LED Headlight Question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Mar 4, 2025.
  1. Mar 4, 2025 at 7:38 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I'd like to upgrade my 2017 halogen headlights to OEM 2018 LED headlights. Is this possible and has anyone done this?
    Corndog123 and HulkSmurf14 like this.
  2. Mar 4, 2025 at 7:40 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  3. Mar 4, 2025 at 7:57 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yep.
    Here's a cheat sheet for ya:
    Right side TRD Pro LED headlight. Part # 81110-0C211
    Left side TRD Pro LED headlight. Part # 81150-0C211
    You will need, as you will discover, an iHacker electrical harness to make it all work.
  4. Mar 4, 2025 at 8:46 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I did the same....excellent upgrade and well worth the cost/effort! Post above has lights, then contact @iHacker for the harness- 2 differrent ones available I think, one dims the DRL when lights are on, other keeps DRL bright. The harness that keeps DRL bright is easier to wire, does not need an extra wire going into the cab.
    HulkSmurf14 likes this.
  5. Mar 4, 2025 at 9:49 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You won't regret it.
    RustyShackle323 and Y0TA PR0 like this.
  6. Mar 4, 2025 at 11:14 AM
    rodl12
    Rod
    South Jersey
    Really appreciate that! I've done a lot of research and I believe with all the 3rd market options OEM is the best way to go.
    AZBoatHauler likes this.
  7. Mar 4, 2025 at 11:15 AM
    rodl12
    Rod
    South Jersey
    Please explain "dims the DRL"
  8. Mar 4, 2025 at 11:25 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  9. Mar 4, 2025 at 12:08 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Not sure if you have amber DRLs that are your parking/turn signal lights, or the white LED strip at the bottom of the headlight for your current DRL.
    The white LED strips on the top and bottom of the OEM LED.
    The factory setup is:
    With parking/headlight off and engine running, they are bright DRLs.
    With parking/headlight on they are dim.
    IMO - You need to wire them so that the bright circuit has an IGN feed and the dim circuit has a parking light feed to take advantage of their greatness.
    Some guys just run them bright, but they are pretty bright at night and could drown out your turn signal.
    If you contact @iHacker through a PM he can give you your options and answer your questions.
    There are usually some variables on how he makes the adpater.
    I had amber DRLs on my 2014 and I liked them.
    I didn't like the bright white DRLs, because for one thing, everyone has them.
    He was able to make my adapter so that I retained my amber DRLs during the day, and I have the dim white strip DRLs at night.
    With my truck and what I wanted, my upgrade was plug and play, no extra wiring or repinning of connectors.
  10. Mar 4, 2025 at 12:38 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    BrandonL812 likes this.
  11. Mar 4, 2025 at 2:11 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    No better time to order but now with 25% off. Get on it now. Who know when they will run another sale? They will but it will be awhile.
    1lowlife likes this.
  12. Mar 4, 2025 at 4:59 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    I get lost in your avatar every time :D
    1lowlife[QUOTED] likes this.
  13. Mar 4, 2025 at 6:43 PM
    Khanhyeeast
    Khanhyeeast New Member
    Major improvement over the stock halogen!
  14. Mar 5, 2025 at 3:57 AM
    rodl12
    Rod
    South Jersey
    Plug and play would be nice.
  15. Mar 5, 2025 at 5:22 AM
    TRLDD
    TRLDD New Member
    2018 Cement Tundra CrewMax SR5
    1LowLife, thanks for posting the 25% off! It was perfect timing as I just ordered the iHacker harness from Mario yesterday. I planned to wait it out and just keep an eye out for a dealer sale on the Black TRD Pro Toyota 81110-0C211, 81150-0C211 setup. Then I log into the forum this morning and there's your post. I was just able to order the pair with the 25% off and free shipping for $464.01 OTD!! Very excited to get these installed and upgrade my night vision and it'll also be nice to get rid of the one halogen light assembly that's fogged. Thanks again for making me aware of the 25% off free shipping deal!
    SAGE63 and 1lowlife[QUOTED] like this.
  16. Mar 5, 2025 at 6:59 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    That is awesome, but I will give @SAGE63 the credit for saving you the money.
    He posted the discount on another thread.
    I think you will be happy with the upgrade.
    Make sure you mark your existing light beam before the swap.
    You might need to fine-tune the levels when you're done, but it is very easy with a long handled Phillips screwdriver.
    There are instructions here as well as YouTube videos.
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0] | Toyota Tundra Forum
    SAGE63 likes this.
  17. Mar 5, 2025 at 7:13 AM
    enve46
    enve46 New Member
    Andrew
    Personally, I went the cheaper route and got Vland LED headlights. So far Ive been more than happy with their performance and install was a breeze. At over half the cost of OEM, made a lot of sense to me
    FabioXc likes this.
  18. Mar 6, 2025 at 4:52 AM
    rodl12
    Rod
    South Jersey
    I thought of going after market but after much research even the most expensive after market headlight were problematic after a few years of use. I hope you have better luck!
    enve46[QUOTED] likes this.
  19. Mar 6, 2025 at 4:57 AM
    enve46
    enve46 New Member
    Andrew
    Me too! I read about the orange DRL overheating the housing so I wired it so it doesn’t come on except for turn signals so that should avoid that issue.
    FabioXc likes this.
  20. Mar 6, 2025 at 5:05 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Not sure what level you're wanting to go to but all I did was get the LED bulbs and put those in. I will say it's a pretty good challenge on how to get access to the headlight bulbs when you have a very big aftermarket bumper in the way. I "deleted" some cosmetic parts to facilitate a much easier change when they burn out.
  21. Mar 6, 2025 at 8:53 AM
    rodl12
    Rod
    South Jersey
    My lens are starting to fog up and rather than sanding, polishing and clear coating them to only last a few years I feel it's best to upgrade them at this point.
    Corndog123[QUOTED] likes this.
  22. Mar 6, 2025 at 8:58 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I found once you start 'polishing' headlights, they fog up even quicker..:eek2::cool:
    Y0TA PR0 likes this.
  23. Mar 6, 2025 at 3:45 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    are you applying a UV protectant sealer after polishing? I polished the headlight on our 4Runner a couple years ago and with the UV sealer they still look great.
    Corndog123 likes this.
  24. Mar 6, 2025 at 4:35 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    No, I never heard of it, that probably would have helped.
    I just remember once I started polishing my 2005 headlights, they would glaze over pretty quick.
    Same for my 2014 halogens.
    If I ever have to do my 2018+ OEM LED headlights I'll remember to put a sealer on them..:D
  25. Mar 7, 2025 at 5:00 AM
    SCTundy
    SCTundy New Member
    I went with iHacker harness and 2019 black trd pros for my 2015 1794 edition. All should be in this weekend.
  26. Mar 8, 2025 at 5:53 AM
    TRLDD
    TRLDD New Member
    Well thanks to Sage63 too!
    Appreciate the advise on marking my original aim prior to removal. I'd seen that mentioned in some of the threads. My harness from iHacker is set for delivery today and got notification from Fred Anderson Toyota that my new headlights have shipped. I'll post some before and after pics and my impressions once the install is complete. Thanks again to all on the heads up for the discount.
  27. Mar 10, 2025 at 5:30 AM
    Corndog123
    Sam
    Tennessee
    Yep, that would be what I would do too. Mine are a little foggy but only on the top edges. How did your project turn out? Were they plugged and play or did you have to delete or modify anything?
  28. Mar 10, 2025 at 7:35 AM
    Timberline
    If they're the OEM halogens then polishing the fog out of them is a waste of time compared to swapping them out for the OEM LEDs. When I bought my '16 Tundra this time last year that was my only disappointment with the truck: the headlights were no better than my 13 year older 2003 Tundra I was driving at the time. I expected projector headlights like my wife's 9 year older 2007 4Runner.
  29. Jun 22, 2025 at 10:41 AM
    TRLDD
    TRLDD New Member
    Heck, only took me 3 months to finally have time to do them. Look Fantastic, function perfectly! Thanks to @iHacker great harness nice guy to deal with.
