General Supercharger Thread
  1. Mar 14, 2025 at 6:38 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Good to know. I was looking at one at some point. You think the LRA model will have the same issue?
  2. Mar 15, 2025 at 3:54 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I dived deeper, so pre 2016 that cross member is the same between small tank and big tank, around mid year in 2016 they switched to new cross member, new cross member will require a lot of hammering to make it fit, I really wanted it to fit but at that point it's not worth the work.
    LRA couldn't tell me, one of the reason I went with transfer flow was because they are willing to sell it and ship it to me directly, LRA required me to go to their retailer to buy and install, the nearest one is 500km away from me so that wasn't going to work, I do have to say Transfer Flow has been pleasant to deal with, just really wish it worked.
  3. Mar 15, 2025 at 6:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Is that cross member bolted in? Or? Couldn’t you revert to the other style cross member?
    HulkSmurf14 likes this.
  4. Mar 16, 2025 at 7:24 AM
    Downytide
    GTA
    I can't quite tell, there seem to be spot welds and two rivets, the only info I could find was it was switched in mid 2016, but it's not model year specific, the crossmember I have sits far too low for the 46 gallons, so the front end of the tank would literately sit 4inches below the frame rail.
    HulkSmurf14 and Saltyhero13 like this.
  5. Mar 16, 2025 at 2:32 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Would bad O2 sensors cause misfire? All the misfires have occurred on bank 1. Happened today on cylinder 7 with no WOT (which had been the seeming cause previously.
    New sensors should be here tomorrow.
    ARES35 and Mdl like this.
  6. Mar 16, 2025 at 2:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @JustDSM there are 3 of us running the Lexus 8arfts coils. Would you be able to do one more base tune with the new dwell in background?
    @e30cabrio still using these coils? This remedied my non-cel misfires and extended starts. It's worth a shot and greatly increases spark. You should have your base read trd tune or @snivilous.
  7. Mar 16, 2025 at 2:51 PM
    e30cabrio
    Yup, I have a new set I just put in, I'm still randomly getting misfires, today just driving through a parking lot at almost no throttle it threw 307, first time it has happened without over 9lbs.
    @snivilous can you add the info Mdl is referring to, to my tune?
    ARES35 likes this.
  8. Mar 16, 2025 at 3:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @JustDSM has to do the new dwell parameters in the background base hpt file.
    snivilous[OP], ARES35 and reywcms like this.
  9. Mar 16, 2025 at 3:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Whelp after a bunch of tinkering the rigs running. Hard to believe a fresh set of plugs and it fired right up. Next up trans and headers
  10. Mar 16, 2025 at 3:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I can also tell the dwell update just at blipping and firing it up makes a difference
  11. Mar 16, 2025 at 4:55 PM
    e30cabrio
    I didn't know, @JustDSM can I send you my current file?
  12. Mar 16, 2025 at 4:56 PM
    e30cabrio
    How many suns you got there? :p
  13. Mar 16, 2025 at 4:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Not enough lol
    Mdl and e30cabrio[QUOTED] like this.
  14. Mar 16, 2025 at 5:00 PM
    Saltyhero13
    That was the issue I had but on bank 2. O2 sensor was the culprit. Forum 1 : Mechanic 0
  15. Mar 16, 2025 at 5:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's the base TRD file when you first read it with hpt.
  16. Mar 16, 2025 at 5:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! It does and although I wanted to use the 880cc injectors and will return (Jesse is a great help!). My extended starts haven't happened in over a week. Hopefully with warmer weather it stays that way.
  17. Mar 16, 2025 at 6:41 PM
    e30cabrio
    So can Sniv do it for me?
    Mdl[QUOTED] likes this.
  18. Mar 16, 2025 at 7:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No, we dont have the file write capability. @JustDSM needs the original file to write a background spark dwell increase onto hpt for the 8arfts coils. Snivilous will copy your current file onto the new dwell base file.
    e30cabrio[QUOTED] and Wynnded like this.
  19. Mar 16, 2025 at 7:27 PM
    e30cabrio
    I don't have an original read for the current ecm I have. I forgot to read it before I had it tuned.
  20. Mar 16, 2025 at 7:29 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    HPT will download the stock file if you read the truck. It doesn't matter if it's tuned or not
    Wynnded, Mdl and e30cabrio like this.
  21. Mar 16, 2025 at 7:40 PM
    e30cabrio
    I have a read from when the ecu stopped letting me write to it.
  22. Mar 16, 2025 at 8:20 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I can send you the stock file in the morning
  23. Mar 16, 2025 at 8:21 PM
    JustDSM
    JustDSM New Member
    Justin
    I only need the Cal ID and VIN to generate a file. I generally ask for the OE file just because it contains that information, and I don't have to worry about an incorrectly typed VIN (I can copy/paste it from the file).
    I want to help you guys out, but please be mindful that this does take time. If you're not on the latest Cal ID for your particular ECU, there is a cost involved for me to generate these.
    If you need an 8AR Coil Dwell modified file, please PM me, and we can work it out.
  24. Mar 17, 2025 at 12:34 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    We really appreciate what your able to do with your knowledge of the programs/tuning. I also apologize if I overstepped in the tuning for the coils.
  25. Mar 17, 2025 at 6:44 AM
    e30cabrio
    Is this what I need? I got it from what I think is the right read.
  26. Mar 17, 2025 at 8:03 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Just heard from Johnny @Cruisers & Co.
    Summary: He may not have notifications turned on so he wasn't aware we've been talking about him. He hasn't heard anything but expects them to start shipping any day. He will have an update from Wholesale later today and expects to be receiving emails/tracking information from them so he can ensure we're all getting notified when things do ship.
  27. Mar 17, 2025 at 8:26 AM
    JustDSM
    JustDSM New Member
    Justin
    You’re good! If the whole forum started swapping coils, you could see that getting out of hand. That’s more or less what I was referring too.
    No bounds have been overstepped :)
  28. Mar 17, 2025 at 9:19 AM
    helidave
    flagstaff
    2015 DC 4x4
    Maybe I missed it before, but how come you can't hook HPT up to the truck and use "read vehicle"?
    HulkSmurf14 and Wynnded like this.
  29. Mar 17, 2025 at 10:44 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    You gonna be at Jambo this year since OTT is the title sponsor?
    M3Tundra-JK and HulkSmurf14 like this.
  30. Mar 17, 2025 at 11:17 AM
    e30cabrio
    Thank you so much for the file!!!!
    Read is greyed out :( I got the ID from step one on write
    Mdl and HulkSmurf14 like this.
