Ghosting effect on HUD
Discussion in '3rd Gen Tundras (2022+)' started by TundraCan, Feb 26, 2025.
  1. Feb 26, 2025 at 6:13 PM
    TundraCan
    TundraCan [OP] New Member
    Why I am seeing doubles on my HUD. It is set to the highest setting but I am also seeing doubles on lower setting. It is not crisp looking. Anything I need to do to fix this? Is it because the windshield ceramic tint that I installed? Many others have ceramic tint but no ghosting effect www.tundras.com/threads/windshield-tint-and-heads-up-display.126717/page-2
    This is a brand new 2025 truck I picked up in mid February.
    UPDATE: March 19, 2025
    Just want to provide update on the ghosting issue on my 2025’s HUD. I know almost all of you believe that it was the window tint that caused the issue. I can confidently say now that it is not. I brought the truck to my window tint installer and he removed the tint. The same ghosting issue still exists even without the window tint. So it looks like this is a manufacturing defect. I have reached out to my local dealership and will attempt to get them to fix it. Not sure if this issue is caused by the windshield glass or the HUD unit.
  2. Feb 27, 2025 at 6:32 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    It's probably the tint, I saw this often when I worked at a BMW dealer thru college. I believe some tints have internal reflection from their manufacturing process so it acts like two layers of glass with an offset.
  3. Feb 27, 2025 at 6:33 AM
    sudobash
    sudobash New Member
    The tint is causing this issue.
    1lowlife and Woodrow bangs like this.
  4. Mar 1, 2025 at 9:18 PM
    TundraCan
    UPDATE: I put my phone on the dashboard and on top of the HUD to test and I can see ghosting too with my phone display. So for sure it is not the HUD. It has to be either the windshield or the tint.
  5. Mar 2, 2025 at 2:33 AM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    lets eliminate the windshield...
  6. Mar 2, 2025 at 6:02 AM
    rjls
    rjls New Member
    Weird. I have the HUD and my windshield is tinted, but no ghosting effect.
    Breathing Borla likes this.
  7. Mar 2, 2025 at 7:11 AM
    Breathing Borla
    AZ
    me too , 80 ceramic , mine actually looks cleaner now
  8. Mar 2, 2025 at 8:46 AM
    mayan
    Mayan
    DFW
    Probably a dumb question but did your installer lay the film on the inside or outside? And manufacturer and product line?
    rjls[QUOTED] likes this.
  9. Mar 2, 2025 at 9:01 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My first thought was the windshield has been replaced with a non-HUD glass.
  10. Mar 2, 2025 at 9:44 AM
    Breathing Borla
    AZ
    ? What do you mean, like the tint?
    That is always on the inside
  11. Mar 3, 2025 at 5:21 AM
    TundraCan
    I know. Mine on other vehicle also had one and no ghosting issue. Which led me to believe maybe the tint make and type is causing the issue.
  12. Mar 3, 2025 at 7:20 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    same
  13. Mar 3, 2025 at 7:30 AM
    DRP
    DRP Old Member
    Dave
    Did the ghosting occur prior to the tint you had installed?
  14. Mar 3, 2025 at 7:40 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That would drive me insane.:eek2:
    I'd have to turn it off...:(
  15. Mar 3, 2025 at 12:19 PM
    TundraCan
    I don’t think so.
  16. Mar 5, 2025 at 2:25 PM
    TundraCan
    Update:
    The tint installer was able to get a hold of another 2025 Tundra. The interesting part is even the one without tint has some ghosting. Is this normal for Toyota HUD?
  17. Mar 5, 2025 at 2:33 PM
    Breathing Borla
    AZ
    mine is clear as a bell with tint
  18. Mar 5, 2025 at 4:02 PM
    eddiefromcali
    Eddie
    100% Stock
    Tinted shield, raining, no ghosting
  19. Mar 5, 2025 at 4:11 PM
    TundraCan
    I can see faint ghosting on yours too. Just like on my post #16. But not as bad as the original post #1.
  20. Mar 5, 2025 at 4:24 PM
    eddiefromcali
    Eddie
    100% Stock
    Not there...its a camera thing.
  21. Mar 5, 2025 at 6:08 PM
    TundraCan
    Ok thanks
  22. Mar 6, 2025 at 5:14 AM
    TundraCan
    March 6 UPDATE: I added seven more pictures that the installer sent. He installed different tints on the 2025 Platinum loaner to show that ghosting still exists (even though it is much more less). He said he never seen this on any other vehicles in the last 30 years in the business. ‍♂️ so far from what I gathered based on the pictures that he sent is that very minimal ghosting exists on 2025 platinum loaner that he has whether window tint is installed or not. I really don’t know what to say at this point other than I have to come in and see it in person versus looking at the pictures that he sent. We can see that he actually took his time to get the loaner from a dealership and performed the tests. He is located about 1.5 hours away from me so that’s why I haven’t gone back to see him. What are the chances that there is defect on my Tundra and his loaner coincidentally?
    mayan likes this.
  23. Mar 6, 2025 at 7:32 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I had a Platinum loaner for a week last year while they repaired my cam tower leak.
    I think the HU display did have a bit of ghosting or blurriness.
    I remember thinking it was cool at first, but the blurriness messed with my vertigo, so I turned it off.
    Is it possible something is on the 'lens' and it's distorting the projection?
  24. Mar 13, 2025 at 7:14 AM
    TundraCan
    March 13 update
    To: 2025 Platinum owners only. Can you please check your HUD and confirm if you see any ghosting/double image? My local Toyota checked a different unit and he said the issue also exist on the unit. He will be checking on another unit. I wonder if this is a windshield manufacturing defect on this particular trim.
  25. Mar 13, 2025 at 7:29 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I suspect you are correct. Just for information purposes Google AI gave this description of a HUD windshield.
    Yes, vehicles with Heads-Up Displays (HUDs) typically require a special windshield because they need a specific type of windshield with a wedge-shaped PVB layer to ensure a clear and sharp image projection, preventing ghosting or double images.
    Here's a more detailed explanation:
    • Wedge-Shaped PVB Layer:
      The windshield for a HUD features a PVB (polyvinyl butyral) layer with a wedge shape, which is different from the standard parallel PVB layer in regular windshields.
    • Preventing Ghosting:
      The wedge shape helps to refract the image in a way that prevents the driver from seeing a double or "ghosted" image of the HUD display.
    • Sharp and Clear Image:
      The special windshield design ensures a sharp and clear projection of the HUD information onto the windshield, making it easy for the driver to read.
    • Special Coatings:
      Some HUD windshields may also have special coatings to further enhance the image quality and visibility.
    • Cost:
      Replacing a HUD windshield is more expensive than a standard windshield replacement.
    Raven67 likes this.
  26. Mar 19, 2025 at 2:08 PM
    TundraCan
    March 19 update:
    DRP and eddiefromcali like this.
  27. Apr 5, 2025 at 4:45 PM
    TundraCan
    April 5 update
    Update regarding my HUD ghosting issue on 2025 Platinum.
    My Toyota dealership has agreed to replace the windshield for free. Toyota Canada will supply the OEM windshield. But I learned that they sub contract the work to a third party to do the work.
    Should I have 100% confidence that they will do a great job and will have no issues with wind noise and water leak and etc. ? What is the chance of this happening?
    I am happy that they will replace the glass but at the same time I am worried that something will get f*** up. They also said that they cannot test the new windshield to ensure no ghosting.
  28. Apr 5, 2025 at 5:20 PM
    Breathing Borla
    AZ
    don’t worry about that dealers usually always sub that out, it’s actually better as they experienced glass guys do it rather than the Toyota techs
    so relax and let them work
  29. Apr 9, 2025 at 5:47 PM
    TundraCan
    I was relax and guess what majority of them went fine except that they cracked my screen protector and it will cost me $50 to replace. This is why I am always nervous taking a vehicle that I baby to any shop. The glass technician has been in the business for 35 years. The dealership told me that he will give me discount when I go back for service. I just smiled and in my mind no I will not because I will be changing my own oil.
  30. Apr 9, 2025 at 5:48 PM
    TundraCan
    UPDATE: for those of you who followed my posts regarding my issue with ghosting/double image on HUD, Toyota agreed to replace my windshield. It was never the tint that caused the issue.
    Today, the windshield was replaced and I am happy to say the issue is fixed. The dealership told me that Toyota installed the incorrect windshield. No more ghosting. The second picture during the night to show the issue prior the fix.
    DRP likes this.
