'm only at 13k miles, give or take.
    My Tacoma was the same way with the OEM tires. I’d say it’s just my driving, but when I switched tires on my previous truck, I put 50k miles on them, and they wore evenly the entire time. They were at 10/32's when I traded it in.
    VCheng[QUOTED] likes this.
  7. Mar 15, 2025 at 2:29 PM
    #9037
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Yes, I am still on the OEM tires, and frankly I am not impressed with them. I will probably go to a different brand and perhaps upsize a little for the next set, whever it might happen to be. I do have a matching spare that I included in the rotation, so the total life of the OEM set might be a little longer than I would like.
    Edit:
    Tread depth at 8,800 miles OEM tires:
    New: 8 mm.
    Rears: 6 mm. Projected life without rotation: 26,500 miles approx.
    Fronts: 7 mm. Projected life: without rotation: 56,000 miles approx.
  8. Mar 15, 2025 at 3:07 PM
    #9038
    az 3rdGen
    Arizona
    how was the drive to lunch? lol
  9. Mar 15, 2025 at 3:25 PM
    #9039
    Daedalus
    Daedalus New Member
    Initial driving impression.
    nailed the 1/4 wave. Shocked at how quiet it is at light throttle cruising.
    But man, when you step on it the thing comes alive.
    Getting serious GTR vibes out the back.
    az 3rdGen and TRD_84 like this.
  10. Mar 15, 2025 at 3:58 PM
    #9040
    lapoolboy
    lapoolboy New Member
    Installed MillerCat v2 stainless cat shields.
  11. Mar 15, 2025 at 4:02 PM
    #9041
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    those looks good!
  12. Mar 15, 2025 at 4:22 PM
    #9042
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    Theft or rock protection!? Looks burly!
  13. Mar 15, 2025 at 4:30 PM
    #9043
    lapoolboy
    Little of both! They are precision-machined and fit perfectly. Stainless everything including backer nuts and hardware. Very pleased.
  14. Mar 15, 2025 at 5:13 PM
    #9044
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    These seem very reasonable for stainless… I think they are going on the list. Do they just bolt up to existing threaded holes on the truck? On my 2008 I had to install rivnuts.
  15. Mar 15, 2025 at 5:16 PM
    #9045
    lapoolboy
    Yes, existing threaded holes and backer nuts are used. No rivnuts. Less than 30 min install.
    akira, ngoshawk and ElJefe77[QUOTED] like this.
  16. Mar 15, 2025 at 6:32 PM
    #9046
    ngoshawk
    ngoshawk New Member
    2025 Tundra Platinum 6.5' bed
    Rough Country wheel liners, mud flaps, TufSkinz gloss black tailgate lettering, JDMCAR console organizer. That’s it.
    If you don’t mind, please; what was your decision to go with the stainless steel over the aluminum? Knowing the higher cost, was there a decision to go that way?
    Thanks,
    Cheers.
  17. Mar 15, 2025 at 6:36 PM
    #9047
    lapoolboy
    Harder to cut and will always look nice.
    ngoshawk[QUOTED] and Mr Rick like this.
  18. Mar 15, 2025 at 7:52 PM
    #9048
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    Looks great! Should definitely hold up to trail abuse and tweakers!
    SDtrueblue and ngoshawk like this.
  19. Mar 16, 2025 at 5:35 AM
    #9049
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    That bumper is awesome - I need something like this for our 1000’s of deer out here…..LOL
    Couple questions, tell us about the install, how long did it take and level of difficultly? Look like you have a lift but does this bumper require any modification to the front suspension due to weight, I think it is around 250lbs right?
    Thanks
  20. Mar 16, 2025 at 5:53 AM
    #9050
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
  21. Mar 16, 2025 at 7:15 AM
    #9051
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    It has taken longer than I expected. Ironman’s instructions are a video and it is lacking to be sure. They don’t really tell you which hardware and such for each step along the way. I had a CBI stealth bumper that I had to take off and that ended up being a chore with a couple bolts, then my winch that fit with that bumper does not with the new one; the winch head is too big. So I had to relocate the head but given the shape of it, it’s still kinda huge. So I used a project box and moved the electronics into it and mounted above the side intakes as pictured. Then I made fog light mounts in the center as the fogs are too wide for the side wings which was my original plan. Then waited for my Strands cubes to come in. I’ve been working a lot this week and weekend, so all this got stretched over a couple days and I should finish soon. But I would say 8 hours or so. It lowered the front by about .05-0.75 inches or so, and no you don’t need a lift.
    But the bull bars are huge which to me gives it a great look and protection for the trail or road. Deer are stupid.
    Winch head relocation and re-boxing
    Winch head hard mount and access perspective with the grille on and hood open
    RatPanda, cody.tx and SnowToy like this.
  22. Mar 16, 2025 at 7:37 AM
    #9052
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Thanks you the answers, gotta think about this. :)
  23. Mar 16, 2025 at 11:56 AM
    #9053
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    What winch are you using ? I'm down to the Ironman or the ARB......I know on the 200 my winch install was a lot longer then the shop expected....but the result was worth it, and it held up really well over time.
    E
    PapaDave418 likes this.
  24. Mar 16, 2025 at 12:31 PM
    #9054
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I have the Harbor freight badlands 12k winch which has been great. I’ve used it a bunch. It comes with a master battery switch and relocation kit which is great, it’s just the shape of the head that proved to be challenging.
    I like ARB’s new tundra bumper but it was $2495 w/o the option of a bull bar or grille protection, that’s what I need.
  25. Mar 16, 2025 at 1:09 PM
    #9055
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Installed new mud flaps from Amazon on my new 1794.
    Wider than factory by about 2” (I have a spare set of rears from my old truck) they look good, drivers rear seems just a little misaligned, but all others look great. May just need a little adjustment on the one.
    These ones:
    https://a.co/d/0s4jOem
  26. Mar 16, 2025 at 1:16 PM
    #9056
    Jcallip
    Jcallip New Member
    Jeff
    2025 Limited
    I added a garmin cam today.
  27. Mar 16, 2025 at 2:07 PM
    #9057
    twoody1204
    twoody1204 New Member
    Tom
    2025 Limited TRD
    Leveling kit and 295 tires
    Ipaddick and SnowToy like this.
  28. Mar 16, 2025 at 4:13 PM
    #9058
    ngoshawk
    ngoshawk New Member
    Thanks. $100 extra is a small price to pay for security and longevity.
    Cheers.
  29. Mar 16, 2025 at 5:23 PM
    #9059
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
  30. Mar 16, 2025 at 5:24 PM
    #9060
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Installed Rago bed stiffeners. Recently put on a Leer 100XR shell and these are cheap insurance for the composite bed.
    Hummer, 2020Platinum, Yota802 and 2 others like this.
