Heater knob wont rotate all the way.
Discussion in '1st Gen Tundras (2000-2006)' started by Outbound, Apr 4, 2019.
  1. Apr 4, 2019 at 12:58 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    I noticed this awhile ago but now have time to adress it. My heater kob will only turn 3/4 of the way clockwise. I can force it all the way but once I let go it springs back. My dad has a 05 Tundra and his heater knob goes all the way.
    Thoughts?
    Here's a pic of the temp knob at its max setting.
    G_unit3000 likes this.
  2. Apr 4, 2019 at 1:03 PM
    How difficult is it to remove that panel that the knob is located on?
  3. Apr 4, 2019 at 1:29 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    I can't remember but does the knob only go on one way if not them try to remove and reinstall so its all the way to heat. Then turn to cold and see if it goes all the way
    truckee_mctruckface likes this.
  4. Apr 4, 2019 at 1:40 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Pull it out and see if there are problems.
  5. Apr 4, 2019 at 1:59 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    DO NOT FORCE! It will break. The cable needs to be adjusted, I attached a pdf file on how to do this.
    good luck, john
  6. Apr 4, 2019 at 2:00 PM
    Well done!
  7. Apr 4, 2019 at 2:21 PM
    Outbound
    Aaron
    Northern Alberta
    Shouldn't be too bad. I have to remove it anyways when I replace all the lights back there. None of my HVAC controls light up anymore. LOL
    Awesome stuff! Thanks!
  8. Apr 4, 2019 at 2:22 PM
    Might as well kill two birds with one stone.
  9. Apr 4, 2019 at 2:23 PM
    Outbound
    Aaron
    Northern Alberta
    That's what I figure and the reason I posted this today. As the weather smartens up, my list of updates/maintenance to the truck grows...
    Not enough hours in a day to do all I want. I wish I had a @Professional Hand Model kicking around who had all sorts of time to tinker on my truck for me. :D
  10. Apr 4, 2019 at 2:25 PM
    Yeah, the weather is getting nice here so it's time to get caught up on things finally.
    Outbound[QUOTED][OP] likes this.
  11. Apr 4, 2019 at 2:45 PM
    NMTundra
    NMTundra New Member
    Decent chance that your knob just needs to be pulled off and put back on. Mine would look like it was going all the way on the cold side but was actually only mid way through the cold band when I first got it. .
    Weagle and Outbound[OP] like this.
  12. Apr 4, 2019 at 2:50 PM
    Fred
    Hand Protectors
  13. Feb 22, 2024 at 1:55 PM
    motoboh
    motoboh New Member
    Does anyone know of a link to removal/installation instructions or video for the heater control, to include replacement of the 3 cables? And my apologies is it's posted here, I just haven't had any luck finding it, thanks to all!
  14. Feb 22, 2024 at 3:06 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    dang you’re from my hometown!
  15. Feb 22, 2024 at 3:15 PM
    FSM can be downloaded here, in the 4th/5th paragraph: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    This thread may help, tons of videos in the 1st page: https://www.tundras.com/threads/vent-control-binding-solved.58386/
  16. Feb 23, 2024 at 2:05 PM
    motoboh
    motoboh New Member
    Thanks so much for these links, Shifty, it's greatly appreciated!
  17. Jan 12, 2025 at 8:56 AM
    zingvs
    zingvs New Member
    Zander
    2001 4x4 SR5
    :typing: Sorry to revive this dead thread, but I was having the same issue with the heat/cold knob, and it ended up being that the previous owner had positioned a coolant hose clamp at the firewall improperly causing the heat controlling arm to get stuck on the hose clamp at 3/4 turn to the right. If anyone else has this issue check that first before getting under the dash.
  18. Jan 14, 2025 at 11:45 PM
    Khunter0211
    Khunter0211 New Member
    '05 DC Limited V8/4WD
    Where did you get the pdf file from? Thanks,
  19. Jan 17, 2025 at 12:16 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    FSM
    Khunter0211[QUOTED] likes this.
  20. Jan 17, 2025 at 12:30 PM
    And in the event you ever forget, that and everything else literature-wise you'll EVER need for your truck is right at the top of the community megathread. All questions, problems, and reference start at the community megathread.
  21. Feb 22, 2025 at 6:00 PM
    RegularCab
    RegularCab New Member
    Tundra 06 RC 4.0 V6
    Thanks to all of contributed to this thread! I am a new member but have owned 2 1st gen Tundras since 2008. I am so happy you guys took the time to post your solutions. After cleaning the manual actuator, the mode control still required more torque than the knob was designed for. I fixed it by grinding/sanding the shaft inside the heater control unit. I have attached the photo posted by user Backdoor.
    shifty` and FrenchToasty like this.
  22. Feb 26, 2025 at 9:23 PM
    Khunter0211
    Thanks for adding another solution to this problem. Which part of the shaft did you sand? Thanks
