Skid plate bolts...and dealer RANT...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Charliebrn, Apr 18, 2021.
  1. Apr 18, 2021 at 6:08 PM
    Charliebrn
    Charliebrn [OP] New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Ok, a small rant. My first oil change on my 2017. Previous owner had dealer do all the maintenance, and the records prove it. I went under the front of the truck today to do the oil/filter change and only 1 bolt holding the back center of the skid plate on. All the other bolts missing, including what look like should be 3 screws for the bumper facia.
    It's just...like they don't give a damn. They wouldn't have done that with their OWN truck, ya know??? Generally, I've been happy with the dealer, they backed me when I needed it, but gees folks, have just a little pride in your work. They must figure that no customer is ever gonna look. All that stuff was just flapping around down there for at least the 4000 miles I put on her.
    I'll probably just try to find replacement bolts (ALL of them, since the one in the back center is slightly stripped as well) online somewhere. Anybody have part numbers avail easy? LOL
    Thanks for letting me vent...
    Petro, coldcanuk, AzSequoia and 2 others like this.
  2. Apr 18, 2021 at 6:18 PM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Sumo91 likes this.
  3. Apr 18, 2021 at 7:01 PM
    Griff
    Griff New Member
    2018 Barcelona Red DC
    Topper, bedslide and more to come
    I had a drain plug dripping on my garage floor. Reached under and tightened it by hand. Got the wrench and snugged it some more....very carefully. Called dealer the next morning and told them they would be examining my oil pan to verify the plug was simply not tightened after their service....rather than over tightened and stripped. Got lucky. I do my own service work now.
    Norfolk757 and coldcanuk like this.
  4. Apr 18, 2021 at 7:05 PM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    I had the exact same rant about two years ago. Bought my ‘13 Tundra as a CPO from a dealer who did all the service. Only 3 total bolts were holding the skid plate. I found the missing ones on this website: https://www.toyotapartsdeal.com/
    Specifically, part # 90119-A0169
    Petro, TreeCat and IndianaGeologist like this.
  5. Mar 3, 2025 at 11:30 AM
    Mabelfail98
    Mabelfail98 New Member
    2013 Cremax
    None
    Yup. I'm at the age where I pay the shop to change my oil. I took my 2013 Tuna in for oil change on 2/3/25. I discovered this weekend that the shop not only left out 3 bolts but misaligned the front hooks. Pissed off! Took it back and showed them. Naturally they did not have replacement bolts.
    07 Tundie, Petro and Tunrod like this.
  6. Mar 3, 2025 at 11:37 AM
    AZBoatHauler
    So.Arizona
    1lowlife and whodatschrome like this.
  7. Mar 3, 2025 at 11:47 AM
    Retroboy1989
    Northern Utah
    So lazy!
    I bought a 2012 that had ONLY been served by a dealer and the Carfax backed it.
    Sure enough, it was missing screws and a bolt.
  8. Mar 3, 2025 at 11:56 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Nope, nobody touches my truck.
    Not only do I get to do the oil change, but I thoroughly inspect the truck for leaks or other wear items. Never an over torqued or missing bolt. Does it suck sometimes (dead of winter, or summer) yes. But I know it's done right, and with pride in my work.
  9. Mar 3, 2025 at 12:05 PM
    D1S7N
    D1S7N New Member
    2021 Limited AG
    Last month I started to hear an intermittent low pitched rattling noise after my last oil change. I couldn’t pin point it until I finally noticed that they didn’t re-install two of the front screws holding the lower part of the plastic bumper on the skid plate so it was rattling.
  10. Mar 3, 2025 at 12:25 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    I'm not sure why people are surprised at this, ive been experiencing the same issues with almost every Toyota dealer in this area. Also, this is not just a Toyota thing exclusively. The dealer fucked my new GX460 with stripped bolts while doing an oil change, then they could not balance the tires properly and had to take back to them 3 times only to go to Costco, yes Fucking Costco, to get them to properly balance the tires. The Lexus (PRIORITY) stealerhip called me back and could give two $hits about their workmanship quality. Mind you this Lexus is still under factory warranty and maintenance plan. These bastards really screwed me over during the purchase try to get more $ out of me after the deal was made so i had to cancel my purchase with them and go to Alexandrea Lexus to get my new Lexus.
    1lowlife and Tunrod like this.
  11. Mar 3, 2025 at 3:08 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Yep, same here. Missing both rear bolts on my TRD Pro skid, which makes no sense since there’s already the little filter housing door that just needs an allen wrench.
  12. Mar 3, 2025 at 3:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    When you do want to put it back together, I recommend Talon's nut plate.
    It will make putting those bolts in MUCH easier..
    TRD Nut Plate – Talons Garage
    My dealer does my oil changes but I look under the truck every time to check that my TRD Pro door bolts are in place..:rolleyes:
    equin[QUOTED] likes this.
  13. Mar 3, 2025 at 3:56 PM
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    Damn. Only one left?
    I was missing only one when I did mine for first time. The three from the bumper fascia long gone too.
    Of course when having the dealer do it, it is always some baby faced kid grabbing the truck.
    Probably going to do it myself after I use my last prepaid change.
  14. Mar 3, 2025 at 4:00 PM
    Petro
    Petro New Member
    Lol.
    Didn't realize the thread was from 2021.
    Wonder if the OP will even see the replys?
  15. Mar 3, 2025 at 5:56 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    To hell with it- Let's rant!!
    I finally swore off dealer service when they failed to torque the lugnuts on my passenger front wheel and it was coming off! I had to replace 3 nuts that had spun all the way off and I had nightmares for a week.
    But at that time, I was TOLERATING the over-torqued oil filter housing and the missing skid plate hardware. I got the impression that the techs must get angry at the vehicles they are servicing and treat them like shit.
    No more. After the wheel episode, I started having a family owned certified shop do bigger jobs and check it out at every other oil change. It's a shit drive through west Portland traffic to drop and pick up, but the guys there do a fantastic job.
    Norfolk757, Retroboy1989 and Petro like this.
  16. Mar 3, 2025 at 6:52 PM
    Retroboy1989
    Northern Utah
    What does one miss by not taking it to the dealer...ever?
    panicman likes this.
  17. Mar 4, 2025 at 6:12 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I used dealership for oil changes. When I did the first 1 myself 1 bolt was missing and another was not OEM. This is a thread about skid plates so I won't go into issues with filter cap. When I got the survey I gave them a 0. Manager called me and I explained why. He ordered 2 new bolts. When I went to pick them up he asked "do you want them installed?". I said NO. We also discussed training for his service techs on use of torque wrenches on oil filter cap.
  18. Mar 4, 2025 at 10:12 AM
    Petro
    Petro New Member
    Dealer tight filter caps?
    Let's just call that on topic also, because I can relate.
    :cool:
    Black Wolf and AZBoatHauler like this.
  19. Mar 4, 2025 at 1:50 PM
    panicman
    Eric
    The service record, which will be of varying importance depending on the owner and their circumstances.
    Also the crying kids, crappy coffee, and the presence of the thoroughly genuine and caring car sales people.
  20. Mar 4, 2025 at 2:08 PM
    AZBoatHauler
    So.Arizona
    For me, I think the idea of maximizing resale value left when we cut the sides off.
  21. Mar 4, 2025 at 2:20 PM
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    At the other end of the spectrum: my Toyota dealership uses plastic-coated sockets to remove and reinstall the lug nuts so the black paint finish isn't marred on the lugs or the wheel. Contrast that with the GMC dealership who likely used the wrong socket when the rotated the wheels on my wife's Acadia and now all the chrome lugs are rusting where the edges were slightly rounded.
  22. Mar 4, 2025 at 2:24 PM
    equin
    Ed
    DFW, TX
    Yep! That’s exactly what I went with when I was looking for replacement bolts! Man, so much easier when I had to put it and the cat plates back on.
    RobertD and 1lowlife[QUOTED] like this.
