6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. May 22, 2024 at 8:00 AM
    #2341
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Either the route that @b6graham has proposed or even the Bilsteins a 2.5" will be a significant improvement over what you currently have. Especially when it comes down to ride/capability. Whether you go straight to 2.5" on the circlip is up to you. You're still in an acceptable travel pocket for the coilover, but you do technically capture more downtravel for your ride height with the 1.9" + top plate spacer setup so that "could" lead to a slightly more supple ride.
    Just know this much though - If you capture 2.5" out of the Bilsteins whether that be the spacer/circlip combo or purely circlip you will be in the territory of needing new upper control arms to get your alignment back into spec. If you were to go to the 1.9" setting and stay there you could avoid that expense. Just some food for thought.
    All said, keep hitting us all with questions as people are happy to help here, and when you're ready to get the goods hit us up over here at Hotshot Offroad (pm me here or call at 406-936-0206) and we can help you out. We can even assemble the shocks to your desired spec as well. :thumbsup:
    DZ_, RobertD and b6graham like this.
  2. May 28, 2024 at 11:51 AM
    #2342
    ThiRdChoice
    ThiRdChoice New Member
    Tommy
    After searching through the forums for almost a year (also just saving), here's my new set up! 6112 set at 2.5" and 5100s in the rear. The front sits a bit high but I will be getting rear shackles later this summer so I'm not too worried. 285/75/17 with 0 offset wheels, had to remove the front mudflap and liner.
  3. Jun 21, 2024 at 4:53 AM
    #2343
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Got the lift. 6112 top setting. 2 CB Shims
    Driver, 1 passenger. 5160 rear. Currently have 2” block as a place holder before a shop can install the CB+3 shackles. They didn’t have the right press for the bushings. Zone off road control arms. New 285/70/18 Toyo ATIII’s. 1.25” bora spacers. Wish I went larger, but saved some weight and didn’t want to mess with BMC. New rims in the future. Thank you @memario1214 and @Coachbuilder1 for answering my 1 million questions.
  4. Jun 21, 2024 at 5:57 AM
    #2344
    COTundra23
    COTundra23 New Member
    Man that looks fantastic! Great work.
    do you have hub to fender measurements by chance?
  5. Jun 21, 2024 at 6:00 AM
    #2345
    therealjonwick
    JR
    2019 OR
    Haven’t taken my post lift measurements. I’ll get to it this weekend. Thanks!
    COTundra23[QUOTED] likes this.
  6. Jun 22, 2024 at 3:56 PM
    #2346
    therealjonwick
    JR
    2019 OR
    Just measured. My post measurements were in a flatter area of my driveway. The pre were in a weird spot. Measured from bottom of the plastic hub cover. The tape sat their easily. About 1.5” to 1 5/8” from center of hub. Full tank of gas.
    Pre lift:
    FD:23
    FP:23 1/16
    RD: 25 1/2
    RP: 24 5/8
    Post lift:
    FD: 26 5/8
    FP: 26 5/8
    RD:27 5/8
    RP: 27 1/8
    So got the 3”+ in front. Should settle I hope. Shackles will knock a 1/4” off the back. Want to keep the rake. Rear passenger is a bit higher. Overall, happy with how even it is left to right. Debating keeping the blocks to not lose the 1/4” in the rear. But I’ve heard the CB shackle rides so much smoother. If anyone wants to chime in, I’m all ears.
  7. Jun 22, 2024 at 4:39 PM
    #2347
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Shackle only good for empty truck, it sag more when you have weight and it’s a rear spring killer.
  8. Jul 25, 2024 at 8:19 PM
    #2348
    94Toy22re
    94Toy22re New Member
    Just installed my 6112 today, setting 2 (1.2") and a CB shim on the driver side. I know everything will settle but right now its nose high and I wanted to keep a slight rake, I know its going to settle some but on my short test drive all of the safety sense warning lights came on. I wondering if should set them at setting 1 (0.75') before I go get an alignment?
  9. Jul 25, 2024 at 8:28 PM
    #2349
    RobertD
    Robert
    DFW, Texas
    How are you nose high? What type of truck (year, cab size, 2 wheel or 4 wheel drive) have you done anything to the back?
    Is this just visual or did you measure the front and rear? I just don't understand how you are high if you install things correctly and the front was at 1.2. I did mine at 1.9 with a driver side shim and it was pretty level.
    For the sensors, try disconnecting the battery for a few minutes. Otherwise, they should go away once you get an alignment.
    94Toy22re[QUOTED] likes this.
  10. Jul 25, 2024 at 10:36 PM
    #2350
    94Toy22re
    2019 Crewmax 4x4, haven’t measured yet. The truck douse have 150k miles i’m hoping the rear springs are not worn out! The rear is factory besides 5160 shocks!
    RobertD likes this.
  11. Jul 26, 2024 at 5:10 AM
    #2351
    RobertD
    Robert
    DFW, Texas
    Hmmm
    I don't have other advice. I'm a 2018 Crewman 4x4 and the 1.9 made me level. I added RAS in the rear to get back rake and to get its benefits.
    @memario1214 any idea how setting the 6112 at 1.2 made him nose high?
  12. Jul 31, 2024 at 9:00 PM
    #2352
    962HR1
    962HR1 New Member
    Eric
    2013 SR5 TRD OffRoad
    Just for a bit more reference.
    Front 6112 at 1.3" lift
    Rear 5160 at stock ride height
    285/75-R17 Falken A/T4W on Rock Warrior wheels
    Biff's R, Oey12, equin and 5 others like this.
  13. Jul 31, 2024 at 9:30 PM
    #2353
    NWPirate
    Zach
    WA
    Looks a lot like my Profile picture location :thumbsup: I'm at at 1.3" also
  14. Nov 2, 2024 at 11:03 AM
    #2354
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    Nice job
  15. Nov 2, 2024 at 11:13 AM
    #2355
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    6112 front on highest setting, no shims, camburg ucas
    5160 rear, deaver u748 & total chaos shackles
    method 703 (+35, 17"), toyo at3 35x11.5
    Mfanatic22, pvmike, equin and 7 others like this.
  16. Nov 30, 2024 at 7:08 PM
    #2356
    naumanator
    naumanator New Member
    Salt Lake City, Utah
    2017 Silver TRD Off-Road Double Cab
    Looks fantastic, I'm about to install very similar lift at 3rd notch. How much weight do you have in the bed with that camper?
  17. Nov 30, 2024 at 10:19 PM
    #2357
    rheosibal
    2.5 Platinum OEM+
    Thanks!
    In the top photo, bed weight is likely around 1000 pounds = GFC Camper (~300lbs), Decked Drawers (~200lbs, empty), all the gear for 4 weeks of travel (~500lbs)
    In the bottom photo, bed weight is likely around 600 pounds = GFC, Decked, weekend's worth of gear
    The GFC and Decked Drawers live on the truck full time and the Deavers work great with variable weight. Minor differences in height and ride quality between fully loaded and completely empty.
    COTundra23 likes this.
  18. Dec 18, 2024 at 8:32 AM
    #2358
    Eddy20
    Eddy20 New Member
    Looking at this option, I like the look! I just want to level I have 20" stock OEM wheels from a 2021 Platinum Tundra. I don't want to screw up the ride or mess with UCA's, shackles or spacers. Will the 6112's accomplish this?
  19. Dec 18, 2024 at 8:33 AM
    #2359
    memario1214
    Colton
    Missoula, MT
    Absolutely
    RobertD likes this.
  20. Jan 11, 2025 at 6:43 PM
    #2360
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Just wanted to give an update on my 6112s. It's been about 6 years and well over 100K miles on them (maybe even 120K?), and they're still holding up, even after installing a heavier-than-stock front bumper (C4 Fab). No leaks or problems with them whatsoever, but given their age and mileage, it's time to replace them. I'll be replacing them with the Fox 2.5 remote resi's that have been sitting in my garage for a good while, but I admittedly have buyer's remorse for not going with another set of 6112s at a more affordable price, given how well these have held up. Someone else said this in another thread recently, but I agree with their post that said these are probably the best bang for the buck front coilovers for the 2007-2021 Tundras.
  21. Jan 28, 2025 at 10:46 AM
    #2361
    Loudog
    Loudog New Member
    2021 Tundra
    Stock 275 70 r18
    Hey all, long time lurker. I've probably gone through this thread 4 times now.
    I was wondering if my sensors will go nuts installing 6112's at 1.9" + 2 .50" cb shims driver, 1 passenger and coachbuilder +2” shackles in the rear?
    I was thinking of installing airbags in the rear to help keep the rake if any. Or would airbags just sit like bump stops and only engage with 1" of squat or something?
    Also, if anyone else can chime in on longevity with their setups that would be sweet!
  22. Jan 28, 2025 at 2:33 PM
    #2362
    memario1214
    Colton
    Missoula, MT
    Running a 6112 setup with your desired lift height and supporting mods will not create any problems in the way of your sensors.
    Why do you want airbags? Are you running a ton of weight out back? Share a little bit about your use case there, and I'll give you some thoughts!
    Loudog[QUOTED] and RobertD like this.
  23. Jan 28, 2025 at 6:05 PM
    #2363
    Loudog
    Loudog New Member
    2021 Tundra
    Stock 275 70 r18
    Thanks, appreciate the quick reply!
    My 2" coachbuilder shackles are on the way, I'm probably a ways out from install as I want to grab new UCA's as well.
    I figured air bags would be easy to install and help with towing. I'm not keen on the Road active suspension setup.
    I do haul a lot of garbage and firewood in the back, 16' boat in the summer and maybe a tandem axle trailer soon depending on my job situation. I'll probably get some Deaver leaf springs, especially if I get a camper on the back. I can also borrow the in-laws 34' trailer for camping. Previously I'd use their F250 but they've since sold that so yeah.
    At the moment I have a bakflip mx4 tunneau cover which has failed seals second year in.. I load up the back with kids stuff when we go on road trips around 5 times a year seeing the in-laws and family. I could see the MX4 being replaced with a topper, three Boys the wife and dog fill the space quick!
    It's going to be a pain to remove shims and run just one .50 for lean so I'm just on the fence about how much rake I'll have. I'm running 275/70r18 Edit: with 1.25" wheel spacers at the moment and probably go 285/70 or then bite the bullet at 295/70r18 :spending::rofl:
  24. Feb 13, 2025 at 10:31 PM
    #2364
    Snoo
    Snoo New Member
    2021 MGM Tundra Platinum
    Finishing up install, does anyone know if bump stop spacers are required for durobumps if the 6112s are set at max lift? I also got a driver side shim as well.
    durobump website says it’s good for 0-3 inches of lift, but saw a diagram floating around stating compression height is the same as stock, which seems like it would need spacers.
    equin likes this.
  25. Feb 15, 2025 at 5:07 PM
    #2365
    silverstreak16
    silverstreak16 New Member
    Gene
    Western NC
    2016 Tundra Crewmax Limited
    Just had my suspension setup installed 2 days ago.
    Bilstein 6112 set at 2.5" with 1 shim each side
    Bilstein 5160 in the rear
    Bilstein UCA
    Icon Leaf Pack
    Carrier Bearing Spacers for driveline
    Rear plastic of front bumper corners pushed forward
    285/75/18 Nitto Recon Grapplers on factory 18" TRD wheels
    Only rubbing is on the sway bar on driver side at full lock
    Skolberg, COTundra23, equin and 4 others like this.
  26. Feb 20, 2025 at 9:22 PM
    #2366
    TRD77
    TRD77 New Member
    2020 TRD Sport
    I need help. It’s time for new tires. I’m currently running 285 70 17 with 6112’s top setting. That’s all the suspension upgrades I’ve done. How big can I go with my current set up? I’m looking at 285 75 17, 295 70 17. Bigger??
    I’m open to body chopping.
    Thanks all.
  27. Feb 20, 2025 at 9:28 PM
    #2367
    RobertD
    Robert
    DFW, Texas
  28. Feb 20, 2025 at 11:41 PM
    #2368
    rheosibal
    2.5 Platinum OEM+
    37s
    Loudog likes this.
  29. Feb 21, 2025 at 8:52 PM
    #2369
    equin
    Ed
    DFW, TX
    I was able to fit 315/70/17s with 6112s set at 1.9" and removing the front bumper plastic flaps. I also had to do a bit of cutting on the plastic fender well just to the rear of the front tires, right where the body mount is. With 17" Icon wheels (which I believe have 25+ offset), I was not hitting the body mount, so no need for any body mount chop on my truck with that setup.
  30. Feb 22, 2025 at 7:20 AM
    #2370
    Loudog
    Loudog New Member
    2021 Tundra
    Stock 275 70 r18
    My buddy runs 35's with a 2.5" spacer on stock suspension, 2015 trd off road with 1.25" spacers on the 18" trd wheels.
    - Cut front liner, might be able to heat gun.
    - Removed the mud flaps behind the front tires.
