AC not working, windows not working, airbag light on
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra6789, Feb 25, 2025.
  1. Feb 25, 2025 at 10:28 AM
    Tundra6789
    Tundra6789 [OP] New Member
    Out of no where at the same time my AC stopped working, non of my windows work, airbag light came on, rear view mirror lost power. I have already installed new 7.5A fuses on all locations that call in the fuse box under the steering wheel. Does anyone know what else is the problem? I have a 2015 Tundra 5.7.
  2. Feb 25, 2025 at 10:35 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Assuming your battery and grounds are good, (check all that first) Id check wiring for rodent damage. Look at wiring under the hood, under truck and dash for chewed wires.
    yakeng and 00h2itr like this.
  3. Feb 25, 2025 at 11:46 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Yep, this. I'd be looking for some gnawed on wires. Rodents love these trucks
  4. Feb 25, 2025 at 2:35 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Is the AC not blowing or not producing cold air?
    Which mirror, the outside rear view or the inner mirror on the dash?
    Looks like everything you report out is fed off the same line, but it only has the 180 and 150 main fuses that feeds it.
    It has your A/C, mirrors, windows is the Power No. 3 fuse on the bottom.
    Inner mirror is powered by the ECU–IG No. 2 fuse.
    Do the doors lock/unlock?
    Cargo light work?
    Do power outlets work?
    00h2itr likes this.
