  1. Feb 14, 2025 at 7:42 PM
    I think I’d like the Seq, that Tun was a dog.
    BroHon[QUOTED] likes this.
  2. Feb 14, 2025 at 7:53 PM
  3. Feb 14, 2025 at 8:12 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I just started looking at some of the Tundras that sold on BAT. Looking at one with the 3.4/manual TC and from what I am seeing the front diff and drive shaft must stay engaged because there is no front ADD/or locking hubs, is that right?
    EDIT: I guess there could be a switch in the manual TC shifter that could trigger a front ADD, Ill look at the FSM.
  4. Feb 15, 2025 at 12:14 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't lie, we all saw your OCD door panel fiasco. I say flip a coin. Speaking of which, what happened to those door panels?
  5. Feb 15, 2025 at 12:20 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    ADD
  6. Feb 15, 2025 at 3:28 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @Sirfive you bringing grandpa's truck?
  7. Feb 15, 2025 at 4:43 AM
    Yep. Moving into sales last year I really struggled with this. The truth is that imposter syndrome is common in high performing people. It turns out, I'm pretty good at my job but still don't feel like it some days.
    @bmf4069 if they are asking you to teach, they have a good reason. I've met you. You have the right mix of people skills and technical knowledge that's necessary for teaching. You'll crush this. Fuck the self-doubt and enjoy the ride.
  8. Feb 15, 2025 at 5:46 AM
    I told the head of the school that and he said he's hired people straight out of the school to teach. Basically 1st year journeymen. This March will be my 11th year with my masters after having my J card for 4. I've had my masters longer than I've been an apprentice and journeyman at this point. I know I can do it; I just worry if one of them kids comes at me with a question I don't know. Also, my ADD riddled brain does shit so different that I don't feel I'm an effective teacher.
    I fully plan on teaching the math and trigonometry behind bending. Most people don't even know that. We have one particular bend called a kick 90. Let's say you need to to make a 90° bend, but drop 4" as well to hit a box. Most people will bend the 90, then hold a tape on the pipe and pull the 90 up to get 4". Well, if you do the math you can put a 30° kick in there by coming back 8" and bending on the 30° notch. I've never met anyone who does it that way. I've seen so much shit that people don't know. I'm hoping I can make a difference and teach these little shits something.
  9. Feb 15, 2025 at 5:48 AM
    Exactly. I didn't put them in because they didn't match. They're just sitting in the shed of shame.
    With that being said, Donut has black flooring with a beige interior, and it looks pretty good. Well, it's not an eye sore anyways.
  10. Feb 15, 2025 at 5:52 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    @bmf4069
    Starter acted up yesterday. Looks like I'm goin into surgery soon. Getting my parts ordered today. DesertDog gave me a parts list and some of this stuff I'm not sure I need...
    Looks like stay away from felpro on the intakes and go OEM. Debating on the plenum... what's your opinion on that?
    DD's list
    Rockauto reman starter: 280-0233
    Toyota: 17171-50020 x 2
    22271-50042 x 1
    90430-12026 x 5
    16341-50020 x 2
    90176-06023 x 1
    23232-41081 x 1
    90301-07037 x 1
    90430-12026 x 4
    90430-12005 x 2
    bmf4069 likes this.
  11. Feb 15, 2025 at 6:00 AM
    Felpro is ok. I went oem because I wanted to make absolutely sure they were good this time.
    But remember master @shifty` teachings: it's (almost) never the starter. When my daughter's tree gave me a "click", it ended up being the battery and terminals. I'd check those. If that ain't it, get a long screw driver and put it on the solenoid and give it a few wacks. You may just need new contacts or have a sticky solenoid.
    shifty` and BroHon[QUOTED] like this.
  12. Feb 15, 2025 at 6:06 AM
    I drew a picture of a kick 90 for reference.
  13. Feb 15, 2025 at 6:16 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, I just got a new battery a couple months ago, and I cleaned the shit outta the terminals and they are soaked down in FluidFilm, so that part is fine.
    "You may just need new contacts" Do you mean this? KIT
    I know it only seems to be when it's cold... which could in a way mean something is expanding/making a better contact?
    Prob wouldn't hurt to get one of these cold spec 2kWs on hand anyway before they go NLA
  14. Feb 15, 2025 at 6:53 AM
    I'm pretty sure that's the kit, but I'd let someone else chime in. That 2kw would probably be pretty good up there in the mitten.
    However, with it only happening in the cold tells me there's a problem with current flow. It could be at the starter end of the cable, or starter itself. It only takes about 30-45 minutes to pull the intake so I'd say fuck it and throw that 2kw in. When you do pull it, use the vacuum port on top with a finger and put your other hand in the TB opening, then lift up and towards you.
  15. Feb 15, 2025 at 7:04 AM
    When my starter was going "click" recently, multiple days in a row, it turns out it was the new positive battery terminal I'd installed a couple months prior. Apparently it wasn't excruciatingly tight, although it wasn't loose either, but it could be moved back/forth with mild pressure.
    I knew there was no way in hell my starter was going out at 80k miles.
    BroHon likes this.
  16. Feb 15, 2025 at 7:09 AM
    Get some rodent tape, wrap the knock sensor and starter wires with it while you're in there.
    bmf4069 and BroHon[QUOTED] like this.
  17. Feb 15, 2025 at 7:17 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Thanks guys. I am going out here in a couple minutes to see how she starts, 23deg. I remember when I replaced the battery the ground cable looked a little sketch, and I joked about not fixing it. Got a coper lug and everything I need to address it. Think I am going to start there.
    What gage are our OEM cables? I'm not going big7 on it yet, but I might address a couple, esp if this ground isn't long enough to do a repair.
  18. Feb 15, 2025 at 7:22 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The forbidden two tone :rofl:
    I don't hate it...
    KNABORES and BroHon like this.
  19. Feb 15, 2025 at 7:39 AM
  20. Feb 15, 2025 at 7:41 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Just needs to ditch those gay patricks :p
    bmf4069[QUOTED] and KNABORES like this.
  21. Feb 15, 2025 at 8:20 AM
  22. Feb 15, 2025 at 8:22 AM
    The two tone line just need to have a little angle to it
  23. Feb 15, 2025 at 8:23 AM
    But still looks like a truck trying to drive out from inside another truck…
  24. Feb 15, 2025 at 9:18 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  25. Feb 15, 2025 at 9:41 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What a special sight, the rarely spotted hood mounted light bar plus ditch lights pointed to the sky
  26. Feb 15, 2025 at 9:42 AM
    BroHon, bmf4069 and des2mtn[QUOTED] like this.
  27. Feb 15, 2025 at 9:53 AM
    don't forget the swamp inside the passenger side fog light. Guess they're saving that to drink later.
    455h0le_dachshund and BroHon like this.
  28. Feb 15, 2025 at 9:54 AM
    And the result iiiissssss.... :confused:
  29. Feb 15, 2025 at 9:54 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Frame swap? Easy peasy
  30. Feb 15, 2025 at 10:09 AM
    Don't hate. This shit looks gooooood.
