Do you change your own oil in your Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Jan 27, 2025.
  1. Feb 10, 2025 at 8:28 PM
    #121
    Mr Rick
    Mr Rick New Member
    I have the whole maintenance schedule in an excel spreadsheet I made that is pretty sweet and clean, if anyone wants it.
    [/QUOTE]I would like one too when you have the time.
    TIA
  2. Feb 11, 2025 at 6:44 AM
    #122
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    TIA[/QUOTE]
    Sweet!
  3. Feb 11, 2025 at 6:54 AM
    #123
    24LTD
    24LTD New Member
    TIA[/QUOTE]
    Is it really ATF needs to change at 30k miles? Sounds early to me
  4. Feb 11, 2025 at 6:56 AM
    #124
    bailey bulldog
    bailey bulldog New Member
    TIA[/QUOTE]
    I'd like it as well please!
  5. Feb 11, 2025 at 7:09 AM
    #125
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Yes, please!!
    @SilveradoSwap NOTE:
    Several people above me copied @Mr Rick 's copied post (yours) that are also looking for your spreadsheet.
  6. Feb 11, 2025 at 7:45 AM
    #126
    Xfun
    Xfun New Member
    Martin
    TUNDRA DOUBLE CAB SR5 TRD OFF ROAD
    Stock
    TIA[/QUOTE]
    Count me too I want it Thank you
  7. Feb 11, 2025 at 8:26 AM
    #127
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    TIA[/QUOTE]
    Add me to the list please!
  8. Feb 12, 2025 at 3:45 AM
    #128
    Main Lo
    Main Lo New Member
    2023 Tundra CrewMax 4x4 SR5 TSS
    TIA[/QUOTE]
    Thank you! One sheet for me please!
  9. Feb 12, 2025 at 5:27 PM
    #129
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Interested in the sheet, do I send a PM?
  10. Feb 12, 2025 at 6:25 PM
    #130
    Mr Rick
    Mr Rick New Member
    Sorry guys but SilveradoSwap is the dude that has the Spread Sheet. Post #13 I sent a request for it but yet to receive it.
    22whatwedo[QUOTED] likes this.
  11. Feb 12, 2025 at 7:14 PM
    #131
    Mr Rick
    Mr Rick New Member
    Looks like it was in my spam folder. Send me a PM and I will get to you asap
  12. Feb 12, 2025 at 7:18 PM
    #132
    Mr Rick
    Mr Rick New Member
    I'd like it as well please![/QUOTE]
    Send me a PM and I will get it to you asap.
  13. Feb 12, 2025 at 7:19 PM
    #133
    Mr Rick
    Mr Rick New Member
    Thank you! One sheet for me please![/QUOTE]
    Send me a PM and I will send it to you asap.
  14. Feb 12, 2025 at 7:35 PM
    #134
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    These raise the tires 6"
    I will need to see how much that will help me with the spoiler down. I like the idea as I can stow them up against the wall in the garage and shouldn't be too heavy. I take it you made them and use them?
  15. Feb 12, 2025 at 7:37 PM
    #135
    mrlittlejohn
    Michael
    I would like this also, and thanks for offering it up. I'm at 18K miles and I need to be ready soon.
  16. Feb 12, 2025 at 7:42 PM
    #136
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    yeah... I'm not running a 3rd Gen, so I have no idea what your clearance is like. However, on my '21 Pro (w/OE Pro suspension) I can comfortably navigate under the vehicle w/a creeper or just rollin' myself under the truck w/o too much difficulty and have easy access to the skids, sliders and such :thumbsup:
    I had a set of those plasticy ones that I noticed a crack in one day, so I got rid of those and went this route. They are heavier than the plastic ones and much more stable!!
    mrlittlejohn[QUOTED] likes this.
  17. Feb 12, 2025 at 7:46 PM
    #137
    mrlittlejohn
    Michael
    I love the idea of the solid ramp for sure, I have seen many videos of ramp fails. I would not want it to happen to me. The spoiler on 3rd gens drop down a good bit and clearance is not much, but this may make it enough. And adding a Fumoto valve may just ease the task also with limited clearance. Hmmmmm
  18. Feb 13, 2025 at 12:42 PM
    #138
    riotkayak284
    riotkayak284 New Member
    TIA[/QUOTE]
    I would appreciate the file, as well. Thanks
  19. Feb 13, 2025 at 6:58 PM
    #139
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Does a bear shit in the woods and wipe his ass with a white rabbit.
  20. Feb 15, 2025 at 10:38 AM
    #140
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    Just wanted to confirm a few more things:
    Re the tubing size that goes on the spill plate for the oil filter, is 5/8, correct? and is the 5/8 ID or OD?
    Finally, is the end of the oil filter nipple barbed, straight flush or other?
    thank you very much
  21. Feb 15, 2025 at 11:11 AM
    #141
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    5/8" ID.
    The nipple is straight.
    tstex[QUOTED][OP] likes this.
  22. Feb 15, 2025 at 11:25 AM
    #142
    tstex
    perfect, thank you very much Taki !
  23. Feb 18, 2025 at 6:08 AM
    #143
    tstex
    Well, changed my first oil yesterday. Here are some things I learned:
    -The oil drain plug (supposed to be tightened at 30 ft/lbs) which i expected to put some real elbow grease/torque to loosen, was barely lightened. I was surprised it was not leaking, changed oil at 5012 miles
    -The oil filter was just the opposite. I needed a pair of channel locks to remove it. I hand tightened until seal was really snug, then did 3/4 revolution more.
    -The box of 10 tundra OEM oil filters i bought from dealer DID NOT have the oil
    Pan bolt washers in it as they said. So, i used the old one and tightened to 32 ft/lbs instead of 30 ft/ lb spec.
    -I used my rhino ramps to raise and i Aldo needed a foot stool to comfortably reach engine oil cap (I'm 6'4")
    -QUESTION: The skid plate/guard is completely diff on my 2024 vs what I saw in the enclosed video. It's a very light, flimsy piece of what seems like cardboard & felt. What do you other owners of 2024 tundras have? (SEE PICS) Also, plz see the beginning of the video link for a much more robust skid plate. When did these change to the cardboard ones?
    much better skid plate seen in first part of video:
    https://www.youtube.com/watch?v=4a3SKCVD6Ek
  24. Feb 18, 2025 at 6:18 AM
    #144
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Yeah, I wouldn't call that a skid plate. It's just a flimsy cover, probably more for aerodynamics than anything else. That's what most come with.
  25. Feb 18, 2025 at 6:23 AM
    #145
    tstex
    It's prob due to cost; which the former is much more durable and tough, if this ever hit anything on the road, it would be destroyed.
  26. Feb 18, 2025 at 6:30 AM
    #146
    Retroboy1989
    Northern Utah
    https://tmisvpp.com
    You can kick off a cancellation with this website.
    ARB1977[QUOTED] likes this.
  27. Feb 18, 2025 at 6:32 AM
    #147
    Raven67
    Kentucky
    That^^^^ is why I bypass dealers. I don't even take it in for the free oil change.
  28. Feb 18, 2025 at 6:38 AM
    #148
    Retroboy1989
    Northern Utah
    Are you kidding me?
    I guess I need to do this as well. Do you check the dipstick and filter also?
  29. Feb 18, 2025 at 6:43 AM
    #149
    BlackNBlu
    Rich
    MN
    @tstex
    What you have is standard equipment. Consider it a splash shield, not a skid plate. Keeps the slop accumulation to a minimum.
    TRD skid plate (aluminum) is an extra cost option except on TRD Pro.
    Didn't you install the Fumoto valve you ordered?
    (No need to mess with drain plug crush washers at that point.
    22whatwedo likes this.
  30. Feb 18, 2025 at 6:51 AM
    #150
    Retroboy1989
    Northern Utah
    The one on my 25 is a composite plastic, not felt.
