General Supercharger Thread
  1. Feb 26, 2025 at 8:48 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    These are the voltages for the ProSpeed injectors I sold you, at 70PSI they are essentially closer to 800cc
    snivilous[OP], Mdl and e30cabrio like this.
  2. Feb 26, 2025 at 9:30 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    On the old motor it was at 52 or so, with the new one it is over 70, Sniv said leave it alone so I did. :p
  3. Feb 26, 2025 at 10:29 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous @Jowett
    For the deeper PML and B&M pan to lower filter deeper. Is it easy to chuck a piece of aluminum pipe in a lathe and reduce outside and inside openings to accommodate the valve body and filter. Not sure on length and transmission pumps ability to pull lower?
    Fab up some spacers for longer bolts.
    Thoughts?
    Excuse my piss poor drawing and lack of opening measurements as I don't have a filter to grab the measurements.
  4. Feb 26, 2025 at 10:49 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Don't see why that wouldn't work.
    You could also put a nozzle extension on the filter itself, not sure of a nice way to go about that besides tapping into the filter which seems undesirable, flip side is if there's any issue with the extension sealing you'll still pick up fluid unlike the top side extension.
    If you can grab dimensions I can throw something on the lathe this week.
  5. Feb 26, 2025 at 10:54 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The suction side is an oval shape. Unless someone 3d prints and adapter and use fipg/rivets to secure it in place?
    I thought of cutting the old filter suction apart and that would give maybe 3/4 inch extra.
    I'll see if the old filter is in the trash...thanks!
  6. Feb 26, 2025 at 10:56 AM
    snivilous
    SW UT
    I can cut a bottom side extension on the mill too. I definitely think the top side extension is the most straightforward, but food for thought is all.
    e30cabrio likes this.
  7. Feb 26, 2025 at 10:58 AM
    snivilous
    SW UT
    I don't know if there's really a downside to higher pressure assuming the pump is keeping up and the fuel isn't getting too hot. 70psi is definitely up there, but to me it makes no difference what the pressure is at so I told Stefan just leave it as is since I had already setup the tune and it was running fine so why change it.
  8. Feb 26, 2025 at 11:48 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Needs an O-ring for the top side of the adapter, too.
    Will the baffles clear the filter in the new the lower position?
  9. Feb 26, 2025 at 12:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have an extra o-ring for that, thanks for the things to look at. I'm actually dropping the pan this afternoon. @snivilous I'll measure the valve body opening to get an accurate measurement and will verify max length. I was thinking even an extra 1- 1.5 inch would help.
    I'm on generator power until tomorrow night from our wind storm, but oh well. Work on...
  10. Feb 26, 2025 at 12:38 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Well let me know if this extension will happen for the pick up I’ll add one to mine while it’s apart soon. Dex3 arrived
  11. Feb 26, 2025 at 1:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok. I filled and flushed mine with dex3 but the new solenoid I got is not working. So I'll drop it measure refill and do it again later. Oh well, Should of left it be...
    HulkSmurf14 and e30cabrio like this.
  12. Feb 26, 2025 at 1:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Damn solenoid and not fluid issue lol
    Mdl[QUOTED] and e30cabrio like this.
  13. Feb 26, 2025 at 1:19 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you get a batch of the filter spacers made, I'd like to buy one as well
  14. Feb 26, 2025 at 1:53 PM
    bflooks
    bflooks New Member
    Metrowest MA
    If there is a list getting started, please add me, too. :spending:
  15. Feb 26, 2025 at 1:57 PM
    centex
    centex New Member
    Oh why not. I love fixing things that aren’t broken.
  16. Feb 26, 2025 at 2:15 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Add me, add me for the filter adapter extension too @snivilous ! I just got my new filter/strainer in and only need the VB now...an extension!
    Mdl and snivilous[OP] like this.
  17. Feb 26, 2025 at 2:18 PM
    snivilous
    SW UT
    Me thinking about all the money I'll make selling $12 extensions that each take an hour to make :rofl:
  18. Feb 26, 2025 at 2:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Muahahaha totally!
    snivilous[OP] likes this.
  19. Feb 26, 2025 at 2:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'll find out in about an hour...don't mind experimenting. And as I mentioned I'll be needing a rebuild soon. Fresh fluid? Faulty new S3 Rostra solenoid? Will replace with old oem solenoid take measurements and see.
  20. Feb 26, 2025 at 2:21 PM
    bflooks
    bflooks New Member
    Metrowest MA
    At $12, put me down for qty 5. :)
    Tripleconpanna, Wynnded, Mdl and 2 others like this.
  21. Feb 26, 2025 at 2:24 PM
    snivilous
    SW UT
    Daddy chill, we don't need you flexing your money like that
  22. Feb 26, 2025 at 2:30 PM
    bflooks
    bflooks New Member
    Metrowest MA
    food stamps have a cash value, right?
  23. Feb 26, 2025 at 2:40 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    tax refund well spent. Now it's ramen the rest of the month
  24. Feb 26, 2025 at 2:40 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I thought you liked shaving metal?
    And I'm not sure if it's needed but as @Jowett said, why the need for baffles if it's not needed or maybe a safe guard?
  25. Feb 26, 2025 at 2:41 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    gotta send two carton of eggs
  26. Feb 26, 2025 at 2:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ll need to dig up the b&m pan see what it looks like again.
    HulkSmurf14, e30cabrio and Mdl like this.
  27. Feb 26, 2025 at 2:57 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm pretty sure the B&M doesn't have the baffles, at least not that I remember.
  28. Feb 26, 2025 at 4:00 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Direct from PML's website:
    "This PML transmission pan works with the stock filter, available from a Toyota dealer or an auto parts store. Baffles on the inside of the PML pan reduce sloshing, direct the flow of fluid toward the pickup, and aid in heat dissipation"
    The heat dissipation topic was covered in the Banks video someone posted a while back, so it's not a new claim, but these are also different than the Banks, so IDK if they're even remotely the same in concept.
    e30cabrio and Mdl[QUOTED] like this.
  29. Feb 26, 2025 at 4:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous @Jowett
    Well I pulled the pan and the filter pickup I have sticks down about .75 inch from filter body. Now if using a WIX it is flush so avoid aftermarket or ensure it has the extended pickup. This is right above the baffles center opening. The pickup sits 3 inches down from the body, by drain. Front baffles are 2 inches tall for front and 1.75 tall for rear. Filter pickup is just forward of rear baffles about 3/8 of an inch above forward edge of rear baffles. The filter pickup sits about 1 inch below the check level drain.
    I don't think we need to extend it. One could make a 1/2 to 3/4 extension but is it necessary? I'm good...I think?
    Valve body diameter is 1.435 inches x .26 deep if needed for B&M pan.
    Now to clean up and fill up. Hope the S3 solenoid works...:fingerscrossed:
  30. Feb 26, 2025 at 5:42 PM
    e30cabrio
    HulkSmurf14 likes this.
