Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Feb 9, 2025 at 6:53 PM
    #241
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Looks good.
    No cutting, perfect.
    I think someone should powdercoat the parts red and then install! Or can you order red??? Unfortunately cannot get these in Canada is what I am hearing...?
    sudobash likes this.
  2. Feb 9, 2025 at 7:01 PM
    #242
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Nope. Nothing touches
    sudobash and az 3rdGen[QUOTED] like this.
  3. Feb 9, 2025 at 7:22 PM
    #243
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Sorry man. I was multitasking with watching the the superbowl and responding lol I should have read your post better. Thanks man.
    eddiefromcali[QUOTED] likes this.
  4. Feb 9, 2025 at 7:28 PM
    #244
    lapoolboy
    lapoolboy New Member
    Fly Eagles Fly!!!!
    Blufin, chrisgibbs707 and az 3rdGen like this.
  5. Feb 10, 2025 at 6:28 PM
    #245
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    I’ve driven lots of vehicles and tow hooks really never crossed my mind. For those who have added the hooks do you plan to ride around with them hanging or bring the hooks out if needed?
  6. Feb 10, 2025 at 6:34 PM
    #246
    eddiefromcali
    Eddie
    100% Stock
    Theyre way too easy to steal, Im keeping mine in a swingcase
    Woodrow bangs[QUOTED] likes this.
  7. Feb 10, 2025 at 6:39 PM
    #247
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    I feel dumb asking this here but you all would know best, what is the major deciding factor where folks decide to get the hooks? I do not off road. If the truck needs a typical road tow they are not needed correct?
  8. Feb 10, 2025 at 8:41 PM
    #248
    Reaper1911
    Reaper1911 New Member
    2024 White Tundra Limited Off-Road
    -TRD pro reaper bumper panels/fender flares -Catalytic converter cover -Bak revolver x4s tonneau cover
    Looks clean.
  9. Feb 11, 2025 at 5:46 AM
    #249
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Typically, the tow truck should be able to find a point to pull the truck up on a flat bed. But people are lazy and they could hook a spot where they shouldn't. If you wreck and then need recovery, they are going to find any solid spot to clear the vehicle.
    Not saying this as a dig to the 3rd gen, but look at the amount of trucks that had to get towed to the dealer for the engine grenading. They were able to hook them just fine.
    ngoshawk and sudobash like this.
  10. Feb 11, 2025 at 6:53 AM
    #250
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    ^^^This. The issue would be if you get stuck and need a yank from the front. Usually, the front is lower than the pulling vehicle, therefore tearing up your plastic pieces on the front bumper (nowhere solid to hook out front, so has to go on a control arm or frame underneath). If you have no "plans" to get off the beaten path, then you should be fine without.
  11. Feb 11, 2025 at 7:31 AM
    #251
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Thank you both. Wasn’t quite sure if/why I may need them. Based on the feedback I can save the money and put it towards larger cup holders, replacing the JBL, adding massaging seats, and the super useful molle panels lol
  12. Feb 11, 2025 at 8:02 AM
    #252
    SnrDisregardo
    Wade
    IL
    I'll say, if you get to a point where you have money burning a hole in your pocket, it would be one of those "piece of mind" mods. Especially since it's fairly inexpensive considering it's all OE parts.
  13. Feb 11, 2025 at 8:04 AM
    #253
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    Let’s be honest, we all got these recovery points so it gives the 2nd genners less ammo to talk crap on the 3rd gen. Plus these recovery points are much beefier than the 2nd gen!
  14. Feb 11, 2025 at 8:09 AM
    #254
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    I’m sure they would still comment here.
    Woodrow bangs likes this.
  15. Feb 11, 2025 at 8:16 AM
    #255
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    If I have money burning a hole in my pocket I’m converting them to $1’s and donating to my local entertainers “college fund”. Tow hooks would be way down on my list. But also understandable why they are good to have. I’d need a beater that does some wheeling to justify the buy. Platinums seem to belong on pavement imho
    SnrDisregardo[QUOTED] likes this.
  16. Feb 11, 2025 at 10:17 AM
    #256
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    better to have and not need than to need and not have. basically what drove me to getting them as I occasionally hunt/fish in some areas that are prone to getting stuck in mud/sand. I can use the mounts to help pull someone out or someone help me get out without ripping off the whole plastic front end
    Blufin and Woodrow bangs[QUOTED] like this.
  17. Feb 11, 2025 at 10:24 AM
    #257
    eddiefromcali
    Eddie
    100% Stock
    I go up to Big Bear Mountain during the winter. Being a 2wd, its a must...I'm going to get stuck at one point.
  18. Feb 15, 2025 at 4:38 PM
    #258
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    I decided to give the Toyota OEM Tow Hooks a go today. I read through this thread and it looked totally doable which it was. We did NOT remove the entire front end which led to having to trim off the 2 side tabs of the bumper cover that go under the mustache trim, but with 19 other clips it’s not going to miss 2 of them.
    Took about an hour total with the help of my Race Ramps.
    I need to find some smaller shackles, as these TRD ones are WAY too big. I bought the “Reno” ones another member here had posted but could not get the silver clevis pin through on the driver’s side hook. The pin hit the protrusion on the new bumper cover and would not go through unless flip 180 which would look ridiculous compared to the other side. https://www.amazon.com/dp/B0C6QB8P3V?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  19. Feb 16, 2025 at 4:32 AM
    #259
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    For those who are adding toe hooks to the front are you also adding recovery points in the rear? If the concept is -in case I get stuck off road- your not certain which side they would have access to.
    seems like alot of work to change your front bumper and the look, to a bumper that has two hooks without shackles.
    I actually think they are cool and look rugged when paired up with a truck that looks built for off road. Other then that they seem like truck jewelry
  20. Feb 16, 2025 at 10:21 AM
    #260
    Calif-Tundra
    Bob
    For the rear I have a tow hitch pull like this.
    https://www.rhinousainc.com/products/shackle-hitch-receiver?variant=41958504562879&nbt=nb:adwords:x:17354061039::&nb_adtype=pla_with_promotion&nb_kwd=&nb_ti=&nb_mi=324626948&nb_pc=online&nb_pi=41958504562879&nb_ppi=&nb_placement=&nb_li_ms=&nb_lp_ms=&nb_fii=&nb_ap=&nb_mt=&adgroupid=&gad_source=1&gbraid=0AAAAADSNCr2Oc38SLZSxQthD71az44C_W&gclid=CjwKCAiAtsa9BhAKEiwAUZAszdbjID4fwuQDlk3hjticAPqsox2zdis4ayGK_cwRCZQwHjda-y0WARoCU0cQAvD_BwE
  21. Feb 16, 2025 at 10:40 AM
    #261
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Brilliant Bob! Thanks
    Calif-Tundra likes this.
  22. Feb 16, 2025 at 11:54 AM
    #262
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    PSA if it makes any difference to people: Don't be fooled by the USA in the name. Made in China.
    I own several bits by Rhino USA. Nothing wrong with their stuff. Just don't pay extra for the name thinking you're getting a made in USA product.
    EXACT duplicates on AMZ under multiple different brand names, all about $15 less.
  23. Feb 17, 2025 at 6:35 PM
    #263
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    I think I am going to order this kit. I may have to fight the urge to color match the valence...
  24. Feb 17, 2025 at 8:55 PM
    #264
    emerson
    emerson New Member
    2022 TRD PRO
    Stock
    How much further does it poke out than oem lower bumper cover with the tow hook?
    Black@Blue19 likes this.
  25. Feb 18, 2025 at 1:11 AM
    #265
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I would do the same then PPF...Just saying :thumbsup:
    vegask[QUOTED] likes this.
  26. Feb 18, 2025 at 1:46 AM
    #266
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Those look very nice!! Yup,,, those will do right fine!:)
  27. Feb 18, 2025 at 11:32 AM
    #267
    vegask
    vegask New Member
    Kurt
    Northern NV
    x2 on this. The Rhino stuff is decent. But if you are doing any serious recoveries please use a soft shackle.
  28. Feb 18, 2025 at 2:16 PM
    #268
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    For those with the TRD 3" lift, you could remove the sway bar drop bracket to use this kit. And moving the sway bar allows for bigger tires with no rubbing....and you could always put a "beefier" sway bar and end links from the TRD Pro on....just sayin lol
    MidnightTRDOR likes this.
  29. Feb 19, 2025 at 5:56 AM
    #269
    Breathing Borla
    AZ
    ya, they got me like that, once....
    Im a buy made in USA guy and I try to look for that first no matter what Im buying, obviously some stuff you just can't find, but I try anyways
    Raven67 likes this.
  30. Feb 19, 2025 at 6:04 AM
    #270
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    Toyota: please provide these front tow hooks as standard equipment on TRD models.
    You don’t even need to include the shackles, I’ll buy my own.
