SS6 LED Fog Light Kit for the 2022+ Toyota Tundra | Diode Dynamics
Discussion in '3rd Gen Tundras (2022+)' started by Diode Dynamics, Jan 31, 2023.
  1. Mar 5, 2025 at 9:29 AM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    Yes I've had it off twice now. You need to get a plastic trim removal tools to get un under the top part and "pop" the tabs off. I found it easier to start on one side and after you pop it loose around the fog light then pull from the middle. It takes some force but you will NOT break that main piece. I did not remove the lower the first time but did the second time when I installed the Tow hooks.
    https://www.amazon.com/Tresalto-Aut...1-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
  2. Mar 5, 2025 at 9:41 AM
    Calif-Tundra
    Bob
    The Tow hooks are Toyota OEM. Here is the kit. I wanted something stockish and that did not need to trim/cut the stock grill. I had no plans on a winch so this kit was perfect. Here is the link to the thread here on Tundra.
    https://www.tundras.com/threads/toyota-oem-trd-front-recovery-hooks.150783/
    Here is my build thread for all the other mods so far. It's been a fun journey for my son and I to modify.
    https://www.tundras.com/threads/calif-tundra’s-2023-limited-trd-or-semi-pro-build.154633/
  3. Mar 6, 2025 at 6:09 AM
    tallg53
    tallg53 New Member
    2024 CMLB 1794 TRD OR
    Just getting started...
    Thanks, I did buy one of the trim removal kits and no luck with that either. Between the pry tools and trying to loosen the clips from behind, it still will not budge. I am going to have to pull off the entire grille assembly to get the lights installed.
  4. Mar 6, 2025 at 1:38 PM
    Calif-Tundra
    Bob
    That will probably be the cleanest best way anyway. Good luck!
    tallg53[QUOTED] likes this.
  5. Mar 6, 2025 at 8:00 PM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
    Is there a vid on how to aim the fogs more downward?
    Thank you!
  6. Mar 7, 2025 at 3:08 PM
    bailey bulldog
    bailey bulldog New Member
    Just pull, it'll come off I promise. Start at the bottom edges where the sensors are.
  7. Mar 8, 2025 at 4:59 AM
    LowcountryDave
    LowcountryDave New Member
    ‘23 Limited TRD
    Finally got my Amber SS6’s installed yesterday. Had them sitting around for three months and finally had the opportunity.
