Have you ever wanted to kill your own mother?
Discussion in 'General Automotive' started by trucksareforgirls2, May 22, 2024.
  1. Jun 11, 2024 at 12:04 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Lesson of the day. Always double check which hole your nozzle is going into.
  2. Feb 16, 2025 at 8:19 AM
    trucksareforgirls2
    trucksareforgirls2 [OP] New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Yes, because me reading the owners manual will fix inattention to detail! Shut up, no one needs to read a manual to put washer fluid in, this was a mistake related to inattention not misinformation!!
    joonbug and 1lowlife like this.
  3. Feb 16, 2025 at 9:35 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    It is evident someone needed to read something?
    Almost a year later?? Attention to detail???? HA!!!
    There was a lesson to be learned!
    Have a sparkly day!!!!!:thumbsup: :)
    I hope your mother is still alive! :)
    Cpl_Punishment likes this.
  4. Feb 16, 2025 at 11:49 AM
    Let's try that again....without the hostility.
    I always read the owners manual or refer to it. Usually it is very obvious to what is what under the hood. There are only so many holes under the hood that get fluid.
    Personally, I would have disconnected the bottom hose and drained (depending on design) or just removed the top hose, removed the overflow tank, drained and refilled. 30 minute job including Long Island ice tea.
  5. Feb 16, 2025 at 12:19 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Interesting, this thread had a 9-month gestation period from conception to revival.
  6. Feb 16, 2025 at 12:31 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm going to agree.
    Removing the contents of the coolant overflow tank would be a pretty easy job..
    The hose on the bottom connects to the radiator neck.
    Might be a little messy, but way cheaper than paying $120 an hour for a dealership to do it.
    upload_2025-2-16_14-19-5.jpg upload_2025-2-16_14-19-19.jpg upload_2025-2-16_14-19-32.jpg
    Not sure if the tank is easily removed from the fan shroud.
    It comes as one piece, kinda looks like it might be plastic riveted in place.
    Maybe remove the 2 bolts and lift the fan shroud out.
    2007-2022 Toyota Shroud Assembly 16711-0S011 | Sparks Parts
    I've seen them go for years and given new life..:eek2::cool:
  7. Feb 16, 2025 at 12:37 PM
    Yes
    Cpl_Punishment and Tunrod like this.
  8. Feb 16, 2025 at 1:04 PM
    T-Rex266 and 1lowlife like this.
  9. Feb 16, 2025 at 4:47 PM
    ScenicRoute
  10. Feb 16, 2025 at 5:10 PM
    This is correct...and a different light blue.
    Cpl_Punishment and 1lowlife like this.
