Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Mar 1, 2025 at 6:18 AM
    #211
    bmf4069 [OP] Captain wtf
    Jake is working on it some today. I'm gonna grab a new belt for Donut and run over there and change it and grab some pics.
  2. Mar 1, 2025 at 7:15 AM
    #212
    Don't forget to loom that wire going down the drive framerail while you're in there! And if you ever wanted to run a backup camera, if you don't have one, now is the time to do it.
  3. Mar 1, 2025 at 5:22 PM
    #213
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Started the day by tacking in a temporary brace, and removing the spare tire carrier.
    Put together a drawing for these frame boxing plates, and cut a pair.
    So many brackets
    The aftermath
    Ready to start going back together.
  4. Mar 1, 2025 at 5:26 PM
    #214
    I’m slow/special, why wouldn’t the oem cross brace work? Or just because beeftown?
  5. Mar 1, 2025 at 5:33 PM
    #215
    JakeJake
    2000 Tundra AC 4X4
    Option 3: Tube is light/strong/sexy.
  6. Mar 1, 2025 at 5:38 PM
    #216
    Heard
    JakeJake[QUOTED] likes this.
  7. Mar 1, 2025 at 7:44 PM
    #217
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Not only is this taking the frame to the next level beef town, but that fitment is fkn level 10. Color me impressed. Nice work Jake.
    I like what you did with the weep holes too, and for northern salties like me, a place to apply rust inhibitor through :thumbsup:
  8. Mar 1, 2025 at 8:18 PM
    #218
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  9. Mar 1, 2025 at 10:33 PM
    #219
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Oh shit. I didn't realize y'all were boxing in the frame.
  10. Mar 4, 2025 at 6:23 PM
    #220
    JakeJake
    2000 Tundra AC 4X4
    Couple of photos to keep this thread on page 1. Entering the home stretch on the major fabrication. Shock mounts in the morning, then Hopefully I can get everything welded out.
  11. Mar 4, 2025 at 6:25 PM
    #221
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So are y'all keeping the leaf packs as is, or planning a bastad pack, or what?
    The u-bolt eliminaters are pretty neat. What advantages do they provide over a u-bolt flip? Less likely to have axle wrap?
  12. Mar 4, 2025 at 8:54 PM
    #222
    Putting in the wheelers AAL.
  13. Mar 4, 2025 at 9:33 PM
    #223
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Smart man! You won't be disappointed.
    I suspect those deaver leafs you gave me would be a bit stiffer. The progressive wheelers AALs are just right IMHO. Not too stiff (like most single AALs) and not too soft (like most other progressive AALs).
    I still need to install those deavers on my Alcans. Hopefully before T2S. But no big deal, if not. She road just fine with the hard topper at HF.
    Just a slight squat. :oops:
  14. Mar 5, 2025 at 5:56 AM
    #224
    JakeJake
    2000 Tundra AC 4X4
    There's several advantages to a u-bolt eliminator:
    Better clamping/control of the spring pack
    Better control of axle wrap-related to the above ^
    Way more beef/weld/size than the oem perch
    uses standard off the shelf bolts-easy to source replacements- easy to impact in and out
    this design allows for wheelbase adjustment + or - 1 inch
    Smooth bottom of the axle tube without anything to hang up on
    opportunity to add lift without springs/blocks etc. I setup Beau's truck using the factory tundra offsets so no added lift on this one, but any tundra leaf will bolt right in at its advertised measurements (+1.5" for his TG progressive AAL for example).
  15. Mar 5, 2025 at 7:05 AM
    #225
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    How do you add lift without spring or blocks? Weld in a thicker base?
  16. Mar 5, 2025 at 7:14 AM
    #226
    JakeJake
    2000 Tundra AC 4X4
    Changing this offset between the axle tube and the spring perch will adjust ride height.
  17. Mar 10, 2025 at 6:43 PM
    #227
    Jake got Ironman all wrapped up today. Holy hell I actually have brakes now. A few pics I grabbed today.
    Truck feels great. Looks amazing under there! I was able to crawl on my hands and knees under there. There's still some work to be done, but it's out of surgery and driving.
    Needs new wheel bearings.
    Needs new brakes.
    Needs parking brakes
    Needs a longer rear brake hose to the axle.
    We're looking at options on the rear bearings. They're easier to do supposedly, but more expensive. Timkens are $160 a piece for just the bearings. Then it needs new retainers, tone rings, c-clips, oil seals, and something else.
    Well give it a shakedown run at Merus when we get some new bearings in it.
  18. Mar 10, 2025 at 6:56 PM
    #228
    Looks beast. Timkens ain’t what the used to be.
  19. Mar 10, 2025 at 7:07 PM
    #229
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So is the rear axle any wider than before?
    I'm jealous of that shock relocation
  20. Mar 10, 2025 at 7:21 PM
    #230
    Beck/arnley or centric are my other choices. About fiddy bucks cheaper though.
    That's with no spacers.
  21. Mar 10, 2025 at 7:35 PM
    #231
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Spacers in front or no?
    Pretty sure they're there in front, but just for clarification.:)
  22. Mar 10, 2025 at 8:01 PM
    #232
    Koyo is OEM for those bearings too. They spendy
    JakeJake and 455h0le_dachshund like this.
  23. Mar 10, 2025 at 8:32 PM
    #233
    Spacers still on in front.
  24. Mar 11, 2025 at 6:53 AM
    #234
    JakeJake
    2000 Tundra AC 4X4
    I have a ton of pictures. Unfortunately most of them are terrible mix of greasy camera lens, bad lighting, and Dale blocking the subject matter. Here's a few of the best of the worst for your viewing pleasure.
    Prop Valve- Plumbed with re-bent and re-flared factory lines
    Rear axle hardline- This is the OEM tundra line re-bent. Mounting provisions added to the axle housing.
    Butta'
    Painted and re-re-reassembled. Out in the sun for the first time in 10 days.
    The tightest of fit between the upper mounts and the bed floor. Not ideal, and not what I was planning for, but the way she goes sometimes.
    My other big oopsie, and biggest regurt on this whole project. Somehow I missed the interference between the new x-brace and one of the bed crossmembers. Should have plasma cut a gusset to reinforce the area that I removed while I had the bed off. Notch is about 1" or 1/3 of the crossmembers original height. Definitely weakened to some degree, but for Beau's intended use it'll be just fine.
    All in this was about 80 hours of work over a 10 day period, and realistically needs another ~10ish in finishing some of the details. Definitely learned a few things, And have a better idea of the process/pricing/nuance of working on someone else's project. Im pooped and the shop is a mess.
    Overall a cool way to get rear discs on a tundra, and Im stoked on the breaking performance.
  25. Mar 11, 2025 at 6:59 AM
    #235
    Looks awesome. He should be ready for GFF and WFF at T2S!
    bmf4069[OP] and JakeJake like this.
  26. Mar 11, 2025 at 7:41 AM
    #236
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Why does it look like the shocks will bottom out before it reaches the bumpstops?
    that smooth shave axle is hawt.
  27. Mar 11, 2025 at 7:47 AM
    #237
    JakeJake
    2000 Tundra AC 4X4
    What bumpstops? :rofl:
    Thats still on the list. The factory bumps will be just about perfect when compressed.
    bmf4069[OP] and Sirfive[QUOTED] like this.
  28. Mar 11, 2025 at 8:01 AM
    #238
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  29. Mar 11, 2025 at 8:14 AM
    #239
    JakeJake
    2000 Tundra AC 4X4
  30. Mar 11, 2025 at 8:38 AM
    #240
