General Supercharger Thread
  1. Mar 9, 2025 at 2:45 PM
    ARES35
    ARES35 New member for life
    Mile high
    Exactly what happened to my driver side cat. It blew apart and was blocking flow. Plus I had constant misfires until I threw on the SPD downpipes.
    nags, HulkSmurf14, Silver17 and 2 others like this.
  2. Mar 9, 2025 at 2:54 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    But it has 3 cylinders!!
  3. Mar 9, 2025 at 4:09 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s 50k per!
    HulkSmurf14, ARES35 and Mdl like this.
  4. Mar 9, 2025 at 6:23 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What’s a good email to send it to?
    HulkSmurf14 likes this.
  5. Mar 9, 2025 at 9:26 PM
    JustDSM
    JustDSM New Member
    Justin
    No need. I have your original file from prior work (30CM22 VIN ending in 9046 correct?)
    If so, here's your stock file with the 8AR Ignition Coil Dwell edits made in the background. As you can see by the percentage of change made, the Tundra coil dwell settings are not charging the 8AR coils nearly enough for them to be at peak capacity.
    Here is the % change required:
  6. Mar 9, 2025 at 11:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's great! Really appreciate your help in getting the most out of them.
  7. Mar 10, 2025 at 6:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep that’s correct; awesome thanks Justin.
    Mdl likes this.
  8. Mar 10, 2025 at 7:53 AM
    Silver17
    Eastern PA
    Is anyone here monitoring their intercooler fluid temperature? I was thinking of installing one of these inline adapters with a threaded port to screw a sensor into for a coolant temperature gauge.
  9. Mar 10, 2025 at 7:56 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I wish I knew about that before fabricating my own on my LS :rofl:
  10. Mar 10, 2025 at 8:01 AM
    Silver17
    Eastern PA
    My thought was if you wish something existed for a particular function, it probably already does. It’s just a matter of googling the right terms to find it lol. That’s what happened here.
    nags, HulkSmurf14, Mdl and 2 others like this.
  11. Mar 10, 2025 at 8:22 AM
    snivilous
    SW UT
    Well I have another temp sensor I need to hook up so I now I know! Get pre and post intercooler temps was my goal.
    But from my fairly limited experience so far with the intercooler temp gauge it doesn't change much. My main concern was my power steering is cooled by the intercooler cooling loop so I have two heat sources dumping in. I had always assumed the IAT matched the intercooler temp pretty close, and they do seem to match extremely close now that I can monitor both. I'd imagine with just the blower that the intercooler temps will hardly move and just mimic the IATs you're already seeing. On my buggy that's like 100-110F usually, but obviously the ONLY similarity is both engines are supercharged :rofl:
  12. Mar 10, 2025 at 8:55 AM
    Silver17
    Eastern PA
    Im able to monitor the true IATs since the Harrop uses an actual sensor measuring intake temperature after the intercooler entering the cylinders. It’s consistently 30-35 degrees over the ambient air temperature as the hot HX coolant circulating the engine bay gives up some heat to the intake air, but getting into boost it doesn’t move at all and stays stable (pretty awesome considering each PSI increases the leaving temp by 15 degrees theoretically.) I want to measure the HX fluid temperature to know what it really is, but seeing as the IAT is always 30 degrees over ambient, the HX coolant is probably 40-50 degrees over ambient at any given time I’d guess. I want to see what happens to the temps if I incorporate a front intercooler sprayer down the road.
    HulkSmurf14, Saltyhero13 and Mdl like this.
  13. Mar 10, 2025 at 1:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @JustDSM
    I just wanted to say again, Thank you! I re-wrote the tune over your new background dwell settings. Flashed it and took it out. It does seem more responsive and I would occasionally get a random misfire, not enough to trigger a mil, on my logging but they didn't appear on my outing.
    I still have to open the gap as I'm at .026 and will see how .032 goes with the 8arfts coils.
    :thumbsup:
  14. Mar 10, 2025 at 1:27 PM
    JustDSM
    JustDSM New Member
    Justin
    Happy to help!
  15. Mar 10, 2025 at 1:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    SWEET!
    Thanks again @JustDSM
    Mdl[QUOTED], HulkSmurf14 and JustDSM like this.
  16. Mar 10, 2025 at 2:10 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And extended starts haven't happened yet. Will see how it goes. Been doing several stops and restarts.
    :fingerscrossed:
    HulkSmurf14, armyoffoo and reywcms like this.
  17. Mar 10, 2025 at 4:26 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Went down a rabbit hole...found another option for transmission upgrades
    8HP in a Tundra seems very doable, expensive, but doable. 4WD/AWD might be possible as well with the right Trans/T-Case, additional driveshaft and electronics for switching modes. (CANTCU only supports Dodge 8HP 70 1st Gen at this time, but contact them for support of other models) https://wiki.canformance.net/doku.php?id=cantcu:supportlist
    The CANTCU would fully integrate with aftermarket ECUs like Motec or Haltec.
    Parts list:
    8HP 70 Generation 1 Dodge transmission, with shifter and harness.
    *You will need to modify your cross member, will need a custom driveshaft, and a shifter mount
    https://www.tf-works.com/domiworks-...8hp-70-75-90-95-scat-pack-hellcat-adapter-kit
    $1200
    https://www.canformance.net/product/cantcu-transmission-controller/
    $1180
    https://www.luxiousauto.com/products/8hp/cantcu-harness
    $700
    Aftermarket ECU Required for Tundra compatibility
    https://www.haltech.com/product/ht-193000-nexus-r3-vcu/
    $2399
    https://www.boomslang.com/haltech-nexus.php
    $1421
    or
    https://www.haltech.com/product/ht-195000-nexus-r5-vcu/
    $4299
    $1659
  18. Mar 10, 2025 at 6:30 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep I’ve got a list of items also
    Turbolamik tcu comms
    Adapter plate also
    https://www.seemslegitgarage.com/product-page/toyota-1uz-3uz-8hp-adapter-kit
    Abell207, Mdl and HulkSmurf14 like this.
  19. Mar 10, 2025 at 6:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Also there’s a thread of someone who has this conversion. Only issue they’re having is the kick down gear selection during passing
  20. Mar 11, 2025 at 8:29 AM
    ssmokedz
    Shelton CT
    I was and was looking to do inlet and outlet temps with this gauge.
    Amazon.com: Revel 1TR1AA006R Gauge (VLS 52mm 50-300 Deg F Dual Intercooler Temperature), 1 Pack : Automotive
    Silver17[QUOTED], Mdl and HulkSmurf14 like this.
  21. Mar 12, 2025 at 10:45 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Anyone get shipping notifications on the valve bodies yet?
  22. Mar 12, 2025 at 10:47 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Negative
    Abell207[QUOTED] likes this.
  23. Mar 12, 2025 at 11:05 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Negative here as well. Though I also didn't receive tracking on the pan, either. It just showed up.
    UPDATE: Just pinged Johnny directly to inquire about an update.
  24. Mar 12, 2025 at 11:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My pan was delayed but just called them and he looked it up and got it out promptly. I inquired last month, for the pan, I believe it was mid March when they expected the VB's in, although I didn't order a VB.
    reywcms and HulkSmurf14 like this.
  25. Mar 12, 2025 at 11:31 AM
    centex
    centex New Member
    Not I.
  26. Mar 12, 2025 at 11:51 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Received the pan but no VB.
  27. Mar 12, 2025 at 11:59 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The PML pan uses a NPT plug to check the level. I just used some Rector seal no.5. By the time I used Teflon tape to install plug for the trickle it completely stopped. No worries as I always top off with a 1/2 quart extra afterwards. Could also have a spare plug already to go too.
    Wynnded and HulkSmurf14 like this.
  28. Mar 12, 2025 at 12:07 PM
    centex
    centex New Member
    Anyone got instructions on how to replace the valvebody?
  29. Mar 12, 2025 at 12:08 PM
    Bluecobra
    2014 Tundra
    I think they are on Cruiser and Co website. Support>Instructions
  30. Mar 12, 2025 at 12:11 PM
    Bluecobra
    2014 Tundra
    Never mind, the instructions there are not for our Trans.
