Climate Control Cables
Discussion in '1st Gen Tundras (2000-2006)' started by Superferret10, Mar 7, 2025.
  1. Mar 7, 2025 at 6:00 PM
    Superferret10
    Superferret10 [OP] New Member
    2005 tundra SR5 access cab v6
    Anyone know what the oem part name or a substitute is called for the climate position cable and/or where to get one? I've lubed up the acutators at the bottom and pulled apart the assembly and my conclusion is that the cable is just messed up as it's missing some of the sheath and seems bent in the wrong way
  2. Mar 7, 2025 at 7:41 PM
