Remote Tailgate Lock
Discussion in '2.5 Gen Tundras (2014-2021)' started by retho78, Feb 28, 2025.
  1. Feb 28, 2025 at 6:07 AM
    retho78
    retho78 [OP] New Member
    2015 Toyota Tundra Limited
    Hi,
    I am looking to install a remote tailgate lock kit on my 2015 Tundra Limited and have seen the Pop N Lock kit PL8547TUN and the Toyota OEM kit, part PK3B6-34JS0. However, there's an aftermarket kit that's similar to the OEM style on Amazon for about $70, and have anyone installed it and had great success? I am curious if I should go with the $130 (Pop n Lock) $230ish for OEM, or the $70 for the aftermarket OEM style.
    Thanks.
  2. Feb 28, 2025 at 6:35 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    For some reason I thought the pop and lock was the OEM.....at any rate, I used the pop and lock and it works great. Have had it on for about 5 years. Last year, I had to open the tailgate and clean dirt and grease the mechanism because it was getting hung up, but otherwise works great.
    Saltyhero13 and retho78[OP] like this.
  3. Feb 28, 2025 at 6:58 AM
    retho78
    Awesome! Thank you.
  4. Feb 28, 2025 at 9:22 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Hard to know without looking at the actual $70 "OEM style" kit looks like.
    The biggest thing to look for is that the kit is true plug and play. Some of the older kits required splicing/tapping the factory harness. Beside that it is probably the same stuff or function similarly.
    FYI someone posted DIY instructions for a homebrewed kit; I think total was ~$20.
  5. Feb 28, 2025 at 9:27 AM
    retho78
    It is a plug and play. I think it does not come with instructions, but I found the OEM and youtube videos that'll provide guidance to install it. Please see link below.
    https://www.amazon.com/dp/B0D3WYYYL8
    Saltyhero13[QUOTED] likes this.
  6. Feb 28, 2025 at 9:30 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'd pass on that one.
    This makes no sense, the mechanism has NOTHING to do with the camera.
    The Pop and Lock is literally plug and play.
    It gives you an adapter for the lock/unlock feed..
    I would go with it..
    Amazon.com: POP & Lock - Toyota Tundra Heavy Duty Power Tailgate Lock with Plug and Play T-Harness : Automotive
  7. Feb 28, 2025 at 9:37 AM
    retho78
    I saw that about the connector to the camera which made no sense.
    Thanks
    1lowlife[QUOTED] likes this.
  8. Feb 28, 2025 at 9:51 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I had the old style P and L on my 2014 Tundra, and I just replaced the actuator with the new style.
    The old one was getting to where it wouldn't lock/unlock every time, but it was 10 years old.
    The actuator is much better and quieter now, and as well easier to install...
    [​IMG] [​IMG]
    I now see you can order the replacement actuator if that happens again.
    I couldn't find it before and ordered the entire kit.:eek2:
    Replacement HD Actuator
    Sometimes you get what you pay for, I feel this is one of those times.
    Good luck..
  9. Feb 28, 2025 at 11:44 AM
    retho78
    I ordered the $70 "OEM style" kit from Amazon and if it doesn't work, then I'll return it. I'll post an update when possible.
    Saltyhero13 likes this.
  10. Feb 28, 2025 at 11:47 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Good luck
    retho78[QUOTED][OP] likes this.
  11. Feb 28, 2025 at 12:21 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    1lowlife and retho78[OP] like this.
  12. Feb 28, 2025 at 4:45 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I’ve had the oem one for about 2-3 years now. No issues at all and very easy to install
    retho78[OP] likes this.
  13. Feb 28, 2025 at 10:17 PM
    retho78
    Okay, thank you. I'll give it try with the OEM style kit and see what happens.
  14. Mar 2, 2025 at 8:20 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
  15. Mar 2, 2025 at 8:25 AM
    retho78
    Js18tundra[QUOTED] likes this.
  16. Mar 2, 2025 at 9:13 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    It should, there is no difference in that part of the truck from 2014 to 2021.
    Maybe even 2007 to 2021.
    Accessory Installation Instrucution Template
  17. Mar 2, 2025 at 10:19 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I'm late to this party, but I'll still throw my experience in for posterity.
    I installed the Pop 'n Lock that was available in 2019 for $91. IMG_3012.jpg
    installation was a breeze, and this unit still works like it did when I installed it over 5 years ago. My only minor criticism is that it is a little loud, but I don't notice it anymore, and have learned to count on hearing the "thunk" when it actuates.
    My brother in law spent the $200+ on the Toyota kit. It did look and feel a little more high quality when it arrived, and it was noticeably quieter. He sold his Tundra shortly after.
    I am always wary of buying the cheapest option, but we won't know until someone takes the plunge. Do the community a favor, and let us know how the kit works.
    retho78[OP] and 1lowlife like this.
  18. Mar 2, 2025 at 10:24 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Yes, you have the old style like I did.
    It's a bit noisier than P&L's newer style actuator..
    [​IMG][​IMG]
    retho78[OP] and panicman[QUOTED] like this.
  19. Mar 2, 2025 at 4:43 PM
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    It was one of the first things I did to my truck. Totally worth it. I was actually surprised that my 1794 didnt have a power locking tailgate from the factory.
    sonofdad and retho78[OP] like this.
  20. Mar 7, 2025 at 3:50 PM
    retho78
    Update - installed the "OEM style" aftermarket kit and everything works so far. There was a hiccup with the functionality. The short wire pins on the actuator that connects to the longer wire were reversed, so it was doing the opposite when I locked or unlocked it. I just de-pinned and switched the two pins in the harness and now everything works as is. I'll post another update if there's any issues with it.
    BrandonL812 likes this.
  21. Mar 7, 2025 at 5:44 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Glad it worked out for you..
    Funny when I replaced my old Pop and Lock actuator with the new one, same color wires, it did the same thing.
    Lock/unlock was backwards from the truck, I just cut wires and resoldered.
    Looks like your kit actually connects to the lock mechanism with no slack.
    The P&L just pushes it one way and then the other leaving slack in between them..
    I like yours..:thumbsup:
  22. Mar 7, 2025 at 5:49 PM
    retho78
    Thanks. Yes, just a very little slack on the mechanism. It's not too loud either.
