  1. Mar 5, 2025 at 12:12 PM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    What is the reason for paying that much for wiper blades?
  2. Mar 5, 2025 at 12:16 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
  3. Mar 5, 2025 at 12:39 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Same reason for getting pricier knives, food, houses, etc. - - you usually get what you pay for. You'll be replacing cheap blades every season. As some others (@RainMan_PNW) mentioned, you might go years without having to replace good ones. I went more than 3 years before replacing OEM (I'm in the DFW area). I like the Icons (also pricey) just fine, but I'll probably go back to OEM when I replace them.
  4. Mar 5, 2025 at 1:17 PM
    centex
    centex New Member
    I get ~18mo out of wiper blades no matter the cost so I buy the cheap ones.
  5. Mar 5, 2025 at 2:06 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I'm still on my OG blades from 2018 with 54,000 Illinois miles on them.
  6. Mar 5, 2025 at 2:39 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    I've tried all sorts of brands over the years. RainX, Bosch, you name it. The last set was OEM because for me, they last longer, don't chatter, or leave streaks. Will continue moving forward as they compare in price to the brands I've used.
    jmdaniel, bulldog93, ATV25 and 2 others like this.
  7. Mar 5, 2025 at 2:41 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Same here.
    jmdaniel and Tripleconpanna like this.
  8. Mar 5, 2025 at 3:24 PM
    seydou
    seydou Distinguished Member
    IMO $20 per blade is reasonable for one that works well and lasts. How much do you pay for a blade or think you should pay?
    jmdaniel[QUOTED] and 00h2itr like this.
  9. Mar 5, 2025 at 3:35 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    VLEDS installed... still to light out to get the full effect, but install was simple, and they seem to be working:
    Dads helper, I needed her to press the brake pedal but she couldn't reach:
  10. Mar 5, 2025 at 4:54 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Springs arrived, t’is almost party time
  11. Mar 5, 2025 at 5:12 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    i just prop my cell phone up against something nearby, put it on recording and go step on the brake pedal to test. Then rewatch it. Works when you are by yourself.
    Henry1jg, rdiddy5, Gaston and 6 others like this.
  12. Mar 5, 2025 at 5:59 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    +1 for OEM as well. Why not they last a long time. I found the chatter and streaks to be true on wifey's car too (GM Malibu). OEM from now on. Just picked up a new set for her from the GM dealer last month, waiting for the weather to break to slap them on.
    jmdaniel and bulldog93 like this.
  13. Mar 5, 2025 at 6:34 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Mine just got here now I need to find some time to install
  14. Mar 5, 2025 at 6:58 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    Yes, the OE do last a lot longer. I typically get about three years out of an OE set for my Toyotas and Hondas.
    I love my Honda because you can still buy just the rubber part and reuse the rest of the blade. They only cost about $9 each. Toyota does not sell just the rubber anymore :(
  15. Mar 5, 2025 at 7:11 PM
    TimmyT
    TimmyT New Member
    Timothy
    Dothan, AL
    16 Tundra Limited, Crewmax
    Leveling Kit
    I did a Headunit swap on my 2016. It now has a 20/21 HU in it. Sourced the HU from eBay and the wire conversion harness from auto harness.com.
  16. Mar 5, 2025 at 7:34 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 SSM Tundra 1794
    I picked up my chrome delete parts from the body shop.
    Two fender fillers (they had rock chips)
    Two new oem bumper ends
    Rear bumper end (was scuffed)
    Resprayed oem bulge (SSM is not available right now)
    I bought the platinum grill already painted from Toyota. I'm also swapping the headlights to oem black.
  17. Mar 5, 2025 at 7:41 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks like the tail light upgrade, you are going to love it.:cool:
    Should take less than 30 minutes, but you know how that goes..:(
    ATV25[QUOTED] and Tripleconpanna like this.
  18. Mar 5, 2025 at 7:58 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What did you pay for the head unit and harness? That might be the way to go for my 2015 vs. aftermarket.
    HulkSmurf14 likes this.
  19. Mar 5, 2025 at 8:20 PM
    TimmyT
    TimmyT New Member
    Timothy
    Dothan, AL
    Leveling Kit
    the HU was $490 and the harness was like $180.
    the key is to make sure you get the same HU style. (JBL or non-JBL) Also, the ones that come with Nav are more expensive. Just make sure it’s an entune 3.0 HU. I had nav in my older 16 HU but I bought the 20/21 one without nav. Thought process was “who needs nav when you have Apple CarPlay?”
  20. Mar 5, 2025 at 11:36 PM
    ZPhilip
    Philip
    West Chester, PA
    How do you verify it’s an Entune 3.0?
  21. Mar 6, 2025 at 12:05 AM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    On the back of the head unit. 3.0 also has 4 buttons on side and a bigger screen. Look on the forum or Facebook I got one for $250 recently.
    bulldog93 and HulkSmurf14 like this.
  22. Mar 6, 2025 at 2:44 AM
    Tundra family
    Tundra family New Member
    While we're on the subject of wiper blades. Why do mine streak no matter what I use? What's the fix for uneven blade pressure? Drives me nuts because it clears on the up sroke then streaks all the way back down. :mad:
    woods and HulkSmurf14 like this.
  23. Mar 6, 2025 at 4:22 AM
    TimmyT
    TimmyT New Member
    Timothy
    Dothan, AL
    Leveling Kit
    bulldog93 likes this.
  24. Mar 6, 2025 at 4:46 AM
    centex
    centex New Member
    Only time I’ve seen that is when they are worn. You could try wiping the blades with a paper towel. Might have some debris stuck to them.
    bulldog93 and jmdaniel like this.
  25. Mar 6, 2025 at 5:11 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Well, I didn't do it today but I added some dents and dings, 4 wheeling ya know..... I also replaced a set of LED headlight bulbs. One burned out so you know.....
    Anyway, I also "deleted" some cosmetic parts to facilitate making that a MUCH easier process. I have a very big (and awesome) ARB bumper w/winch. So that made the changing of bulbs a very challenging job. I got it figured out and now it will be as I said MUCH easier to change out again.
  26. Mar 6, 2025 at 5:29 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Great idea..
    Hazards:
    Reverse:
    Brake:
    This is what I have in-between the tailgate and fender: SoundOff Signal mPower Fascia 3" LED Single Color Light
    Yes and Yes... roughly 30min from unboxing to installed.
    I run the DD Tail to Turn kit w/5000k reverse on the 4R and these are just as good :thumbsup:
  27. Mar 6, 2025 at 6:57 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Those brake lights are something else! Going to need sunglasses behind you.
    I am torn on all this lighting stuff. On one hand, it's a serious safety issue if people can't see you are turning or stopping. I have replaced bulbs for that reason before too. But then, how bright is too bright? Modern headlights are already a pain in the ass and need to be fixed for oncoming traffic like they do in europe where the driverside light dims a bit or whatever. Then, are we adding blinding tailights in now too? I am not even 40 but I stopped driving at night unless I have to. I do have a nasty stigmatism and that makes it all alot worse though, so maybe I'm just handicapped and its a me problem:rofl::anonymous:
    Corndog123, Henry1jg, ATV25 and 2 others like this.
  28. Mar 6, 2025 at 7:02 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Totally a valid concern. What I'll do before the weekend is up is follow my truck with the wife driving to get a feel for that. They are already on, and I would assume they are SAE 'certified' but perhaps @memario1214 can chime in with the technical details there?
    memario1214 and woods like this.
  29. Mar 6, 2025 at 7:03 AM
    RobertD
    Robert
    DFW, Texas
    So... I have @memario1214 HotTails were uses these Vleds but he was the first with the dedicated plug and play Tundra kit. I work evenings and drive home at midnight/1am. I can see the people in vehicles behind me when stopped, in a vast amount of red light but I have yet to see any shield their eyes or look away.
    With the light being red, I don't think it has the same "super bright" effect that white led headlights have. So I think these taillights just increase your safety awareness without having a down side. I 100% recommend the kit and would do it again.
  30. Mar 6, 2025 at 7:06 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Agreed, I was watching for people's reaction when driving in this morning and didn't see anyone that appeared to be frustrated with the brakes lights. I did go thru a drive thru for my coffee and was aware enough to put the truck in park when stopped.
    I may remove the small led's down the road...
    woods likes this.
