Milwaukee Tools
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 9, 2024.
  1. Feb 14, 2025 at 8:55 PM
    #1411
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    The M12 impact is freaking awesome.
    Leo's first likes this.
  2. Feb 15, 2025 at 7:56 AM
    #1412
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    https://youtu.be/FGMkEfuWZHM
    ZappBrannigan and T-Rex266[OP] like this.
  3. Feb 15, 2025 at 1:00 PM
    #1413
    French Avocado
    Utah / Wyo
  4. Feb 15, 2025 at 2:30 PM
    #1414
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    OK, let me explain. Grounds crew get these larger beefier carts, felicities get regular carts with small plastic beds. Well I had been eyeballing a cart that was out in the too broke to fix pile. Yesterday I said F it and pulled the bed off it. After some Unistrut and a couple L brackets I got that bed mounted to my cart. It's was not my fault the two pack out plates fit perfectly side to side, well 4 plates later I got this. I have not settled on the final set up. Northern Tool and HD did not have the large tool box that is the size of the wheeler with out the wheels and handle in stock, that should be prefect for the tool bag. Any thoughts?
  5. Feb 15, 2025 at 3:13 PM
    #1415
    Very nice. Add in some deep sockets, tire repair kit, gloves, etc if you can.
  6. Feb 15, 2025 at 4:19 PM
    #1416
    French Avocado
    Utah / Wyo
    I have the Tundra socket in there but should add an extension. Good idea on the gloves. The tire repair kit is in the black case.
  7. Feb 15, 2025 at 4:20 PM
    #1417
    French Avocado
    Utah / Wyo
    Very nice collection of packouts! Might be a little heavy in the rear once loaded with tools.
  8. Feb 15, 2025 at 4:35 PM
    #1418
    French Avocado
    Utah / Wyo
    Currently, I have only M18 tools. I cannot pass on the buy 3 M12s (limited selection) get $200 off. Which three should I get? I am considering the Surge 1/4" impact driver (set with 2 batteries), M12 multi tool (do I need it if I have the M18?), and the M12 polisher/sander (2438-20). Would I be better served with the M12 3/8 ratchet? Or, the extended reach ratchet?
    Leo's first and T-Rex266[OP] like this.
  9. Feb 15, 2025 at 4:37 PM
    #1419
    Portable jump starter too
  10. Feb 15, 2025 at 4:39 PM
    #1420
    Impact driver
    Multi tool (even the M12 is great for random shit..used it a few times now)
    Polisher and sander you may burn through the batteries (I don’t have them, but I can see it)
    I have the M12 ratchet which has also been great. If you don’t have the right angle drill, and that’s an option- consider that too
  11. Feb 15, 2025 at 4:39 PM
    #1421
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I opted for the insider ratchet instead of the extended reach one - two birds with one stone.
    I prefer the ergonomics of the M12 multi-tool over the M18… it’s just a little more compact
  12. Feb 15, 2025 at 4:45 PM
    #1422
    French Avocado
    Utah / Wyo
    Bingo - portable starter is in the basket next to the packout because it would not fit.
    T-Rex266[QUOTED][OP] likes this.
  13. Feb 15, 2025 at 4:46 PM
    #1423
    Which one do u have?
  14. Feb 15, 2025 at 4:48 PM
    #1424
    French Avocado
    Utah / Wyo
  15. Feb 15, 2025 at 4:49 PM
    #1425
  16. Feb 15, 2025 at 4:53 PM
    #1426
  17. Feb 15, 2025 at 5:09 PM
    #1427
    Azblue
    The Dirty T ( ^_^)_且
    Wait a second, I just saw your new avatar and noticed you are now the Forum Treasurer? Did you run that by our official Forum Financial advisor @LarryDangerfield ?
  18. Feb 15, 2025 at 5:23 PM
    #1428
    French Avocado
    Utah / Wyo
    Which impact is that? The mid-torgue does not fit well and I have to fit it in a higher spot but then still sits proud.
  19. Feb 15, 2025 at 6:16 PM
    #1429
    Outbound
    Aaron
    Northern Alberta
    I need that.
    That's way cooler than my Home Depot tote...
  20. Feb 15, 2025 at 6:25 PM
    #1430
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Which packet case is that???
  21. Feb 15, 2025 at 6:27 PM
    #1431
    Outbound
    Aaron
    Northern Alberta
  22. Feb 15, 2025 at 6:31 PM
    #1432
    Tripleconpanna
  23. Feb 15, 2025 at 6:37 PM
    #1433
    Tripleconpanna
  24. Feb 15, 2025 at 6:38 PM
    #1434
    Outbound
    Aaron
    Northern Alberta
    Not fair.
  25. Feb 15, 2025 at 9:03 PM
    #1435
  26. Feb 15, 2025 at 9:06 PM
    #1436
    Outbound[QUOTED] likes this.
  27. Feb 15, 2025 at 9:13 PM
    #1437
    French Avocado
    Utah / Wyo
  28. Feb 15, 2025 at 9:53 PM
    #1438
    RainMan_PNW
    Casey
    Clark County, WA
    Ain’t nuthin official about it. Kind of like my questionable vendor status… :notsure:
  29. Feb 15, 2025 at 10:12 PM
    #1439
    Pull it out (TWSS) and see if that’s the issue. Shave them off (I used an oscillator, but a good blade would also do it) and try setting it back in. Also do it under the inflator so it lies flatter
  30. Feb 16, 2025 at 9:32 AM
    #1440
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I'll be returning the inflator for that set with battery and charger.
    Also, damn you guys, damage taken.
    Just got those two sets.... I blame you all!!!!
