General Supercharger Thread
  1. Feb 17, 2025 at 2:53 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You can have more accurate fuel mileage/range information if you get a scangauge 3. It basically gets programmed to your fuel consumption with the new injectors and everything when you tell it how much fuel you added at each fill up. I just use that since the truck dash is now useless. Mileage is just one of those things everyone will get different results either way between driving habits, location, tire size, temperature etc but I can say it hasn’t gotten worse with the SC for me unless I’m driving especially aggressive.
    As for range, even at 12mpg using 30 gallons (when the gas light comes on) you should be getting 360 miles and still have 8 gallons left in the tank.
    Wynnded, Mdl and Tripleconpanna like this.
  2. Feb 17, 2025 at 5:49 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I get 17mpg avg.
    MOST of the time, I drive like a cadaver.
    it's easy for me to get 20mpg on the hwy.
    I use the SG3. it learns at each fill up, and adjusts accordingly.
    I usually refill @ half tank....15 gallons. which is about 250 miles.
    The Jekyl/Hyde nature of a S/C is awesome....this bitch will move if I hit the pedal.
  3. Feb 17, 2025 at 5:52 AM
    JohnWhicker
    JohnWhicker New Member
    The bitch will MOVE that's for sure :) Same with me, I drive pretty chill but when I need to move, dude, this focker can go fast. I wish there was a way for the ODB Fusion app to adjust and learn just like the SG3.
  4. Feb 17, 2025 at 5:56 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd be happy to trade you a SG3 for a 2650 :D
  5. Feb 17, 2025 at 6:16 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Same error. Better connectivity.
  6. Feb 17, 2025 at 6:44 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    10-13 city 16-18 on road trips. And low single digits haulin the mail in the dirt
  7. Feb 17, 2025 at 7:53 AM
    JohnWhicker
    HAHA
  8. Feb 17, 2025 at 8:03 AM
    e30cabrio
    Can't be my connectivity. Ran an RJ45:
    Same thing : :(
    Mdl likes this.
  9. Feb 17, 2025 at 8:04 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Try backing up your files, uninstalling, deleting folder, reinstalling
  10. Feb 17, 2025 at 8:06 AM
    e30cabrio
    It's happening in 3 computers, I'll give it a try on the one with beta.
    Mdl likes this.
  11. Feb 17, 2025 at 10:32 AM
    e30cabrio
    Uninstalled & reinstalled the 3 machines, did a fresh install on a 4th machine. Same damn thing.
    armyoffoo and Mdl like this.
  12. Feb 17, 2025 at 10:36 AM
    centex
    centex New Member
    Think you can say it’s not on your side.
    snivilous[OP], NatesNightMare and Mdl like this.
  13. Feb 17, 2025 at 11:26 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Well, shit, that's all I had to offer...hopefully HPT support comes through.
    e30cabrio[QUOTED] and Mdl like this.
  14. Feb 17, 2025 at 11:26 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have a guy in CA that's having issues trying to load a tune. Keeps hanging up and it's frustrating.
    What's interesting months ago I could search argument null and get a few posts on the forum about it. Now nothing.
    e30cabrio[QUOTED] likes this.
  15. Feb 17, 2025 at 11:39 AM
    e30cabrio
    As a hail Mary, I pulled the battery for 1/2 hour. Nope.
  16. Feb 17, 2025 at 11:40 AM
    e30cabrio
  17. Feb 17, 2025 at 2:19 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
  18. Feb 17, 2025 at 2:39 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Finished getting my bulkhead panel mounted, now I have a target for my gauge wiring. I'm also going to move my fuse blocks, relay and ground bar into the cab, as well as the D2A controller. Tons of room to mount stuff to the right side under the dash.
    I made an aluminum panel for the pass-through and used the panel as a guide for the hole saw.
    Panel with fitting and dust cover installed.
    Inside the cab
    reywcms, Mdl, HulkSmurf14 and 3 others like this.
  19. Feb 17, 2025 at 2:44 PM
    centex
    centex New Member
    Is the blower motor going to be in the way?
    HulkSmurf14 likes this.
  20. Feb 17, 2025 at 2:52 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Nah, it's down and to the left of the hole. This comes through right behind the glove box.
    HulkSmurf14, Mdl and centex like this.
  21. Feb 17, 2025 at 3:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's HPT servers...
  22. Feb 17, 2025 at 3:30 PM
    e30cabrio
    Glad it's not me.
  23. Feb 17, 2025 at 5:14 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Another case of stupid cloud network implementation. One reason why standalone is the way :mad:
  24. Feb 17, 2025 at 5:23 PM
    e30cabrio
    Hope it is fixed soon
    Mdl likes this.
  25. Feb 17, 2025 at 5:50 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    FYI for anybody who purchased a WAT Extreme VB, all VB's will be shipped in the same "Nomad" labeled box. Verified with the company today.
    Bluecobra, Abell207, reywcms and 7 others like this.
  26. Feb 17, 2025 at 5:52 PM
    centex
    centex New Member
    I just checked the forums and there’s no mention of an outage in there.
  27. Feb 17, 2025 at 6:02 PM
    Silver17
    Eastern PA
    Do they send you tracking on the VB when they ship or did it just show up one day?
  28. Feb 17, 2025 at 6:19 PM
    e30cabrio
    Forum seems pretty dead, first response to my thread was 22 minutes ago, suggested I try another file (I did yesterday, current tune had the same error)
  29. Feb 17, 2025 at 6:20 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    You should receive a DHL notification as I did.
  30. Feb 17, 2025 at 6:27 PM
    snivilous
    SW UT
    What about flashing the stock file? I would do the read download and try to flash that. Course you could get stuck with a N/A tune, but it'd weed out the flashing issue theoretically.
