Yup, it's the thread yall being waiting for
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Jan 22, 2025.
  1. Mar 1, 2025 at 7:20 AM
    389 24/7
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Btw this took so long because of some usps facility consolidation issue
  2. Mar 1, 2025 at 7:53 AM
    389 24/7
    Oregona
    2022 TRD OR
    Nada
    I guess doing 10k oil changes does no harm
    & all those early oil changes to pull out metal debris is a waste of time, money, & natural resources
    I wonder how many peeps are performing unnecessary oil changes
    I used to be one of those people
    Lol
  3. Mar 1, 2025 at 7:59 AM
    AZBoatHauler
    So.Arizona
    5k OCI vs 10k OCI isn’t so much about metal wear IMO - it’s about sludge. If you think oil with a flashpoint of 380 is doing great - I don’t know what I can say. You didn’t get a TBN to determine how much, if any, life that oil had left.
    BlackNBlu and Cpl_Punishment like this.
  4. Mar 1, 2025 at 8:06 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    What's the flashpoint of new oil?
  5. Mar 1, 2025 at 8:07 AM
    AZBoatHauler
    So.Arizona
    It’ll depend on the manufacturer and weight but should be in the 400s. Mobil1 5w-30 came back at 480.
  6. Mar 1, 2025 at 8:25 AM
    AZBoatHauler
    So.Arizona
    I found a virgin oil analysis of Toyota 0-20 for comparison.
  7. Mar 1, 2025 at 8:26 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    What brand of oil are you using?
  8. Mar 1, 2025 at 8:53 AM
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    I didn’t know I wasn’t not waiting for this thread, so I was really glad when I found it. :hearteyes:
    Cpl_Punishment and 389 24/7[OP] like this.
  9. Mar 1, 2025 at 8:55 AM
    389 24/7
    Oregona
    2022 TRD OR
    Nada
    Toyoda...lol
    ARB1977[QUOTED] likes this.
  10. Mar 1, 2025 at 10:36 AM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    Is anyone running 5w-30 in their 22-C Tundra?
  11. Mar 4, 2025 at 4:33 AM
    389 24/7
    Oregona
    2022 TRD OR
    Nada
    I called blackstone & spoke with Brian
    He clearly stated that my engine is fine, no metal debris & I should continue with 10k oil change interval
    I will get another analysis done at my 130k oil change (in about a month) with TBN this time so we can clear that up
    22whatwedo, ZappBrannigan and j-utah like this.
  12. Mar 4, 2025 at 6:32 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Awesome man. Thanks for taking the time to do this. Can’t wait for the results. How much idling do you do? Noticed just a trace of fuel in your sample.
  13. Mar 4, 2025 at 6:40 AM
    389 24/7
    Oregona
    2022 TRD OR
    Nada
    I idle a lot
    I live in snow country, east of the cascades & 30 mins south of crater lake, so I often let my tundra warm up for 15-20 mins before I drive it especially this time of year
    ZappBrannigan likes this.
  14. Mar 4, 2025 at 9:39 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    You’ve definitely proven 10K could be done. How often do you check your oil? Any oil burn?
  15. Mar 4, 2025 at 12:02 PM
    389 24/7
    Oregona
    2022 TRD OR
    Nada
    If you are talking about checking the oil via dipstick, never
    I drain the oil, remove filter, put 7.75 quarts in & drive another 10k
    Then repeat
    I have not checked the oil dipstick/level once in 3 years/125k miles
  16. Mar 4, 2025 at 12:38 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    For shits and grins. Check the oil level before you change the oil. I’d like to know if the level stays the same or it drops some. If it stays the same that’s pretty damn impressive.
    Cpl_Punishment likes this.
  17. Mar 4, 2025 at 12:58 PM
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    My 3.5 Ecoboost does not use any oil between changes either. I have gone 16,000km (10,000mi, the oil life monitor suggested OCI) a few times but typically change at 10,000km. What surprises me is that the level does NOT decrease even though I "catch" probably 1/4 to 1/2 litre of grunge in my catch can. It's a smallish catch can so I dump it every 1500kms (900mi).
  18. Mar 5, 2025 at 10:08 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I switched over to 5W-30 at my last change at 15K miles. I change every 7,500, currently have 19K and change on it. I'll be changing the oil again in about 2-3 months and have analysis done at that time. I can say, I noticed no loss in mileage and the engine runs smoother and quieter. Analysis at 15K with 0W-20 showed everything was good, so I'll be able to see if the 5W-30 had any detrimental effects. I still don't believe the metal shaving excuse from Toyota, but that's just me. Time will tell if my 2024 hybrid, with no recall, craps the bed or not. Either way, not worried about it. If it does, I'll have a fat extended warranty from Toyota to foot the bill.
  19. Mar 6, 2025 at 9:51 AM
    mass-hole
    mass-hole New Member
    If you put on 125k miles in 3 years you are going to have good results from Blackstone. This shouldnt be a surprise.
    Its the people who are driving 10k a year doing 10k mile OCI's, short tripping their trucks, and not towing much that are probably gunna see worse results from fuel dilution.
    Tundrastruck91 likes this.
  20. Mar 6, 2025 at 9:56 AM
    #50
    mass-hole
    Let me guess, your catch can is the dual valve kind? And is it mounted in front of the radiator? If so, you're getting that much because your catch can is mostly catching water and fuel because its being hit by cold air and condensing it all out. Very little oil makes it out the baffles on the valve cover.
    I ran dual catch cans(one for the PCV on the passenger side, and a second for the CCV on the driver side) that were mounted to my firewall, where its much warmer, and so it caught very little water and fuel. The cans would only have an ounce or two of oil after a few thousand miles.
  21. Mar 6, 2025 at 10:22 AM
    #51
    2wheelsforfun
    Foothills AB Canada
    Nope, just a simple JLT can mounted to the battery bracket which sits midway back in the engine compartment so stays plenty warm.
  22. Mar 6, 2025 at 10:31 AM
    #52
    mass-hole
    Interesting, and its all actually oil? It doesn't separate out if you let it sit? My original can would catch a lot like yours, but 90% of it was not oil. It looked like some extravagent Starbucks drink if you let it settle out for 5 minutes in a cup after draining.
  23. Mar 6, 2025 at 10:45 AM
    #53
    2wheelsforfun
    Foothills AB Canada
  24. Mar 6, 2025 at 3:20 PM
    #54
    dagooaz
    dagooaz New Member
    Dave
    Starbucks would charge $9 bucks for that!
  25. Mar 14, 2025 at 8:39 AM
    #55
    Third-Reef
    Third-Reef New Member
    Gary
    2025 1794 TRD offroad
    What is the purpose of the catch can? It is not needed for carbon build up like it was on my ford ecoboost. With the port injection it all stays clean in the new Toyota engines.
    PNW Tundra Mike likes this.
