'05 Tundra - 210k miles - Smart buy? (newbie looking for help)
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Feb 2, 2020.
Buy or Pass?
  1. Buy
    89.0%
  2. Pass
    11.0%
  1. Mar 10, 2025 at 7:46 AM
    #241
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
  2. Mar 10, 2025 at 11:49 AM
    #242
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    @thefish712...
    Thankfully 95% of the above queries are solved [somewhat] in the Tundra FieldServiceManual [great illustrations], which is linked via @Shifty in his 'so you wanna buy a FGTundra`...[search "FSM" in that thread]. The other 5% likely fr/the brain trust here.
    The most valuable info iv found here is LBJs, TBelts, Trans maint... and always TRY to buy Toyota built parts...
    The FSM is comprehensive, searchable and printable [caution: near 5000 pgs] depending on your PDF reader.
    BTW: Thx for the tour of your FGT...you might b pleased to hear, near 4yrs after your acquisition, i paid near $10k for mine last MemorialDay...theyre not depreciating...
    and not yet repainted, but iv got near $4000 in suspension, TB, cooling, tires, body parts... all Toy or Denso... I pulld a 5000#+ boat/trailer few times already and feels as secure as the Ram2500 i used a halfdozen times..
    I shoulda replaced my '01 Taco 5 yrs bk...
    thefish712[OP] likes this.
  3. Mar 10, 2025 at 12:22 PM
    #243
    thefish712
    Fish
    Ha! Yes, I do love to hear that.
    And double yes, the help here has been immense. Learning so much and saving wayyy mucho time/headache
  4. Mar 10, 2025 at 12:29 PM
    #244
    thefish712
    Fish
    When it comes to regreasing the zerks, should I be popping the zerk open after pumping grease in and hopping up and down on the rear of the truck for each and every zerk point (sorry if that's not what they're called)? I know I've got to do it for the rear yokes, but what about the other 6 points?
  5. Mar 10, 2025 at 1:38 PM
    #245
    I’m questioning wether I’ve ever greased this one :anonymous:
  6. Mar 10, 2025 at 4:34 PM
    #246
    thefish712
    Fish
    Ran it for 20+ minutes, cap off. Didn't see too much water moving, but maybe it's hard to tell? It was definitely hot. Had heater on full blast as well
  7. Mar 10, 2025 at 6:41 PM
    #247
    Only the slip yoke.
    The others, grease should squeeze out from just under each cap of the u-joint. Wish I had a link to that ChrisFix u-joint video. Greatly dislike the guy, but it's great for newbs.
  8. Mar 10, 2025 at 9:23 PM
    #248
    thefish712
    Fish
    Yeah, that'd be great. But alas, it sounds like it's lost.
    Is it possible to overfill? And how do I avoid that?
  9. Mar 11, 2025 at 6:24 AM
    #249
    I had a hell of a time trying to find a video that shows the process of a standard u-joint. But essentially, you're doing four things every time:
    1. CLEAN the zerk, wiping off thoroughly with a shopcloth is ample. You don't want to force dirt into the joint
    2. Gun should be loaded with a good moly-fortified grease like Palladium #2 or similar ... Before greasing your first joint, always test 6-8 pumps to ensure grease is coming out; airlocks can happen, where nothing will pump out of your gun, YouTube can help with solving that
    3. Then lock on the zerk and start pumping, the grease should disappear into the joint
    4. With every zerk except the slip yoke (#B in your picture), continue pumping until you see grease exiting around the perimeter/base of the 4 round caps** then wipe up all the excess grease so it doesn't sling all over everything, including yoru exhaust, which may stink later
    ** You should be greasing roughly every oil change; If you haven't greased in 10k+ miles, I'd continue pumping until you see new grease coming out of the base of the caps. Otherwise, pumping until you see about a teaspoon or so of fresh grease is genuinely enough.
    1st video shows general process. See the 2nd video here on how a U-joint works, so you understand what's happening inside the joint when you do this.
  10. Mar 11, 2025 at 9:42 PM
    #250
    thefish712
    Fish
    Thanks for sending all of this. Again, very helpful. It was raining today so hopefully tomorrow I can get some time back under the truck. We SoCal guys melt in the rain...
  11. Mar 13, 2025 at 1:16 PM
    #251
    thefish712
    Fish
    Update time: still working on the coolant! Classic, getting a 2 hour job done in 10 hours lol tbf, rain has been a killer.
    I flushed out the system with hose water, then drained it. Still pretty green all around. Then filled and refilled with distilled water. Well worth it as it was pretty clear coming out this time. Doing one more fill/drain of distilled water (waiting on engine to cool and rain to hold off), then adding in the fresh 'Yota coolant and burping the system. Surely I will have further questions on burping the air out, but one step at a time
    Thanks again yins for everything!
    shifty` likes this.
  12. Mar 13, 2025 at 1:18 PM
    #252
    If you have one of those easy up canopies, you can make a small shelter over the front of the truck to give you respite from the evil rain while you work. Mini tent of pain
  13. Mar 13, 2025 at 8:12 PM
    #253
    thefish712
    Fish
    Alright, finally finished. Ran the truck for 20ish minutes with the cap off so it should have all the air bubbles out. Think I’m good to go on this job…
    the truck already seems that much happier, I just know it
    shifty` likes this.
  14. Mar 14, 2025 at 11:52 AM
    #254
    thefish712
    Fish
    Greasing these u-joints. Are there 8 different zerks to shoot grease into? I didn't see that many when I initially checked it out, but they could have been hidden
  15. Mar 14, 2025 at 12:40 PM
    #255
    See the picture you posted. There will be a zerk at each of those locations, four at "A", three at "B", and one at "C". If you don't immediately see it, it may be rotated out of sight 180°.
  16. Mar 14, 2025 at 12:44 PM
    #256
    thefish712
    Fish
    Maybe I'm confused by this photo... but it looks like 4 A's in total, spread out along the shaft, then 1 B, and 3 C's in the middle
  17. Mar 14, 2025 at 1:23 PM
    #257
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    TGIF….ABC’s can make ones head hurt !
  18. Mar 15, 2025 at 5:55 PM
    #258
    Yeah I got my Bs and Cs backwards, but I'm moderately dyslexic so it's expected.
    It's like the J5 sang it, A-C-B, it's easy as 2-1-3...
