Papasmurf's 07 4x4 LT Build Thread and now with more other stuff too!
Discussion in '2nd Gen Builds (2007-2013)' started by papasmurf, Jan 11, 2017.
  1. Sep 23, 2021 at 9:09 AM
    #691
    Sunnier
    Sunny
    San Diego, CA
    That compressor mount solution is awesome!!!
    Man, the older she gets, the better she gets! :101010:
  2. Sep 23, 2021 at 9:38 AM
    #692
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Awww thanks!!! yeah just so happened to have some nice thick plate aluminum and it was unused space so it just made sense to me..
    Now to figure out a storage solution for under the rear seat :anonymous::cool:
    Sunnier[QUOTED] likes this.
  3. Sep 23, 2021 at 9:52 AM
    #693
    Sunnier
    Sunny
    San Diego, CA
    Or… you could add some batteries, and be ecological…. :rofl:
  4. Sep 23, 2021 at 9:53 AM
    #694
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    but I already have three..how many more do I need? LOL:goingcrazy:
  5. Sep 23, 2021 at 9:58 AM
    #695
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Nice, I am glad to see you are keeping up with your skills for when i finally call you to do my 38 gal gas tank upgrade!
    papasmurf[OP] likes this.
  6. Sep 23, 2021 at 3:19 PM
    #696
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Finished the vertical tire mount and pro eagle mount today... just gonna let it dry and then ill put the tires back in and strapped down. On to suspension and brake maintenance.
  7. Sep 23, 2021 at 3:35 PM
    #697
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I need the red sticker
  8. Sep 23, 2021 at 3:46 PM
    #698
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looks great Bruce, especially the CF wrap. I've messed w/ that stuff and it can be challenging on some of those pieces you did.
    Sunnier and papasmurf[OP] like this.
  9. Sep 23, 2021 at 3:50 PM
    #699
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yup it was a PITA buuut it’s what I wanted so I made it happen. I just hope w everything I’ve done it’s quiet, less rattling, less noise in cab and app around feels better.
    831Tun[QUOTED] likes this.
  10. Sep 28, 2021 at 11:07 AM
    #700
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Awesome!! Looks good! Every since you told me about dual twin compressors I'm gonna have to steal that idea :D
  11. Sep 28, 2021 at 11:50 AM
    #701
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah its a pretty legit setup!
    i can build ya the same setup ;):anonymous:
    Cruzer[QUOTED] and Sunnier like this.
  12. Sep 28, 2021 at 1:28 PM
    #702
    Cruzer
    Cruz
    Sunnyvale, CA
    Did you put a check valve from the compressors into the manifold? Have you tested to see how fast you can air up now vs single twin compressor?
  13. Sep 28, 2021 at 1:56 PM
    #703
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Check valve no… not sure it needs it… and haven’t tested speed but I will do a side by side single valve dual … 37” on 17 from 20psi to 40 dirt pressure to street pressure and I will do them two separate days so compressors are cold
    831Tun, Sunnier and Cruzer[QUOTED] like this.
  14. Sep 29, 2021 at 3:07 AM
    #704
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    And the rebuild is complete....
    new upper and lower control arms uniballs, and new hardware with new misalignments
    new rotors and pads, and fully refreshed shocks back in...
    and now shes sitting on the ground.
    What's left :frusty:
    New wrap - this is delayed till after Tundras to Sedona due to delays in materials :annoyed:
    New storage boxes for tools, spare parts, recovery gear had to rethink this since I changed out my back seat... but I have a plan. :spending:
    new onboard water pump to be swapped (old one gave up the ghost):boink:
    needs a bath:mudding:
    figure out why my 5150 whip isn't working, I'm told they are sensitive with ground connections, so need to check my wiring on that. :rant:
    Fix gas filler neck:welder:
    Pin trans cooler open:monocle:
    that's it for now :fingerscrossed:
  15. Sep 29, 2021 at 6:12 AM
    #705
    Sunnier
    Sunny
    San Diego, CA
    Good progress! Damn the materials delay… seems like that’s everywhere now. I’m excited to see that new wrap!
    What’s up with the gas filler neck?
    831Tun likes this.
  16. Sep 29, 2021 at 7:01 AM
    #706
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    the rubber surround is falling apart... so the filler neck is not fully supported, i need to figure out a new solution.. not sure what yet
    joonbug and D4x4TRD like this.
  17. Oct 3, 2021 at 9:21 PM
    #707
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    so everyone asked for updates to the Excursion and Bourbon...
    well here is a tow pig update.
    Ahhh yes a 6.0 power stoke in its natural habitat :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Just kidding the tow pig is getting a bunch of upgrades!!:spending:
    @mishimoto all aluminum radiator, upgraded thermostat, aluminum degas resi
    @bulletproofdesl oil cooler kit, 7.3 mechanical fan clutch kit, egr upgrade, billet water pump
    @sinisterdiesel CAI, Blue-spring kit, hot and cold charge pipes, intake elbow, billet oil, fuel caps
    Turbo rebuild kit
    New idler pulleys and tensioner
    New motorcraft fuel filters
    And a few assorted maintenance items.
    Added w my tuner this truck should be ready for towing duty!!
    :turtleride:
    PS. If you don't know about diesel stuff feel free to ask, I'm not an expert but spent two years doing research before I bought this one... so I know a few things. :monocle:
    nb_nielsen, wv00097, joonbug and 3 others like this.
  18. Oct 3, 2021 at 9:44 PM
    #708
    GravityGear
    Aurora, CO
    Man, I'd love a fully bulletproof 6.0. It's a thing of my dreams.
  19. Jan 25, 2022 at 3:48 PM
    #709
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Well i guess i owe you all some updates...
    starting with the excursion... she got some more upgrades.
    Air bags
    On board air courtesy of ARB dual compressor.
    And for the tundra well she is a never ending money black hole..
    Was in the dealer for a 4wd issue for 2 months.
    Got it back 2 weeks ago
    now has new transfer case, front diff and actuators.
    Also recently added some new tail and head lights I had laying around for a while waiting to get the truck back
    Here are some photos and a vid from this past weekend wheeling with the wife and fam and friends out in Parker during the 425 race
    Wife decided to take our friend's daughter for a drive...
    Then decided she wanted to be my new hood orniment
    The race was awesome and our boy BJ Baldwin won!
  20. May 20, 2022 at 10:57 AM
    #710
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I figured it is a good time to update everyone on the truck and life and other vehicles too...
    My last post was back in late January. Work-life got busy due to COVID restrictions opening up and starting to travel more with work. Now that I can go see my customers.
    Then life happened, in the middle of March my Father passed away suddenly and tragically leaving my Little Brother, Sister, and me in turmoil.
    He left behind quite a large hole! He was the president and co-owner of a decent-sized company which we have now inherited, as well as a lot of financial things and other assets. We have spent the better part of 9 weeks dealing with lawyers and stuff getting everything sorted. Its been extremely trying on all of us, but the family is doing well and healing. My Brother, sister, and I have all grown stronger and closer through this which is great! Things have started to calm down and I have some time back to get on here and other places and start enjoying life again.
    So on that topic, I ended up with one of his cars. A 2011 Maserati Gran Turismo Cabrio (convertible for the layman), got shipped out here end of march from Maryland.
    It wasn't in the best shape (although nothing majorly wrong), dad rarely drove it only has 11,8XX miles on it, he recently had it serviced but the tires were original the clear bra was 9 years old and the car needed some love both interior and exterior. So what does any car junky do, get to work and have stuff done and mod sh!t! LOL
    The first step was organizing the garage and yes I have a new problem:anonymous:, an addiction to Chemical Guys products to keep the fleet clean. :spending:
    I started with the basics. I took it to my wrap shop where the truck currently is (Pics to follow after this topic) and had the shop remove the old clear bra, detail, polish and paint correct the car, and install a new PPF wrap on the front half the car.
    After that, I addressed the smaller items.
    Tires were original so got on a forum, of course, asked questions like a Newb, and figured out the best tire combo and sizing. upsized the tires 10mm on front and rear and installed some spacers to fill the gaps better. Went with Pilot Sport 4S in 255/35/20 front and 295/35/20 rear. You can see sorta in the first pics that the wheels were inset a bit, so now they are pushed out and the tires fit better than the stock Pirellis.
    Had to clean up the wheels before new tires.
    Then on to the mechanical stuff, figured id let her breathe a little better so installed a BMC air filter and a non resonated X-pipe. If anyone complains about installing an air filter, let me tell you it took me almost an hour for this thing, its not mechanic friendly :frusty:
    So all that being said the car is much happier now!
    Here is a vid of the cold startup with xpipe. :burnrubber:
    Onto the tundra...
    This is the last photo you will see of it full wrapped in the old snow camo... new pattern coming soon! Oh, you may notice new head and tail lights and hood pins... I thrashed it pretty good last T2S had to chop out the stock rad support and build a custom tube one..as well as broke the factory hood latch and hook off the hood. So hood pins went in as well.
    It should be done in a week or two. :headbang:
    Oh and the bourbon got a new set of shoes! Full military bead locks with the rubber inserts, so I can run 0 psi on them! :yes:
  21. May 20, 2022 at 6:57 PM
    #711
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Glad to see you back Bruce..sorry for your loss and glad to hear things are working out for you. Your garage looks soooo clean it's weird..
  22. May 21, 2022 at 8:09 AM
    #712
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hahaha yeah the wife said the same thing! And thanks, it’s slowly turning around the lawyers are not making things easy
    WVI likes this.
  23. May 30, 2022 at 11:22 PM
    #713
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Just read through your entire build, really quality work and documentation. Sorry about your loss. Especially hard being that far away. I'm in MD, if there's anything I could do to help feel free to shout out. That Grand Turismo is a beauty, they sound pretty gnarly with an exhaust.
  24. Feb 18, 2025 at 11:29 AM
    #714
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Well, folks I have been busy and gone for a bit. Not that I haven't been busy with tundra stuff, either, but I haven't had a ton of time to spend on the forums.
    But it's time for another big update. The truck is under the knife again, this time at an off-road fab shop. I'm getting the following things done in the next 6-8 weeks.
    Magnuson 2650 Supercharger
    New Rear Axle full trussed
    The front end is gonna be fully tubed (removing all stock sheet metal)
    Rehanging fenders, lights, hood mounts etc.
    Custom wheel wells (with all the fuse boxes and accessories removed to be mounted to the new front cage)
    stock shock towers and TC bypass hoops removed
    New 10" 3.0 coil overs and 10" 3.0 bypasses
    New mounting for shocks and bypasses
    front top mount bumps mounted
    New hard-mounted seat mounts and harness bar tied into the B pillar
    I'll post pics as I get them.
  25. Feb 18, 2025 at 9:56 PM
    #715
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Good list there Bruce. As for removing the shock buckets, are you going custom or LSK?
  26. Feb 19, 2025 at 7:20 AM
    #716
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    it will be custom. they are going to tie that in with the tubed front/engine cage/bracing
    eccracer104 and joonbug like this.
  27. Feb 19, 2025 at 7:25 AM
    #717
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sweeet!
    papasmurf[QUOTED][OP] likes this.
  28. Feb 19, 2025 at 7:28 AM
    #718
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Dual Dual ARB IS INSANE
    GREAT build !
  29. Feb 19, 2025 at 9:04 AM
    #719
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    some say its too much but 1 is none and 2 is 1.. I like redundancy and 37's take a while to fill up. So with a high flow hose and fill nozzle and the arbs going, the fill is much quicker, plus I can technically run air tools if I wanted.
    NoMoreGreen, eccracer104 and reywcms like this.
