Windshield tint and Heads Up display
Discussion in '3rd Gen Tundras (2022+)' started by BoulderGT3, Jun 27, 2023.
  1. Oct 22, 2024 at 5:50 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I did 35% on front side windows, 20% on sunroof & nothing on windshield. The ceramic cuts out so much heat from the sunroof, I can actually enjoy it now.
  2. Oct 22, 2024 at 7:23 AM
    Breathing Borla
    Northern Illinois
    here is an assortment in different sun angles
    let me know if you want anything more. You have to be careful here as windshield and anything more than 50% on the front is illegal, so I already was a notch past that and wanted to make sure you can still see. The 35% front and 50% everywhere else then 80% on the windshield is perfect for me and in states that watch this closer. The officers can still see you moving around and see inside so they leave you alone with it. go 100% ceramic for the heat blocking though, totally worth it.
    good luck
    KevKev_22[QUOTED] likes this.
  3. Oct 22, 2024 at 7:26 AM
    Breathing Borla
    Northern Illinois
    throw some 80% on the windshield if you like the heat reduction from the pano, you'll love it and it actually helps seeing out night and day as the glare it cut down
    Raven67[QUOTED] likes this.
  4. Oct 22, 2024 at 9:48 AM
    KevKev_22
    KevKev_22 New Member
    2024 tundra platinum
    Thank you so much. 35% on front is the legal limit here. I wasn’t sure how the 50% on the rear would look (on top of the factory tint) alongside the 35% front. But yours looks great. Also, 80% on the windshield isn’t even noticeable which is what I was hoping for.
    how is the visibility out of the rear, driving at night? I may even go slightly lighter at like 60% in the rear just to avoid it being too dark.
    Either way, I appreciate the pictures!!! Thank you.
  5. Oct 22, 2024 at 10:01 AM
    jaxadam
    jaxadam New Member
    65% on windshield with HUD and no issues.
  6. Oct 22, 2024 at 10:23 AM
    Breathing Borla
    Northern Illinois
    I have no problem at night at all. but I also have a camera rear view mirror, but if you switch it off you can see fine, you won't have a problem with 50% over the factory, I wouldn't go darker than that though FWIW
