Added MTS/Crawl Control switch to Platinum CrewMax
Discussion in '3rd Gen Tundras (2022+)' started by Tundra_Lover7, Oct 19, 2022.
  1. Mar 6, 2025 at 9:38 AM
    #211
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I removed the side panel, but it didn't help much, I just used a plastic trim tool & pried switch straight up, it popped out easily, just that short wire is a pain to deal with.
  2. Mar 6, 2025 at 9:52 AM
    #212
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Oh, I see. Makes sense (despite some folks saying it can be a pain). I have added the gear shift panel trim cover (to cover the piano black finish) and now my access to the top of the switch assembly is severely limited (without risking damage to that aftermarket cover/sticker). Glad to know it works on the 2024 Limited, maybe one day I will give it a try (when my sticker cover gets damaged and will need to be replaced).
  3. Mar 6, 2025 at 10:06 AM
    #213
    Raven67
    Kentucky
    I have the cover as well, no damage whatsoever.
    MAC25Tundra and Pine_Cone67 like this.
  4. Mar 6, 2025 at 10:15 PM
    #214
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Appreciate the pics and posting your experience.
    Raven67[QUOTED] likes this.
  5. Mar 7, 2025 at 4:55 AM
    #215
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    As we all know you can dig on the web for better pricing on all or any part, but I believe it was $178.
    The computer module was fairly inexpensive too and from what was posted by Virgillus11 they were identically the same exterior wise "but" a 6 & 7 wire on the connecting harnesses is present on those model/trim pkg of trucks that actually has these factory options and have the 2 wires additional obviously.
    He followed these additional wires back to the rear diff. and this is where the project lays, MTS allegedly works based of two people who have posted that it works but the Crawl mode will not and if attempted the dash cluster will light up.
    ziznack[QUOTED] likes this.
  6. Mar 10, 2025 at 12:23 PM
    #216
    DrinksOnMe
    DrinksOnMe New Member
    2024 Silver Tundra Limited 4x4
    Plugged mine in today. Worked for me as well. Limited hybrid 4x4 with PVM. For $175, you can basically handle 95% of trails near me. Sounds like a good deal to me. Assuming the trucks that have 4x4 w/o off-road package sit in the automatic range of the MTS, I don’t see why the MTS wouldn’t work. I noticed a difference just on the loose pavement going around my neighborhood. Can definitely feel a change in acceleration going from snow to dirt. Now to do more research into adding the crawl function .
    Also wanted to add that I just removed it straight out of the center console. Took a minute to plug the new switch in. Not too difficult. No scratches on center console. I have the matte cover as well.
  7. Mar 10, 2025 at 12:45 PM
    #217
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    What do you mean straight out of the dash? As opposed to how?
  8. Mar 10, 2025 at 1:04 PM
    #218
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I'm assuming you have AVS and load Leveling too.
  9. Mar 10, 2025 at 2:02 PM
    #219
    DrinksOnMe
    Thanks for bringing this up. It has been edited. I pulled it straight out the center console. Need to use a plastic wedge tool.
    No AVS and no load leveling equipped. That’s only the platinum option, right?
    Raven67 likes this.
  10. Mar 10, 2025 at 3:49 PM
    #220
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I'm not sure what the Platinum trim offered but the reason I had asked is that from what I read the load leveling isn't compatible with the MTS/Crawl mode.
    For really short money it's worth replacing the switch and the only concern would be the accidental engaging of Crawl mode & have the dash cluster light up.
  11. Mar 10, 2025 at 4:58 PM
    #221
    ziznack
    ziznack New Member
    Texas Y'all
    I think crawl doesn't work with any because you actually have to replace the diff or something. But why wouldn't the AVS and rear air work with MTS?
  12. Mar 10, 2025 at 5:07 PM
    #222
    DrinksOnMe
    I tried to initiate crawl mode and nothing happened. No dash lights, and crawl didn’t light up. Possibly I only need to replace my diff to have all the features. I will most likely do this depending on the cost of the diff. Dealers near me were up charging on the off roads. If I can get it installed for the cost of the off road I will most likely update it if I struggle off road. Assuming the 4x4 limited are essentially the base version of an off road. I’m assuming because of the AVS on the platinums it throws errors. Not sure though.
    Doesn’t make sense for it not to work unless there is something about the AVS and auto level that won’t allow it. Even then I would assume the platinum is essentially in the “Auto” part of MTS. Or the platinums are more advanced and the 4x4 is more intelligent. I say that with a grain of salt.
  13. Mar 11, 2025 at 3:20 AM
    #223
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    There was two Toyota packages that I couldn't add to my trim,one was the 3" lift and secondly was the MTS and Crawl mode.
    Not knowing any better at the time when I made the Toyota plunge so to speak, I didn't ask the salesman as to why but gaining and learning information here I would have to guess that AVS would be the culprit.
    ziznack likes this.
  14. Mar 11, 2025 at 8:48 AM
    #224
    ziznack
    ziznack New Member
    Texas Y'all
    That's a good point. You could not have the AVS and air package with the TRD OR package.
    Blufin[QUOTED] likes this.
  15. Mar 11, 2025 at 6:38 PM
    #225
    The Dutch Man
    The Dutch Man New Member
    Just bought the MTS switch from Fred Anderson on sale for $131.
    How Has everyone removed the switch from the top without pulling panels?
  16. Mar 11, 2025 at 6:51 PM
    #226
    Raven67
    Kentucky
    I used a plastic pry tool, started at the rear & it popped right up.
    Actually used the same pry tool that came with my Auto start defeater. Worked great, no scratches.
    MAC25Tundra likes this.
  17. Mar 11, 2025 at 7:16 PM
    #227
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    Alright, take my money.
    just got one for a 22’ platinum hybrid just to play with
  18. Mar 11, 2025 at 10:06 PM
    #228
    ziznack
    ziznack New Member
    Texas Y'all
    If anyone has AVS and rear air, please let us know if any issues or if it still works.
  19. Mar 12, 2025 at 5:22 AM
    #229
    DontTazeMeBro
    2022 Platinum MGM
    I have both, and will let you know when my switch comes!
    Raven67 and ziznack[QUOTED] like this.
  20. Mar 12, 2025 at 7:28 PM
    #230
    CajunTim
    CajunTim Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    I have both as well and my switch arrived tonight but it’s the one I already have. Gotta call tomorrow to return it.
    ziznack likes this.
  21. Mar 12, 2025 at 9:25 PM
    #231
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Note- You are testing for Crawl in 4Lo correct? (I haven’t seen it mentioned here but it only works in Low range) Also, I’ve not read anywhere that there is a different differential for trucks with Crawl/Hill Decent. I’ve often wondered if there’s actually a different ABS controller or ABS unit since that’s a key part of its function. Overworking it will throw a warning light on the dash for ABS High Temp.
  22. Mar 12, 2025 at 9:51 PM
    #232
    mikewantsabeer
    mikewantsabeer New Member
    Pacific County, WA
    2023 Tundra Limited
    this is more inline with what I know about atrac/crawl. It doesn’t require the use of the locker so I don’t think that’s a limiting factor. My 06 4Runner had ATRAC and DAC and didn’t have anything special, I can’t imagine they’d have a different ABS module.
  23. Mar 18, 2025 at 11:10 AM
    #233
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Did your switch come in? I dont have AVS, but curious to see if the switch works for you guys!
  24. Mar 19, 2025 at 4:54 AM
    #234
    Rookhoe
    Rookhoe New Member
    Binghamton, NY
    2025 Mesquite Toyota Tundra Limited
    I've been lurking in this thread since a few weeks ago. I have a 2025 Limited without the TRD Off-Road package. I'll likely end up buying the switch and doing some testing of my own. I'm not saying that anyone is wrong, but I just find it difficult to accept that the crawl control requires the use of a locker. I had crawl control in an older 4Runner that I owned and it didn't need the locker to work. When researching adding it to my GX460, I don't remember any mention of needing a locker for it to work.
  25. Mar 19, 2025 at 4:59 AM
    #235
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    So far the only known inhibiting factor is AVS nobody knows as of yet what else is preventing it.
  26. Mar 19, 2025 at 7:34 AM
    #236
    ziznack
    ziznack New Member
    Texas Y'all
    I thought we didn't know that yet?
  27. Mar 19, 2025 at 7:52 AM
    #237
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    These are the posts that hit home with this whole mod.
    Post # 121
    127
    128
    130
    101 has AVS & LL
    65 Also is a good read.
    These guys who have pushed the envelope in attempting this mod have gone above and beyond Virgillus11and Tundra_Lover both have AVS Virgillus11 states MTS works but Crawl/DAC is no bueno.
    Still looking for another factor.
    ziznack likes this.
  28. Mar 19, 2025 at 8:00 AM
    #238
    ziznack
    ziznack New Member
    Texas Y'all
    I don't see anything about AVS on 101. Last I saw someone was waiting for the switch to test on AVS.
  29. Mar 19, 2025 at 8:03 AM
    #239
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I'm basing it on his trim and from what I read on his earlier posts.
    ziznack likes this.
  30. Mar 19, 2025 at 8:08 AM
    #240
    ziznack
    ziznack New Member
    Texas Y'all
    Gotcha
