General Supercharger Thread
  1. Feb 27, 2025 at 11:26 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was curious as the AISIN WS fluid has a similar viscosity as Dex3, 7.3 vs 7.1 at 100deg C. AISIN being mostly synthetic and DEX conventional...does Dex have better bite on the clutches? Dex3 doesn't have a lot of the modifiers that most synthetics have.
    Just thinking if one were to still want the WS fluid, AISIN 7.3, with a thicker viscosity than Toyota WS 5.4 viscosity.
    As we know superchargers like to eat Transmissions.... when given a little bit more boost.
  2. Feb 28, 2025 at 5:59 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Another option is Amsoil. I’ve been running Amsoil Signature ATF (ATL) for 60k miles and the trans hasn’t died yet. The Amsoil has a higher viscosity than WS and synthetic with a 6.3 cSt at 100C.
  3. Feb 28, 2025 at 6:22 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    That's what I used, 2 years ago, I did a partial with 6 quarts, just now they did the full drain when the TQ converter & filter was replaced. I have 4 more to top it up if need be (and over fill some)
    I have been alittle preoccupied with weird limp mode & this....
    ssmokedz and HulkSmurf14 like this.
  4. Feb 28, 2025 at 7:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was running the Amsoil when my transmission roasted. Not that it means anything though, seeing as how I was tweaking the tune as much as I was.
    HulkSmurf14 likes this.
  5. Feb 28, 2025 at 7:41 AM
    e30cabrio
    That's cheery.
  6. Feb 28, 2025 at 7:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  7. Feb 28, 2025 at 7:48 AM
    e30cabrio
    I think that's an apple.
    lol
  8. Feb 28, 2025 at 7:57 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Nah, a Swoll Cherry, is all!
    M3Tundra-JK, Mdl and e30cabrio like this.
  9. Feb 28, 2025 at 7:58 AM
    e30cabrio
    Maybe it's an apple holding 2 cherries!
    On topic? Who needs ontopic???
    :D
    Mdl, sbxx312 and HulkSmurf14 like this.
  10. Feb 28, 2025 at 11:12 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just ordered a new coupler from zzperformance for the 1900. I replaced it before in 2015. It's a rattling oh and my driver side cat is too. At least the converter is under warranty.
    HulkSmurf14, reywcms and e30cabrio like this.
  11. Feb 28, 2025 at 12:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    https://youtu.be/9AtuVIrd7iY
    e30cabrio and Mdl[QUOTED] like this.
  12. Feb 28, 2025 at 1:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    e30cabrio and Wynnded[QUOTED] like this.
  13. Feb 28, 2025 at 2:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would probably sound more akin to a mongoose being stuffed into a garbage disposal.
  14. Mar 1, 2025 at 10:18 AM
    e30cabrio
    Had a sporadic miss in #7 so swapped the new plug & Denso coil to 1.
    The orange tinge is from octane boost I used on CA. gas
    7
  15. Mar 1, 2025 at 10:26 AM
    centex
    centex New Member
    Electrodes look a little worn.
  16. Mar 1, 2025 at 10:58 AM
    e30cabrio
    That's the way they came, they have under 100 miles. I put them in after the L.A. Drive. There was still CA gas in the tank.
  17. Mar 1, 2025 at 11:00 AM
    e30cabrio
    Here is one where you can see it better.
    Here is how they are new.
  18. Mar 1, 2025 at 11:13 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    It's always hard to judge spark plugs but those look pretty nasty. In the email #1 looked pretty good but #7 definitely had the looks of misfiring
  19. Mar 1, 2025 at 11:28 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    ooo man thems are naaaaasty!
  20. Mar 1, 2025 at 11:58 AM
    centex
    centex New Member
    Ok. First pics didn’t look like the nub was there. But if that’s after a 100 miles that’s still looking pretty rough. These are mine at 75k.
    With the issues you were having, I’d swap the plugs out. These may be fouled.
  21. Mar 1, 2025 at 12:01 PM
    e30cabrio
    Trying to get the truck's new motor dialed in. It is being a dick.
  22. Mar 1, 2025 at 5:17 PM
    e30cabrio
    Got some logs, had misses on cyl 1,remembered I put a crappy AutoZone accel pedal in. I have had weird idle in neutral & park, put the 143k oem in & the truck feels better & the surging idle is gone.
    Pulled the plug form 1 (that was in 7) it looks better, I cleaned it & put it back. No misfire, got to 9.8LBS.
    Plug in 1 from 7 before cleaning.
    After cleaning.
    Denso coil.
    Maybe......
  23. Mar 1, 2025 at 6:28 PM
    e30cabrio
    I finally used the hose protection that came with the 300.00 TRD hose kit.
  24. Mar 1, 2025 at 7:35 PM
    e30cabrio
    2 drives, no limp, no codes. It feels good, I think it needs to learn.
  25. Mar 1, 2025 at 8:28 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hey guys... Looks like Fred Anderson has the 25% off plus free shippping sale going on now in case anyone needs anything...
    Also, for those of you that have done a tranny cooler (which I think is all of you ;)), does this list of parts in my cart appear to be complete for what I need to complete the install... and confirming there's nothing on the list that really isn't needed, correcct???
    Also, it seems weird to me, but Toyota parts website is always strange in how it labels; like the T-stat is called the Oil Cooler Assembly w/T-stat. So, just confirming that's the "thermostat" that everyone purchases for these installs and not a 'complete' OE trans cooler (like I have on my '08), right???
    Finally, should 12qts of fluid get me through this intall w/a drain n fill, plus have enough to complete another drain n fill down the road??
    Thank you all :hattip:
  26. Mar 1, 2025 at 8:36 PM
    You do early morning sober shopping…… stop it!!!!
    But 12qts should be more than plenty for 2 drain n fills.
  27. Mar 1, 2025 at 8:50 PM
    Tripleconpanna
    See, it's a good thing I'm not making it to T2S this year... otherwise I'd be bringing a little project for y'all to help me out with :spy:
    Ponderosa_Pine likes this.
  28. Mar 1, 2025 at 8:57 PM
    You haven’t met @RUSTYNUTS ………
    The king of camp mods and repairs!
  29. Mar 2, 2025 at 7:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Continuing on the crank no start problem solving. We've got fuel pressure at the rail so now onto no spark testing.
    HulkSmurf14 and Wynnded like this.
  30. Mar 2, 2025 at 7:41 AM
    e30cabrio
    These are some of the parts I have.
    HulkSmurf14 and Tripleconpanna like this.
