General Supercharger Thread
  1. Mar 8, 2025 at 3:02 PM
    centex
    centex New Member
    The nice thing about gears is if they are going to go out, it’s going to be early. Not a year from now.
  2. Mar 8, 2025 at 4:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Going with the straight mid pipes I went from 13.8 to 12.4 psi. Seems to have a bit more pep but it could be the extra growl from the free flow exhaust.
  3. Mar 8, 2025 at 4:38 PM
    ARES35
    ARES35 New member for life
    Mile high
    Are you running the SPD downpipes?
  4. Mar 8, 2025 at 4:41 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No. It's the OG dirty deeds dual 3 inch exhaust. Had it since 2012. But the mid pipes have gone through many cats to none.
    HulkSmurf14 and ARES35[QUOTED] like this.
  5. Mar 8, 2025 at 4:45 PM
    ARES35
    Mile high
    10-4 i see.
    Mdl[QUOTED] likes this.
  6. Mar 8, 2025 at 6:23 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I was reading some slightly older comments/discussion on the boosted page. I thought this was an interesting different opinion on what causes a boosted 3UR to have busted ring issues. Just thought it was relevant to the recent cat converter and AFR discussions so figured I’d share. Maybe the real boosted longevity issue for the 3UR is exhaust manifold/cat restriction causing high cylinder temps, and not the ring gaps themselves? Gotta say, the ring gaps being similar to the new V35a-fts is interesting despite being NA vs built for boost.
    upload_2025-3-8_21-17-3.jpgupload_2025-3-8_21-17-15.jpgupload_2025-3-8_21-17-29.jpgupload_2025-3-8_21-17-45.jpgupload_2025-3-8_21-17-58.jpgupload_2025-3-8_21-18-11.jpg
  7. Mar 8, 2025 at 6:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was running JBA LT's, 200 cell high flow cats, dual 3 inch exhaust( not stock). Aeromotive 340lph pump when mine went. AFR's were usually 10.8-11.4 at wot. So most likely leaned out because of supply line size and BD tune?
    I've always geared towards the 10.5 from Matt's post that I saw in the past.
    It is interesting and some food for thought.
  8. Mar 8, 2025 at 6:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    So we NEED LTHs... for longevity and less failure... alright, I'm just figuring arguments for the wife :argue:
  9. Mar 8, 2025 at 6:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And what about those running stock manifolds and exhaust?
    ARES35, armyoffoo and HulkSmurf14 like this.
  10. Mar 8, 2025 at 7:00 PM
    Silver17
    Eastern PA
    It’s probably just more overthinking of the issue. It would appear to me that some will go, and some won’t. I’ve seen at least one blow that had all of the PS fuel mods and tuning as well. It’s probably largely a crapshoot if you’re an unlucky one or not, and more dependent on driving style and abuse.
    Saltyhero13 and Mdl[QUOTED] like this.
  11. Mar 8, 2025 at 7:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I wasn't sure who was stating what but it's a good discussion. Aside from that guy busting a rod in his N/A tundra we haven't had engine failures like years past. The tuning has come a long way...as I literally knock on wood! Haha
    ARES35, Saltyhero13, Wynnded and 3 others like this.
  12. Mar 8, 2025 at 7:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    With going catless I did lean up my PE on my 3rd run today. I did keep it in 10.5-11 from 4400-6000rpm.
    ARES35 and Wynnded like this.
  13. Mar 9, 2025 at 6:16 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Several people, Keith being one, told me that if the cats come apart and restrict the exhaust flow, it will likely kill the engine. Made sense to me. I removed mine. Of course I only use my truck off-road.:)
    ARES35 and Silver17 like this.
  14. Mar 9, 2025 at 7:11 AM
    Silver17
    Eastern PA
    Well what about using a turbo? Aren’t the pre-turbine exhaust pressures 1.5x to 2x the boost pressure? It’s kind of an exhaust restriction by design.
  15. Mar 9, 2025 at 7:27 AM
    centex
    centex New Member
    Cats coming apart can completely stop flow depending on how they get oriented when it comes apart.
    HulkSmurf14 likes this.
  16. Mar 9, 2025 at 9:48 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Continuing the crank no start. Tossed in a new Odyssey just to cover any random voltage issues. Pulled 2 plugs this morning and they’re soaked in fuel and gunk so this could definitely be a contributing factor. More to come.
    ssmokedz, HulkSmurf14, ARES35 and 5 others like this.
  17. Mar 9, 2025 at 9:58 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sucks, sorry.
  18. Mar 9, 2025 at 9:58 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    With the 8arfts coils have you thought of opening the gap. Even just going back to .028 to .032? When I get the new injectors I'll be opening them up @Jowett asked if we tried opening for the stronger spark.
    I saw my five-o's were pretty rich on start up @Wynnded had same issue but from extended starts.
    Good luck trouble shooting I'm sure your covering all the bases.
  19. Mar 9, 2025 at 10:02 AM
    e30cabrio
    I had to go to 32 or so to get rid of my misfire with the 8ARFTS.
    HulkSmurf14, ARES35, Wynnded and 2 others like this.
  20. Mar 9, 2025 at 10:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea I think im at .028 but cant remember may open them up .032
    HulkSmurf14, Wynnded and Mdl[QUOTED] like this.
  21. Mar 9, 2025 at 10:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What else may cause no spark. We have new fuses and relays, new crank sensor. Do we have an ignition diagram laying around?
    HulkSmurf14, Wynnded and Mdl like this.
  22. Mar 9, 2025 at 10:58 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Was the battery disconnected for a while? I've only heard it happen once. The ecu/immobilizer needed to be reset. Is key recognized?
    HulkSmurf14 and Wynnded like this.
  23. Mar 9, 2025 at 11:04 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Or aftermarket alarm with immobilizer bypass acting up?
  24. Mar 9, 2025 at 11:05 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nope key is recognized and tried the spare is also recognized
  25. Mar 9, 2025 at 11:11 AM
    JustDSM
    JustDSM New Member
    Justin
    It might help if you had the proper dwell time configured for the coils.
    I can port the changes into a file for you in the background if you want to send me a stock file for your truck.
  26. Mar 9, 2025 at 11:18 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Never had any running issues before not sure that would help but couldn’t hurt.
  27. Mar 9, 2025 at 11:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @snivilous you got that laying around?
  28. Mar 9, 2025 at 12:01 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    HulkSmurf14, reywcms[QUOTED] and Mdl like this.
  29. Mar 9, 2025 at 12:09 PM
    Silver17
    Eastern PA
    Definitely just left a BMW I8 driver feeling like his 150k got him something wholly inadequate to fend off pickup trucks with pappy caps on the highway. :rofl:
    Who would buy one of those? Pretty unspectacular for the coin.
  30. Mar 9, 2025 at 12:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was under the "assumption" we couldn't change those. If possible I'd be interested in anything for spark.
    @reywcms I have your tune file when snivilous changed your airload for the 103mm TB but that was last year, 5/24.
