  1. Mar 4, 2025 at 11:07 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    It will only turn the brake adjuster if the brake shoes have enough travel to click the star. I think that system is designed to adjust brake shoe travel, not cable slack, although shoe slack will affect cable slack. If shoes are adjusted correctly and you still have E brake cable slack, you have to adjust the cable itself.
    oscardog86 likes this.
  2. Mar 4, 2025 at 11:34 AM
    Dakillacore
    Georgia
    Since we're on the topic of brakes......
    I had some dumbass slow down fast in front of me so I had to hit the brakes pretty hard. I almost went into the back of their vehicle because it did not stop quickly at all. It felt like there wasn't enough pressure on the rotor. What adjustments can I make to tighten it up?
    I have already had the brake fluid changed out and bled the system a couple of months ago, but I don't think there is an issue there.
  3. Mar 4, 2025 at 12:04 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Manually adjust the rears first. Using a small flathead screwdriver, adjust the star in the upwards direction when going in from the back side of the drum. No need to take the wheels off, there is a visual adjustment hole on top / above of the axle housing. With the rear wheels in the air, adjust until there is just a slight bit of drag when turning the wheels by hand. Then test. If you need more, adjust the LSPV upwards towards the top of the shaft. I'd send you pics, but I know there are quite a few on here already. The front brakes are dependent on the rears being dialed in.
    https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/#post-2540134
    https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/#post-2566492
  4. Mar 4, 2025 at 12:53 PM
    Dakillacore
    Georgia
    Thanks, brother. I'll check this out and report back when I get it situated.
  5. Mar 4, 2025 at 3:07 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    i’d beg to differ. Pull the rear wheels & drums, hit it with the brakleen & a shop rag, adjust em induvidually, then fine tune the crossover after bolting the tires on and using a mirror to verify both tires stop on the same click of the p brake. If you take em apart hit the teeth of the adjuster with a triangular file & just clean the grooves. No need to make deep cuts.
  6. Mar 4, 2025 at 3:26 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Today I did the 'beef up the tailgate latch parts' thing. Nothing huge. I did notice that some parts looked newer and had already been replaced once, but with the same teeny wimp parts.
    I also installed running boards at the weekend and added fog lights recently, but forgot to post.
    Two things about adding the fog lights.
    1) The instructions, at least for the later models, say to add a relay. Turns out mine was already there (AFTER ordering one!), so check before you order. if you want to do it.
    2) The DC actually needs the fog lights for the Sequoia, otherwise the adjuster mechanism will be loose in its socker. The mega thread does warn about it the DC being much more Sequoia based at the front, but dumbass here relied on the eBay algo thing saying the same one that the AC uses will fit. It doesn't :). At least it only cost me a little time thanks to easy returns to a great seller.
    My todo list is getting smaller!
    Neo, Dakillacore, Tlar25 and 3 others like this.
  7. Mar 4, 2025 at 5:06 PM
    meatwizard
    meatwizard Ski touring with poop in my diaper
    Montana
    '05 Tundra AC 4x4 V8 Grey
    Got tires mounted on the new rims
    Method 703 17x8.5 0mm offset
    Yokohama Geolander At 4 255/80 R17
  8. Mar 4, 2025 at 5:27 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Those will look great installed. What are your suspension plans?
    Filthyphil likes this.
  9. Mar 5, 2025 at 6:06 AM
    oscardog86
    oscardog86 New Member
    Southern California
    So I bought some Total Chaos lowering shackles to bring me down a bit because I had too much rake after adjusting my 6112s down to the 3rd notch. While contemplating that project and knowing Id be removing my leaf springs, I decided to splurge and get some Archive Garage Hammer Hangers as well. Truck looks pretty level now. Also took it for a quick test drive yesterday, and this thing has almost no body roll anymore. Probably gonna add some sort of a cross tube from the hangers as well to get even better stability in the rear.
    PXL_20250304_233337520.jpg PXL_20250304_235903849.jpg PXL_20250304_235926271.jpg
  10. Mar 5, 2025 at 6:17 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    What leafs are those?
  11. Mar 5, 2025 at 6:19 AM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Sick. Are these just bolt on?
    oscardog86[QUOTED] likes this.
  12. Mar 5, 2025 at 6:24 AM
    oscardog86
    Southern California
    Archive Garage MD leafs
  13. Mar 5, 2025 at 6:24 AM
    They do bolt on but the oem has to be ground off
  14. Mar 5, 2025 at 6:25 AM
    oscardog86
    Southern California
    Yea they bolt on , but you have to drill out or punch out the old riveted in stock hangers. Actually was surprisingly easy. I was watching videos where other guys used air hammers to do it but some grinding and drilling made pretty quick work of it!
    Also helps that I ordered the extra drill bits from Archive Garage that cut through the rivets like nothing.
    Oh and wanted to add, Archive Garage quality is quite impressive. Not only the welds and stuff they build, but the instructions they provide, how everything is organized and packed. Really impressed!
  15. Mar 5, 2025 at 6:28 AM
    Was ist das? Stiffener of some sort?
    Dook55 and oscardog86[QUOTED] like this.
  16. Mar 5, 2025 at 6:33 AM
    oscardog86
    Southern California
    Oh yea, forgot to mention that funny looking thing. So when I had a bumper built 6 years ago, before I learned to weld, the fabricator welded the forward brace of the tube bumper to my frame. The lower tube used to go straight through to the frame. This was fine until the lowering shackles I installed caused the leaf spring to contact the tube. So I cut out that portion of the tube to the frame, and welded a sleeve to attach to the top tube you see now and thats going to the frame several inches higher, giving me clearance on the leaf spring now.
    Tlar25, 455h0le_dachshund and shifty` like this.
  17. Mar 5, 2025 at 6:43 AM
    oscardog86
    Southern California
    Just for a heads up, the Total Chaos lowering shackles lowered me about 1". Hub to fender was 23" and now is about 22". My front is about 21" on both sides. So pretty level now
  18. Mar 5, 2025 at 6:54 AM
    meatwizard
    Montana
    @Tlar25 Toytec 650lb coils paired with 5100s in the front and 5100s with a toytec add a leaf in the rear.
    Tlar25 likes this.
  19. Mar 5, 2025 at 7:15 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm jealous. I really want some hammer hangers and their shock relocation
    Tlar25, PNW15 and oscardog86[QUOTED] like this.
  20. Mar 5, 2025 at 7:21 AM
    oscardog86
    Southern California
    The shock relocation would be pretty awesome, but my bed aint coming off any time soon!
    Down the road ive thought of building a flat bed and then a new camper on the flat bed. So at that time id probably do the shock relocation as well. But until then, im pretty happy with my setup
  21. Mar 5, 2025 at 9:38 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Took the two Kendas with the most tread to get mounted this morning. They're ready for some test fitting shenanigans soon.
  22. Mar 5, 2025 at 9:43 AM
    oscardog86
    Southern California
    @455h0le_dachshund Really like the look of your truck. I think the blue shell makes the pickup truck look of it pop out more too
    Tlar25 and 455h0le_dachshund like this.
  23. Mar 5, 2025 at 9:45 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thanks! I dream of someday the whole truck being blue :)
    Dirt Ferguson, Tlar25, Azblue and 2 others like this.
  24. Mar 5, 2025 at 9:48 AM
    oscardog86
    Southern California
    I would love to get a paint job for my truck with a cool new color other than white. But then I'd just wanna baby it and be afraid of every little scratch, lol
  25. Mar 5, 2025 at 11:29 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Yesterday, actually. 107,xxx miles on the originals. Drivers side was good, no movement when I checked them on the truck, but the passenger side had a bit of play in the joint and the grease was leaking on both ball joints, so they were replaced with OEM.
    Neo, The Black Mamba, shifty` and 9 others like this.
  26. Mar 5, 2025 at 1:48 PM
    Dakillacore
    Georgia
    Do you always add black pepper to your LBJ's? :D
    robabeatle, Tlar25, BroHon and 5 others like this.
  27. Mar 5, 2025 at 2:38 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do you not? :D
  28. Mar 6, 2025 at 12:29 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Noticed that the pesky wiring harness that is always getting chewed on when routed incorrectly during a T-belt change... Is routed incorrectly on my truck, and allegedly has been since 2016 according to the Aisin sticker... Can't believe it's been like that with no visible damage for 70k. Maybe it did get damaged and was replaced? But I have 14 pages of records and no mention of it...
    Not sure what maintenance other that T-belt would cause this routing... Not even A/C replacement? Which I have no record of...
    Access is difficult to get an ideal zip tie, but I secured it the best I could until I get to my belt job this spring.
    Does the bracket have to be removed to route behind or can I unplug and sneak it thru... Hmmmmm. EDIT: Yes it can be fished thru with some grunting, cursing, needle nose pliers, and luck...
    hammeron, Tlar25, FirstGenVol and 4 others like this.
  29. Mar 6, 2025 at 3:50 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    You got it, yeah I had to do the same thing fishing it back through there. It's tight, one plug at a time with long bent needle nose :thumbsup:
  30. Mar 6, 2025 at 3:50 PM
    I've seen this mentioned but never knew what people were talking about. I need to check mine.
    What's it look like after you fishes it through?
