Brake Issues (Pull left on harder brakes) HELP!
Discussion in '1st Gen Tundras (2000-2006)' started by JustGotDuals, Sep 10, 2020.
  1. Sep 10, 2020 at 1:23 PM
    JustGotDuals
    JustGotDuals [OP] New Member
    Hi! I have a 2001 tundra LTD, and I am having a braking issue with it. It does not pull when driving, but it pulls when you brake harder or quick! When it does it and you let go of the wheel, it pulls the steering wheel to the passenger side like 10 -15 degrees and kind of corrects the pull (not much). But if you hold the wheel like a normal person would, it pulls hard to the driver side (left). It has been doing this for about a month now, since then I have replaced brake calipers, hoses, and the small hard line that goes into the caliper. Pads looked even and rotors were new with pad less than a year. Rear brakes should be all good too because they were serviced when I got new bearings. Got two alignments. I have newish tires with less than 7K miles (rotated at 5k miles). I think it maybe the tires up front pulling, but anyone have any ideas? Braking is unaffected besides the pulling!
    Thanks ahead of time!!
  2. Sep 10, 2020 at 2:41 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    How are the front wheel bearings? Had a similar issue on an Jeep and when I disassembled for a u joint change found the axle nut about 150 ft-lbs less than it should've been.
    Drove normal otherwise until hard braking.
  3. Sep 10, 2020 at 3:41 PM
    JustGotDuals
    They seem pretty solid. No play in the wheel and tire, and they check out when I did my suspension and steering parts
  4. Sep 10, 2020 at 4:10 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Problem started before or after all the new brake work?
  5. Sep 10, 2020 at 5:38 PM
    JustGotDuals
    Everything worked fine until I took her on a fishing trip (12+ hours round trip) toward mid August. It was only slight on the way back but now it is where its at.
    The calipers and hoses were done to try and relieve that issue. And is say "hard" braking, but it is more of like a slowing down on the highway from 65mph to make a turn on a smaller road with a car behind you
  6. May 10, 2021 at 6:37 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Did you figure out the problem?
  7. May 10, 2021 at 7:16 PM
    JustGotDuals
    Hi! No I never did, but I am thinking it was the tires. They were wearing horribly even after going to the alignment shop multiple times and having everything checked over. I ended selling it for the same price I bought it for 4 years ago and bought a newer f150 just earlier this year. Sorry I couldn't be much help!
  8. May 31, 2021 at 3:51 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Ya my truck does the same. But also have problems with the brake hitting the floor
  9. May 31, 2021 at 4:00 PM
    15whtrd
    15whtrd Mr. Blonde
    I would look into all the suspension bushings. Upper and lower a arm bushings as well as wheelbearings, ball joints and tie rod ends.Don’t forget proper alignment.
  10. Feb 15, 2025 at 10:19 AM
    Grizzld
    Grizzld New Member
    '05 2wd DC Tundra, '07 2wd Sequoia
    OK guys, same issue as the OP, but on a 2007 Sequoia SR5, rwd. I didn't want to start a new post since the issue I'm having is exactly the same - imperceptible during soft braking, pulls left on hard braking but the steering wheel stays mostly straight, it just tracks left.
    For those who aren't familiar with the differences, Sequoia and Tundra brakes are essentially the same except Sequoia rear brakes are disk. Since the rears look perfect, and you guys haven't steered me wrong yet with my Tundra, help!
    To troubleshoot so far, I've changed pads to new oem, swapped front left and right tires, checked caliper pistons, lines, and suspension components for odd wear. The only thing I noticed was the OEM struts installed 30k miles ago have a very worn looking bushing where the shock mounts to the lower A-arm.
    Pics in the next post, Tia guys!
  11. Feb 15, 2025 at 10:49 AM
    Grizzld
    Grizzld New Member
    Couple of pics of the pads as removed looking at the car from the front (so the right side pads came off the driver's side caliper).20250215_093746.jpg 20250215_093649.jpg
    And this is the receipt from 2021 for what was replaced - brake booster, front strut assys, rear shocks.
  12. Feb 15, 2025 at 11:11 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    This UBJ has seen better days. I think this is a part of the issue but not THE issue. Know what I'm saying?
    anyways, you said "check calipers" what does that exactly mean?
    The pull to either direction is almost always a stuck caliper or bad alignment.
    tvpierce and KNABORES like this.
  13. Feb 15, 2025 at 11:25 AM
    Grizzld
    Grizzld New Member
    When I was installing the new pads, checking the pistons. They were all just fine, nothing stuck. I thought the upper and lower bjs looked fine but I can have another look, what specifically, Fish?
  14. Feb 17, 2025 at 11:20 AM
    FishNinja
    Lee
    06DC2wd
    I was just asking to see what you checked. Lol
    I would have a look see at tire wear and alignment specs now.
    Also if your suspension is just old or not up to par. The excess body roll can cause dives in different directions. Just shooting from the hip though.
    Grizzld[QUOTED] likes this.
  15. Feb 17, 2025 at 8:38 PM
    Grizzld
    Grizzld New Member
    I spoke to the mechanic who installed the struts and shocks in 2021 (30k ago) and asked why the shock bushings are so worn already, he said that was normal.
    I'm close to just installing some 5100s up front and calling it a day.
  16. Feb 18, 2025 at 2:40 AM
    FishNinja
    Lee
    06DC2wd
    This is why I do my own work on my cars and trucks.
    That bitch ass played you for your $$$
    those shocks you have are Monroe? Basically bottom of the barrel. Costs like $75 a corner.
  17. Feb 18, 2025 at 5:53 AM
    Grizzld
    Grizzld New Member
    Dang Fish, easy boy. I needed the truck back quickly so I went with whatever was available and not 2-3 days out. He did recommend oem, but I wanted cheap and fast so here we are.
    I'm still not convinced this is "the" issue, but we'll find out.
    I'll keep you guys updated for posterity.
  18. Feb 18, 2025 at 6:46 AM
    FishNinja
    Lee
    06DC2wd
    Grizzld[QUOTED] and KNABORES like this.
