General Supercharger Thread
  1. Mar 2, 2025 at 7:42 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry this is happening, hope you figure it out quickly.
  2. Mar 2, 2025 at 4:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @reywcms just in case you experience a hard(bang) shift like I did in 5-6. I increased the torque reduction in all cells by 10%. This solved my issue. It mostly happened under light load throttle with the torque converter locked and unlocked. I'm also running my trans cooler at 160 deg. So it does increase the viscosity even more. Wanted to put it out there for thought.
    **Well I tried it but it came back. Hard shift under 2k rpm
  3. Mar 2, 2025 at 4:30 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Noted!
    HulkSmurf14 likes this.
  4. Mar 2, 2025 at 4:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh and it was the Upshift torque reduction table for 5-6.
    Edit. It didn't work. Same shifting next day.
  5. Mar 2, 2025 at 5:41 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    how do you run it at 160°?
  6. Mar 2, 2025 at 5:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Right now I'm straight lined to my cooler. I removed the derale inline thermostat that I had for winter. Decided to pull it when I swapped my pan and fluid. With the 50 deg temps after warm up it sits at 150-160. Will be going with the Improved Racing FSM thermostat with a 145deg pill. Want to target 160-190 deg but will see what summer temps bring.
  7. Mar 2, 2025 at 6:32 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I think when time allows I’ll be going to 40% concentration on the SC heat exchanger circuit. Should still be good to -15 degrees and give 5-8% better heat transfer. Could do the same for the engine coolant too I suppose.
    koditten, HulkSmurf14 and Mdl like this.
  8. Mar 2, 2025 at 7:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's where I'm at now with the red stuff. I don't get too cold temps but wanted that level of protection with some water wetter mixed in for both systems(intercooler).
    HulkSmurf14 and Silver17[QUOTED] like this.
  9. Mar 3, 2025 at 11:06 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Parts trickling in. New trans is here gets dropped off tomorrow
    ssmokedz, ARES35, Jego and 9 others like this.
  10. Mar 3, 2025 at 11:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I really like the one aip tube! Easier install than my JBA's...
  11. Mar 3, 2025 at 11:47 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Anyone with long tubes have a pic of their wideband sensor location I want to be sure I have clearance of where I want to weld it at
  12. Mar 3, 2025 at 11:54 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I put mine a couple inches in front of the O2 sensors in my mid-pipes
    HulkSmurf14, Mdl and reywcms like this.
  13. Mar 3, 2025 at 12:20 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I see the clearance is pretty good. I’ll be adding mine closer to the merge collector before the cats.
  14. Mar 3, 2025 at 12:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have mine pretty close to the vband/collector. I kept it within the 18-23 inches from manifold. My cats are actually after the secondary O2's...
  15. Mar 3, 2025 at 1:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got tired of the five-O 750cc extended starts and ordered the @TurboKits 880cc injectors. Looking forward to it! At least I'll have some good parts when I'm ready to do my built engine.
    ARES35, Jego, Wynnded and 7 others like this.
  16. Mar 3, 2025 at 2:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Let me know how those work-out my extended isn't bad at all but why not move to 850s if they work well.
    HulkSmurf14 and Mdl[QUOTED] like this.
  17. Mar 3, 2025 at 2:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Will do and @TurboKits is doing some mock ups for some pics of them installed. At least they are a true performance injector and not a modified OEM.
    I've changed the ECT air adder, and IC up/down 15% and this winter it either starts right up or halfway through 2nd start cycle. And Five-O says it's the tune...
  18. Mar 3, 2025 at 2:44 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Curious to hear your experience. I've recommended to multiple people, maybe dozens at this point, to go with the DW650 solely because they seem to be the most reliable (and least janky, the Prospeeds seem reliable too). I just hate how much you have to pay for such a minor increase over the TRD injectors. After you and @Wynnded experience with the 5-0 they're definitely on my never recommend list. Which leaves either small 650s or janky hack around harness with 750s. Hopefully the Turbokit ones like to start and there isn't any tuning issues, and hopefully at 43psi they're a bit smaller so not total overkill for most people.
    ARES35, Wynnded, e30cabrio and 5 others like this.
  19. Mar 3, 2025 at 2:47 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I asked him about their performance. He had them installed in his 2008 with no issues. That the 880's were smooth handling the low end.
    Here's a snippet from my email:
    The injectors drop right in and are potted with extension harnesses already soldered into place. They fit just like any factory or aftermarket injector, no modifications required. They are true performance injectors, not modified OEM, so they have amazing control at any duty cycle. Will they solve the long crank issue. Maybe, I had them in our 2008 and it was silky smooth, but I never had any long crank issue with it anyway. I am about to wrap up the 2016 TRD Pro project truck in the next week or 2 and we will be installing the 880cc in it as well. So I don’t want to oversell them as a fix for the long crank, but they are, in my opinion, the best injectors available for the Tundra platform.
    ARES35, HulkSmurf14, Wynnded and 3 others like this.
  20. Mar 3, 2025 at 2:59 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I borrowed @Wynnded five-o 750's and had the same issue. And of course his issue was resolved by going with the Prospeed ones. I've only seen a few DW 650's have that issue posted on HPT.
  21. Mar 3, 2025 at 4:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As usually happens...today no extended starts. WTF!
    Update: And tonight it took 2 cycles. Idk
  22. Mar 3, 2025 at 5:30 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    New kitchen for truck parts presentation purposes?
  23. Mar 3, 2025 at 5:31 PM
    ZPhilip
    Philip
    West Chester, PA
    I had the extended starts with the DW650s for a while but sometime in the tuning revisions it was fixed somehow and hasn’t returned.
  24. Mar 3, 2025 at 6:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    yesssir
  25. Mar 4, 2025 at 1:19 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Do companies just sell the individual S/C's? I haven't really called around yet. Been thinking either Whipple or Harrop when the time comes. I'm not in a position right now but tried searching even for a used one.
    HulkSmurf14 and reywcms like this.
  26. Mar 4, 2025 at 1:43 PM
    e30cabrio
    Magnuson said 4k for just the 2600 if I wanted to upgrade.
    Silver17, HulkSmurf14 and Mdl like this.
  27. Mar 4, 2025 at 1:45 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Maggy does from the 1.9 to 2650. I’m waiting for colton to hear back from Whipple if the gen6 3.0 is an upgradable option. If so I’ll have a 2.9 available at some point
  28. Mar 4, 2025 at 1:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was going to ask you if you were planning an upgrade as you just had it serviced...I'm interested. But I'm still planning a move but not many offerings out there in my price.
    reywcms[QUOTED] likes this.
  29. Mar 4, 2025 at 2:06 PM
    Silver17
    Eastern PA
    Harrop used to advertise an upgrade kit for the 1900 to 2650, haven’t seen it advertised lately but I bet if you email
    ryan.dinkel@harrop-usa.com or Chris.Mentrup@harrop-usa.com you can find out quick. Magnuson does too as stated, not sure about Whipple.
  30. Mar 4, 2025 at 2:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks for the contacts!
    e30cabrio and Silver17[QUOTED] like this.
