Milwaukee Tools
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 9, 2024.
  1. Mar 8, 2025 at 6:32 PM
    #1651
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Wife is looking at adding this project to my “to do list”. Would I only need the Milwaukee crown stapler (3/8”?) for this?
  2. Mar 8, 2025 at 7:48 PM
    #1652
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Stapler or Brad nailer would work, imo. Those panels aren't going anywhere and won't be pushed/pulled to where I'd see the need for stapler strength.
    T-Rex266[QUOTED][OP] likes this.
  3. Mar 8, 2025 at 7:51 PM
    #1653
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    He's just trying to justify buying another tool for another job.....
  4. Mar 8, 2025 at 7:52 PM
    #1654
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I’ll start this off by saying that I am by no means a professional, but when I do this sort of thing I use a finish nailer and fire the pins at opposing angles. Now the reason I do that is because my buddy, who is a journeyman finish carpenter, got all upset with me when I tried to use a crown stapler one day and chastised me for creating a larger indent to fill later, which didn’t hold as well as the opposing angled pin nails.
  5. Mar 8, 2025 at 8:46 PM
    #1655
    And the wife is on board lol. Taking it while I can
  6. Mar 8, 2025 at 8:47 PM
    #1656
    I can see that. That is great in-sight
  7. Mar 8, 2025 at 8:50 PM
    #1657
    Ghost Rider
    Ian
    Cypress, Texas
    Why not, right?
  8. Mar 8, 2025 at 9:03 PM
    #1658
    Exactly, and knowing her I may need it again. I used my buddy’s Brad nailer for the bathroom remodel a few months ago for scribe…so I should def have my own
  9. Mar 8, 2025 at 9:31 PM
    #1659
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Now you sound like @Blue Thunder :rofl:
  10. Mar 9, 2025 at 4:59 AM
    #1660
    The detail sander from Milwaukee works really well. It also has a decent battery life.
  11. Mar 9, 2025 at 5:02 AM
    #1661
    I would use the 16 gauge finish nailer.
    Toyotoholic and ZappBrannigan like this.
  12. Mar 9, 2025 at 8:27 AM
    #1662
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Listen to Bryan and Zapp. Either a 16ga or 18ga finish nailer.
    Crown staple going through 1/4” of panel plus 1/2” of Sheetrock (plus some texture) only leaves 1/2” of bite into the stud and leaves a bigger hole to fill. And when you are doing the thicker trim boards, you have even less.
  13. Mar 9, 2025 at 8:42 AM
    #1663
    Also makes perfect sense. I will get a nailer for this project. Thank you gents.
    Prostar 190 and ZappBrannigan like this.
  14. Mar 10, 2025 at 6:34 AM
    #1664
    Ghost Rider
    Ian
    Cypress, Texas
  15. Mar 10, 2025 at 11:00 AM
    #1665
    I have the brad nailer (18g) coming.
    For cutting these panels, would this suffice?
    https://www.homedepot.com/p/Milwauk...-Battery-Charger-2630-20-48-59-1850/305900535
    Leo's first likes this.
  16. Mar 10, 2025 at 11:08 AM
    #1666
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
  17. Mar 10, 2025 at 11:10 AM
    #1667
    idk shit about saws and do not have any power ones. So I am depending on you all lol
    OldGuy03 likes this.
  18. Mar 10, 2025 at 11:19 AM
    #1668
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    A track saw would be nice but those are quite a bit more expensive. I don't have the need for one, at least not enough to justify the cost with how infrequent I would use it. And since I can't make a cut as straight as I'd like I use a straight edge that I bought at Home Depot several years ago. It's two 4ft sections that attach with a bar in the middle, I clamp both ends to the piece being cut and run the saw along the edge to get a straight cut. You have to do some trial and error on a scrap piece of wood to know how much to compensate for when measuring for your cut but it's doable. If you use the saw a lot or just have the money to burt get the track saw, otherwise I'd get a circular saw and straight edge.
    As for circular saws themselves, a brushless motor would be better but for light use the one you linked would be fine.
    I have something like this...
    https://www.homedepot.com/p/Empire-...CMBo1J5NYF7lFC1E9hgaAuPBEALw_wcB&gclsrc=aw.ds
    I did drill and tap a couple more holes in the bar to make the two pieces more sturdy
  19. Mar 10, 2025 at 11:24 AM
    #1669
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
  20. Mar 10, 2025 at 11:25 AM
    #1670
    Gaston
    Gaston New Member
    Gary
    SE MI
  21. Mar 10, 2025 at 11:29 AM
    #1671
    ScenicRoute
  22. Mar 10, 2025 at 11:34 AM
    #1672
    TacomaTRD4x402
    Southern California
    Yeah, definitely not for the paneling but it's a great tool to have.
    What do you mean? When I bought the saw I was comparing several other stands and settled on the DeWalt for its portability and ease of setting up. I'm able to easily load/unload from my truck.i believe Bosch has a similar one that someone on here recommended. That was a close 2nd.
  23. Mar 10, 2025 at 11:49 AM
    #1673
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I’ve watched a lot of reviews on mitre saw stands recently (in the market for one myself) and YouTube university tends to agree with you on that one being top dog
  24. Mar 10, 2025 at 11:53 AM
    #1674
    TacomaTRD4x402
    Southern California
    That's where I got all my degrees:cheers:
  25. Mar 10, 2025 at 12:01 PM
    #1675
    RainMan_PNW
    Casey
    Clark County, WA
  26. Mar 10, 2025 at 12:03 PM
    #1676
    RainMan_PNW
    Casey
    Clark County, WA
    That stand is hard to beat for folding/traveling stands
  27. Mar 10, 2025 at 12:10 PM
    #1677
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Get yourself any kind of circular saw that fits your fancy. The right tool for breaking down sheet goods is a track saw, but they are expensive and not as multipurpose. you can approximate one for the cost of a couple pieces of wood.
    2 get a GOOD mask with a good fit an p100 filters. You don’t want to breathe that crap.
    3 make yourself a saw board with your new saw. It will act as a guide for among straight cuts. Honestly, I have a dewalt track saw and the saw board was just as good.
    4 Get yourself a big piece of foam insulation to lay the panels down on to cut them. If they flex when you cut them, they won’t align well. I am famous for being lazy about this and regretting it later.
  28. Mar 10, 2025 at 12:17 PM
    #1678
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Those straight edges are where it's at. I still have my almost 30 yo craftsman corded circular saw and one of those. Gets it done for me. Track saws are super nice but not a need unless your making money from its use.
    T-Rex266[OP] and Gaston[QUOTED] like this.
  29. Mar 10, 2025 at 12:38 PM
    #1679
    Gaston
    Gaston New Member
    Gary
    SE MI
    haha, same!
  30. Mar 10, 2025 at 3:10 PM
    #1680
