Differential and Tcase oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pierceson, Feb 27, 2025.
  1. Feb 27, 2025 at 7:45 PM
    Pierceson
    Pierceson [OP] New Member
    WILLINH likes this.
  2. Feb 27, 2025 at 7:50 PM
    Superdave1.0
    Superdave1.0 New Member
    Dave
    LX470, 2025 Civic Si
    For front and rear diff most gear oils are fine. I like Valvoline in the Flex fill bags. Makes adding the gear oil super easy.
    I would do some research on the T-Case. I know that 4runners and Tacomas after a certain year require a different fluid than your normal GL5 diff fluid found these days.
    ATV25 and Pierceson[OP] like this.
  3. Feb 28, 2025 at 6:40 AM
    Pierceson
  4. Feb 28, 2025 at 7:31 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    I personally went with Amsoil Severe Gear 75-140w oil in the diffs (the collapsable bags), and Ravenol 75W in the T-case. Jury is still out on the Ravenol, but I've seen mostly positive things posted. I can always change it out, but the factory stuff is like $75-85 a quart (if you can find it) and requires 2 quarts. If the Ravenol doesn't work out so well, I'll go OEM on that one. Will check in a few more months to see fluid condition. The fluid that came out looked super clean (did all of this at 45K miles) but I'd also read many others when draining and refilling it was clean coming out if changed at a decent interval. I tend to spend more on maintenance, and shorter intervals for the longevity of the truck.
    ATV25 likes this.
  5. Mar 1, 2025 at 5:01 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Ravenol 75w is what I am going to use in Tcase if I ever get to it. I changed it at 50k in Tacoma and could not tell used oil from new. Tcase oil is last thing on my list. After what I have read on this forum I would not use anything in tcase other then 75w with proper specs.
    ATV25 likes this.
  6. Mar 1, 2025 at 5:06 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    +1 for Ravenol 75w. The bottle with the long straw makes the fill up extremely easy as well.
    Edit: in the T-Case that is, not the differentials.
  7. Mar 1, 2025 at 5:06 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    OCI thread related.
    F/R Differential: 30k (OE or aftermarket). -- 75w-90 Amsoil Severe Gear
    Transfer Case: 30k (OE or aftermarket) -- 75w Ravenoil
    OCI non-thread related.
    Oil & Filter: 5k miles or 6mo. -- Pennzoil Ultra Platinum 5w-30
    Transmission Fluid (drain/fill): 30k or 6yrs. -- OE Toyota Brand.
    Coolant: 50k miles or 5yrs. -- OE Toyota Brand.
    Power Steering Fluid (OE or aftermarket Fluid) -- OE Toyota Brand.
    Brake Fluid DOT 3, inspect at 3 years (aftermarket)
    Sparks Plugs: 120k (OE)
    ATV25 and BrandonL812 like this.
  8. Mar 1, 2025 at 7:02 AM
    Yoymon
    Yoymon New Member
    2015 tundra
    Amsoil
  9. Mar 2, 2025 at 2:34 PM
    Chip_Tundra
    Chip_Tundra New Member
    Henry1jg and Superdave1.0 like this.
  10. Mar 2, 2025 at 2:52 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I checked with my dealer and they use 75-90 in differentials and transfer case. They said they only use 75 when warranty is involved. I used 75-90 synthetic in all and no problems goin and out of 4 wheel drive.
  11. Mar 2, 2025 at 5:10 PM
    Superdave1.0
    Dave
    Yeah and they use it out of a huge drum, which is assumed to be lower quality. Most shops use the same oil for all 3. Doesn't mean it's correct. The T case takes a different fluid per Toyota. And Toyota sells a specific T case fluid that is super expensive.
    AZBoatHauler likes this.
  12. Mar 2, 2025 at 6:40 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  13. Mar 2, 2025 at 6:41 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    from Toyota to one of the members,
    Tiptop93, Y0TA PR0 and Js18tundra like this.
  14. Mar 2, 2025 at 7:36 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    The big distinction here is GL4 oil for the T-case and GL5 for the differentials.
    GL5 (hypoid gear oil) has higher levels of sulfur that can damage/corrode T-case synchronizers.
    Different oils for different applications.
  15. Mar 3, 2025 at 8:31 AM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Chip_Tundra likes this.
  16. Mar 3, 2025 at 8:39 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :monocle:
  17. Mar 3, 2025 at 8:43 AM
    AZBoatHauler
    So.Arizona
    Kind of like saying “I do the right thing when someone is holding me accountable.”
  18. Mar 3, 2025 at 9:18 AM
    yakeng
    yakeng 3URFE Apologist
  19. Apr 17, 2025 at 6:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    14crwmaxltd likes this.
  20. Apr 18, 2025 at 3:39 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I use this in my t case, it shifts in 4WD way faster than any other fluid I’ve tried. A lot of the 4Runner/taco guys run it in their cases.
  21. Apr 18, 2025 at 12:58 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    Redline MT-LV is a solid option too for the tcase. Have it in both my Tundra and the wife's Sequoia.
  22. Apr 18, 2025 at 2:28 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Contact the cordial and nice people at boutique Red Line. :militarypress:
    yakeng likes this.
  23. Apr 19, 2025 at 6:57 AM
    Js18tundra
    You contacted sales associates/ customer service reps. Not engineers, their system says there is no substitute, that’s what they are telling you. They aren’t going to recommend an oil they haven’t deemed as an acceptable replacement. If you are looking for an Amsoil fluid that works well in our transfer cases by Amsoil, I’ve been using their syncromesh fluid, it’s been working great and a lot of the tacoma/4runner guys have been using it also. I’m not sure why Amsoil hasn’t added it to their substitutions list.
    14crwmaxltd[QUOTED] likes this.
  24. Apr 19, 2025 at 7:19 AM
    blenton
    blenton New Member
    I'm giving the MT-LV a go in my '21. 15% off at Oreilly's if you select ship to home.
    Red&03Taco[QUOTED] likes this.
  25. Apr 20, 2025 at 5:36 AM
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    I just changed mine the other day. I used Amsoil 75W85 in the front and rear diffs. I used Redline MT-LV in the transfer case. The MT-LV specifically says it can be used in place of the Toyota 75W transfer case oil on the bottle.
    Red&03Taco and 14crwmaxltd like this.
