General Supercharger Thread
  1. Feb 14, 2025 at 10:52 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  2. Feb 14, 2025 at 10:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I've got a set of maggy green injectors here with your name on it.
  3. Feb 14, 2025 at 10:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I am pretty sure he didn't have this on a FFV
    reywcms[QUOTED] likes this.
  4. Feb 14, 2025 at 11:23 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    What's the process to force the FFV pump to always be in high pressure mode? Guy I'm trying to help has lean out issues up top with a FFV but I think the pump is in "normal mode", and I know nothing about FFV.
    ARES35 and HulkSmurf14 like this.
  5. Feb 14, 2025 at 11:28 AM
    AZTundra
    Paul
    Phoenix, AZ
  6. Feb 14, 2025 at 11:28 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
  7. Feb 14, 2025 at 11:31 AM
    snivilous
    SW UT
  8. Feb 14, 2025 at 11:38 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  9. Feb 14, 2025 at 12:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @armyoffoo I was mocking up my relay box like your setup. One of the brake lines is a lot higher on 2nd Gen than the 2.5 and of course causes the box to be higher and closer to the hood. I'll see about ordering a brake line from a 2.5 Gen shouldn't cause issues but didn't want to be bleeding the brakes. Or just mount it higher?? I need to clean up that rats nest of wires.
    ARES35 likes this.
  10. Feb 14, 2025 at 1:00 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I got my mounting bracket from t a c o t u n e s, it should work for 2007-2021, so maybe the overall height isn't that much different, just the routing?
    Mdl[QUOTED] likes this.
  11. Feb 14, 2025 at 1:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I was going to fab a bracket up but will check it out. I still have the link that you gave. Thanks again!
  12. Feb 14, 2025 at 5:30 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    That sounds a helluva lot easier of a place to install than on the manifold.
    Video makes it look pretty easy. So just anywhere upstream of the cats?
  13. Feb 14, 2025 at 5:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    Hot damn....I hope this applies to my order.
  14. Feb 14, 2025 at 5:32 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yep, anywhere before the cats and angled pointed up so that condensation doesn't collect in the sensor.
    HulkSmurf14 likes this.
  15. Feb 14, 2025 at 7:23 PM
    Danimal86
    Daniel
    Sacramento, CA
    Cool. I'll go that route instead of attempting to pull the manifold.
    Sniv mentioned needing to trim the sensor of the wideband when installing on the manifold. That still the case for the downpipe or no trimming needed.
    Lastly, according to victors video the passenger side looked a lot easier, does either side matter?
  16. Feb 14, 2025 at 7:25 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I believe he trimmed down the bung that was welded into the exhaust, so that the sensor's position was more in the middle of the exhaust stream instead of at the edge. Either side is fine.
    Mdl likes this.
  17. Feb 14, 2025 at 7:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As @armyoffoo said trim the bung not sensor.
    Weld in around 9 o'clock position on passenger side is easiest. Applied to aem and Innovate.
    HulkSmurf14, ARES35 and armyoffoo like this.
  18. Feb 14, 2025 at 8:10 PM
    ARES35
    ARES35 New member for life
    Mile high
    I still have the jumper where the relay was in fuse box.
  19. Feb 14, 2025 at 8:15 PM
    ARES35
    Mile high
    Speaking of manifold to downpipe bolts, make sure to loosen em hot, loosen/tighten/loosen. I stripped 2 of 3 on pass side and had a major leak. Pulled the DP broke the existing studs flush, drilled em starting small to 10mm using cobalt bits and oil. Dropped in new 10mm bolts, wash, lock washers and nuts. It was a bitch that could have all been avoided:annoyed:
  20. Feb 15, 2025 at 12:05 PM
    snivilous
    SW UT
    Let's see if this one will play nice
  21. Feb 15, 2025 at 12:28 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That got my attention!
    Mdl and snivilous[QUOTED][OP] like this.
  22. Feb 15, 2025 at 1:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice looking TB ya got there!
    snivilous[QUOTED][OP] likes this.
  23. Feb 15, 2025 at 1:52 PM
    snivilous
    SW UT
    She's getting trial by fire and just did 60 miles on the interstate and next will hit the sand dunes :rofl: if the idle could decide to lower faster that'd be great, it seems to drop 200rpm per restart so we're slowly getting there from 2500rpm down to 1100 currently :rolleyes:
  24. Feb 15, 2025 at 2:01 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Trying to get logs and had issues with the boost signal being static, replaced with spare sensor and no change, tested connections and there is a problem with the wire going through the firewall. Previously it read clean with less than 1 Ohm resistance, now it is OL or 34 Ohm resistance. I wanted to replace the firewall grommet with a proper bulkhead fitting, so now's my chance.
    **predator noises**
    Silver17, e30cabrio, koditten and 2 others like this.
  25. Feb 15, 2025 at 3:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Bulkhead fittings for the win! Better than my drill/grommet/silicone. At least it's held up in our rain.
  26. Feb 15, 2025 at 7:03 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Round trip Phoenix to L.A. BMW motor is here.
    Silver17, HulkSmurf14, ARES35 and 4 others like this.
  27. Feb 15, 2025 at 8:20 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Cosmetic only. You would have to mod more than the outer fender to vent anything from the bay with these.
    You can see here there is no passage of air from the engine bay to the fender:
    https://youtu.be/DhvWgIbiMIY?si=3yMY0Q1U02r0aNrJ
    You would have to cut holes inside the engine bay to have these vents work.
  28. Feb 15, 2025 at 8:42 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If I ever get to it I'll be opening my hood directly above the fan shroud on each side of support to draw air out from radiator. I already bought some stainless screen.
    I think 2 7x12 openings on each side of center support.
  29. Feb 15, 2025 at 8:44 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    How's it running?
    Mdl likes this.
  30. Feb 16, 2025 at 3:06 AM
    e30cabrio
    After a few scares Thursday & Friday going into limp mode at WOT from 7&8 massive misfires, the trip was great. It runs very strong, mileage is doubled from the old motor, still seems low though. But it is a giant brick with 295/70/18's
